I have a Panasonic SA-BT100 Blue-ray Home Theater. It was a display at the store. I brought it home and only a few of the functions on the remote work. When I try and use the bottons on the unit itself, I get a message on the tv saying that they are currently disabled. How do I reable them and the remote?
SOURCE: My dvd player won't play burnt CDs
the specs only mention cd-r make sure your not using cd+r
Posted on Mar 30, 2008
  • 8 Answers
SOURCE: panasonic sa-ht95 home theatre Display shows
Replace traverse assembly.
Posted on Oct 02, 2009
SOURCE: why wont my sa-pt950 panasonic home theater system
Are there different buttons so you can use it for multiple units? make sure you press the correct one
Posted on Dec 02, 2009
  • 10 Answers
SOURCE: My Home Theater System is displaying F61,it's a panasonic SA - HT740
its the fan !
Posted on Mar 19, 2010
SOURCE: Panasonic SA-HT820V need universal remote that can control radio
I had a similar problem. I disassembled my remote (flat screwdriver and pulling, cleaned the circuit board and rubber buttons thoroughly with rubbing alcohol, then reassembled.
For some reason, the remote didn't work properly until I started pressing the channel buttons immediately followed by the volume buttons. It worked normally, after that. It was most likely due to the not yet dry rubbing alcohol interfering. My remote now works, normally.
Posted on Sep 05, 2010
What soes W2S flashing on my Panasonic Home Theater mean
you need to go to the menu and move the audio setting.
Jun 12, 2013 | Panasonic SC-BT100 Theater System
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
I have a panasonic sc BT 100 blu ray home cinema system, the iPod and optical inputs appear to not to be working, are there any internal fuses that could have blown
Inputs are not fused. Have you looked at the manual(s)?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-BT100-Home-Theater-Systems-manual/id/17669ag210/t/2/
Digital inputs need to be assigned. The optical cable must be routed with no tight bends.
Jun 29, 2011 | Panasonic SC-BT100 Theater System
Can I add a blue ray player to my Panasonic SA-PT956 Home theater system?
Yes, sort of. IF the BD has OPTICAL digital audio. Otherwise you won't hear it in multichannel.
I'd run the BD's HDMI or component video straight to the TV.
Dec 28, 2010 | Panasonic Home Theater System System
Sa bt300 reads lock and will not open
You have to turn it off. Press the Open and Fast Forward buttons on the unit (Not the Remote Control) at the same time until the tray opens.
Mar 10, 2010 | Panasonic SC-BT100 Theater System
When i turn up the volume on my home theater it goes to maximum by itself, and does the same on minimum side!!
Turn unit off, then Press "Play/Pause", "Stop" and the "Power" button on the unit (not on remote) ALL AT THE SAME TIME. This should fix it. Also, download the firmware update (Google "firmware update for Panasonic SC-BT100 and follow the link to the Panasonic support site)....since I updated the firmware, mine hasn't done this again.
Feb 02, 2010 | Panasonic SC-BT100 Theater System
I have a Panasonic SC-BT100 Blu-ray Home Theater system. Every time I hit the volume button once, the volume starts scrolling and won't stop until I hit the OK button on the remote. Most of the other...
I have had the same issue and have discovered that if I walk over and manually adjust the volume one time, it corrects the issue with the remote for a few months. It's obviously a bug, but at least in my case the bandaid is quick and simple. Much simpler than configuring the blasted thing to work like I want! :-)
Good luck ... hope it works for you too.
Jan 14, 2010 | Panasonic SC-PT660 Theater System
Can u program Panasonic SC-bt100 without remote ?
Not that I know of....the remote has options that aren't on the physical unit so programming must be done with remote.
Jan 01, 2010 | Panasonic SC-BT100 Theater System
I have the Panasonic SC-BT100 Blue-Ray Disc Home Theater Sound System, and whenever we watch a dvd it plays fine and after a while the tv turns blue but the sound goes off.. after a while it will come back...
Cooling fan is probably dirty or not running. Check the fan by removing it with the two screws on the back and make certain that it's plugged in and the short, black wire (that appears to go to nothing) is "securing" the plug to the board.
Jan 03, 2009 | Panasonic SC-BT100 Theater System
Televison & Video Logo
317 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
