Question about HP Pavilion a305w (DM181AR) PC Desktop
Installed memory cpu is making a loun beep and wont boot up
Loud beep wont start up after new ram installion
    President:
  • 1,179 Answers
Either RAM is not fully seated or it's incompatible with your motherboard. Try reseating first. Hope this helps.
Posted on Dec 22, 2008
  • 40 Answers
Ram is not supported or installed incorrectly, try readjusting it, then reset the CMOS and try again. If ti doesn't work after the readjust make sure that the ram speed etc is supported by your motherboard.
D101GGC mother board makes long beeps and fail to boot up. I removed rams, dvd rom, floppy drive, hdd and finally removed the cmos battery for a minute and put it back. it failed to boot up. But once I...
The fact that the board is making a long beep is usually a sign of a memory problem. This may be the RAM has failed (try with one stick at a time or some new RAM ) But, it could be more serious- The memory controller can also cause the same problem. This can be on the motherboard or part of the processor. Your motherboard is now obsolete as there have been at least 2 new CPU sockets released since. You motherboard is old and so the problem is most likely to be a failed onboard memory controller. But, try the RAM first if the fault remains I would suggest a new board. Sorry!
Apr 17, 2013 | Computers & Internet
Why does my dell inspiron m5030 laptop give me a series of 5 beeps and wont boot when I try to turn it on?
Please read this:
DELL BEEP CODES
Beep Codes Beep Code Description Failure Coverage 1 System Board: BIOS ROM failure System Board, covers BIOS corruption or ROM error 2 Memory No Memory / RAM detected 3 Chipset Error (North and South Bridge Chipset DMA/IMR/ Timer Error for Intel platform); Chipset Error System Board Chipset Failure Time-Of-Day Clock test failure. Gate A20 failure Super I/O chip failure Keyboard controller test failure. 4 RAM Read/Write failure Memory failure 5 RTC Power Fail. CMOS battery failure 6 Video BIOS Test Failure Video card / chip failure 7 CPU Cache Test Failure CPU failure 8 LCD LCD failure
Jan 12, 2013 | Dell Inspiron M5030 Laptop
ALL I GET IS A CONSTANT BEEP ON START UP. NO MESSAGES JUST FAST BEEP
It is common for most motherboards to beep to let you know
that something is not right: for example, missing/incompatible
RAM modules (or RAM modules not properly installed) or
missing Graphic Card or CPU improperly installed or overheating
beyond specs...If it's a new motherboard, lay it out outside the
case, installed with the minimum one RAM module, a Graphic Card
(if no built-in Video), the keyboard and mouse. Plug in the power
supply and CPU power coonectors and make sure you can post it
without any error. If there are, check your CPU and its socket, check
for thermal grease. Check for properply installed RAM module. Check
for Graphic Card if any. Of course, assuming that all your components
are compatible with your motherboard (consult user's manual or
manufacturer's website)
Jul 12, 2011 | Intel Motherboard, G33, Core 2 Quad, MATX,...
I get 3 beeps and no video on my gateway desktop
The beeps usually meen that the memory is either incorrect or not inserted correctly. Try removing the new memory and go back to the original configuration. Though not recommended, putting the memory in while still plugged up should not be the problem.
Sep 01, 2009 | Computers & Internet
Turns on, no bios no screen, just beep.
Now the question is, when the computer first starts up and you hear the beep, that is where it will tell you what your problem is depending on the beep you get.
One Long and one Short Beep = Motherboard issue
One Long and Two Short Beeps = Video (Mono/CGA Display Circuitry) issue
One Long and Three Short Beeps = Video (EGA) Display Circuitry
Three Long Beeps = Keyboard error
One Beep, Blank or Incorrect Display = Video Display Circuitry
If it is the last one, then try doing the following.
