After the damage i did not turn the console on, i unplugged it and let it dry for about 48 hours. after trying to turn it back on, the touch points do not work properly and it turns off by itself making the beeps as if someone has turned it off.
SOURCE: Xbox 360 wireless controllers wont connect!
well you might want to press the little button by the battery pack at the top and the little one on the 360
SOURCE: Xbox 360 power brick turns rd when connected to console
When the light turns red that means the power brick is to hot.
SOURCE: xbox 360 error e73
There is no easy do it yourself fix with the Ethernet failure. you will need to send to Microsoft for this repair. the actual Ethernet port is integrated within the main board. it will need to be replaced by a Microsoft tech. They will re solder the new port on the board and the actual Port is not available for consumer purchase at this time. use the number below to request a repair ticket.
1-800-4MY-XBOX
