Question about E-Machines eMachines Monitor E15T4
EMachines monitor keeps flashing the On Screen Display menu.
I think the year I bought the monitor with the computer was around 2006. The buttons on the side won't work. When I press the Menu button on the side it stops the menu from flashing... until I remove my finger.
How can I turn the On Screen Display Menu off using the computer or how do I fix my button problem?
    Scholar:
  • 100 Answers
If it is the button. you would have to open the monitor and fix it that way, and i dont suggest doing that yourself, unless you are familiar with electronic components. take it to a repair shop. call around and get an idea of who would do the best job for the best price.
Let me know :)
Posted on Dec 24, 2008
The right hand 1/3 of the screen is blank. Cannot get anything to display
sounds like you have to set the monitor resolution using your computer. right click desktop... graphics options. or Properties. look for Resolution slider. Move it around. press apply. see what happens. if it now fits but is fuzzy. change the refresh rate eg. 60 Hz or 75 Hz. On the monitor itself there is typically a button that allows you to move the image to fit the screen, quite often these settings are inadvertently played with by children ect. look for buttons/ menu's on your monitor itself. play with the settings .
Aug 24, 2010 | E-Machines eMachines Monitor E15T4
HCL Monitor Screen Display Problem with Contrast menu showing up.
my hcl 17inches monitor is displaying contrast,brightness etc automatically
in the middle of the screen.even if i press the menu buttons it
disappears for a sec and comes again and again.what should i do to
solve this?
Sep 13, 2009 | Computers & Internet
HP 2338H Monitor Goes into Sleep mode and I have to power comput
you meant w2238w , right, you left off the w?
circa 2006 monitor, 11 years old.?
if the monitor fails on 2 PC, the monitor is bad ! ok, do that...
then
push the monitor menu buttton, connected to a running PC.
if the OSD is dead, , (on screen display , menu button front of monitor)
that means the monitor is dead, CCFL tubes are bad.
cold cathod florescient laml tubes all day this old.
the menu button can be in lock mode, hold the button for 10 seconds, and it unlocks
then go in the OSD screens if they work,. and turn off the sleep timer.
this timer is marked in the OSD as power saver,. turn it off.
it is a time clocked feature, and a pain to use on modern PC.
your PC does sleep modes today and never us this timer,inside monitor (default is on, turn it off)
all that is on page32 in your manual,
https://www.manualslib.com/manual/71500/Hp-W2338h.html?page=32#manual
Sep 21, 2017 | HP Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Menu box keeps popping up on screen
Same problem here. I've had this monitor almost two years with no problem until this morning when it started flashing the menu screen and nothing I do will make it stop. Oh well, it was only a hundred dollars. I guess this is emachine's way of saying, "you got your money's worth, now throw this piece of junk away and get another", lol. And therein lies the solution! :)
Jan 13, 2009 | Computers & Internet
Contrast/menu/screen resolution box wont stop flashing on screen.
try to clean around it's exit button sounds stuck
or unplug monitor for about 20 minutes
if the problem persists i would reinstall driver
Jan 09, 2009 | E-Machines eMachines Desktop PC
Menu/screen resolution/contrast box keeps popping up on screen.
By what your describing, the board in the monitor that allows you to make changes to the display is going bad (sounds like the settings button). If it were a notebook you might be able to get a board replacement (just an example I know notbooks dont have this feature in the lid). Since it seems that your display is for a desktop, I dont think it would be easy or inexpensive to get a replacement board. You will probably have to get a new monitor. If you want to fix it yourself, pull the monitor apart and get the board out. Try an electronics cleaner and put it back together. If it works, great. If it doesnt, take the board back out and take the board to an electronics (tv) repair shop and see if they can solder in a new button. If that doesnt work your back to buying a new monitor. Hope this helps...
Monitor will not turn off and keeps flashing the words Auto processing
it is not a bad rom. if it was a rom it would constantly act up but it only acts up upon overheating. The solution is difficult but if you open the monitor you can find all of the heatsinks take them of and replace them with bigger ones. or have a fan blowing on it at all time it is active i added bigger heatsinks to my emachine le1799 and it solved this problem of pulling up menu and changing setting by itself and the lack of the ability to turn power of.
Sep 15, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Color on monitor
First, have you degaussed the unit to stop any magnetic interference?
Do you use software to change monitor settings or do you use the on screen display menu on the monitor?
Most lcd's have a button for menu on the lcd. This can be used to adjust color, contrast, brightness, degauss, as well as screen position and size.
Mar 06, 2008 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Monitor E15T4 Logo
428 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