1. Disconnect external devices = Unplug everything from the back of the computer and then restart it. If it starts up, then it is one of the peripherals that is plugged in. You will then need to turn off the computer and gradually plug each one in and turn the PC back on to see if the peripheral is the problem. If that isn't the problem, the proceed to #2.
2. Cable check = With the computer shut down, make sure all the cables within the PC are attached properly. Once you finish doing that, turn on the PC and that isn't the cause, continue on...
3. Disconnect all expansion cards = Sometimes another expansion card can become loose and cause various amounts of issues. Remove each expansion card (clean them if necessary of dust) and replace them. Turn on your PC. If it doesn't start move to the next step.
4. Disconnect all drives = disconnect the data cables from the CD-ROM, hard drive, and floppy drive from the motherboard (make sure to mark them so you remember where they plugged into). This will either remedy the situation or you will see an error when you reconnect each device one at a time to determine which device/cable is causing the issue.
5. Remove the RAM = Loose or bad RAM can cause PC's to not boot or boot incorrectly. Remove each stick and replace them one by one alone in each memory slot. If the PC boots up in each slot, then your golden, but if a slot is defective, then your motherboard is damaged in that slot. You can still use the other slots as long as you use the defective one. If a stick of RAM doesn't allow your computer to boot up, its quite possible that stick of RAM is defective and will need to be replaced. But make sure you try out all the other options before throwing away a stick merely because the PC doesn't boot. A faulty stick can be the problem, but if the problem lies elsewhere, you may be throwing away a good stick of memory thinking it may be bad.
6. Disconnect and reconnect the CPU = Most CPU's are easy to remove, but if you aren't familiar with it. Read your manual on how to remove the CPU. Once you remove it and re-seat the CPU, reboot your PC.
7. If after you have tried all the previous steps and your PC still doesn't boot, then it is most likely that your motherboard, CPU, RAM, or power supply is defective and must be replaced. If you are unfamiliar with fixing the problem (or have never built your own PC) you can opt to have someone repair it or you can start with the cheapest option of purchasing a single stick of new memory and see if the memory was indeed the original problem. If the PC still does not boot with new memory, then it is most likely your motherboard, CPU, or power supply that is dire straights.
Aug 28, 2009 | Gateway GT5028 PC Desktop
Installed more memory into Compaq V2000
The new ram you have installed, is it the same speed/type as what is already in the system?
Take out the new ram and leave the old in. Try and boot. If all ok, swap out the old ram for the new and see if you can boot. If the system does not boot when trying one of the above, you know it's bad ram. If the system boots with the old ram and the new ram installed seperately, i'ts likely that you have two different types of ram. Check your old ram and see what spec it is. Your new ram should be the same. Compaq do not list a four beep error on boot, but my guess is conflicting ram.
http://www.bioscentral.com/beepcodes/compaqbeep.htm
Jan 17, 2009 | HP Compaq Presario V2000 Notebook
MSI P6NGM won't BOOT
You should only hear 1 beep. That 1 beep is power on self test, known as P.O.S.T.
That loud flat line sound (And I'm pretty sure about this), was you're CPU. Just because you ran & passed the stressed test is nothing compared to running the system under load? That's why when you put in you other memory nothing changed. If you hadn’t mentioned you clocked up the FSB I would have come to the same conclusion hearing the loud flat line statement.
Can you test the CPU in another board? That is about the only way to be sure it's not the CPU. Memory does not make that kind of sound. Memory makes short & long beeps.
You can try clearing the cmos/bios by going to pg. 2-18 in you're user manual. This will reset the bios back to default settings & cross you're fingers!
If I can be of more service, just post back & let me know how thing go.
Good Luck!
Mike
Apr 25, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
Booting problem
try these two alternatives:
1.try to clean or change the slot of the memory
2. check on th power supply you put on your motherboard for the new board there are the socket for the power to be placed on the otherboard
Dec 22, 2007 | Biostar P4M890-M7 Motherboard
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
HP Pavilion a305w (DM181AR) PC Desktop Logo
128 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
