Question about Homelite 'Yard Broom' Leaf Blower
What is the proper gas/oil mix ?
Gas/oil mix ?
  • Thomas F. Schneider May 11, 2010
    Most are 50 to 1.
    Homelite website support is usless.
  • keith johnson May 11, 2010
    what type of equipment do you have
    Scholar:
  • 76 Answers
If you dont have your owners manual, than id try 40:1 mix. If it smokes alot than cut it back to 32:1
Posted on Dec 27, 2008
How do i mix the gas/oil on a 25 cc 2 cycle craftsman weed eater
The specs say 40:1 so 3 - 3 1/2 OZ of 2 cycle oil in a gallon of gas.
May 10, 2014 | Craftsman 25cc Gas Line Trimmer
I have a sears 2 cycle mini tiller that worked great for the first hour but now won't start.
Do not use pre-mix fuel. Clean carburetor. Check age of gas. Cannot be more than 30 days old.
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil) .Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
check age of gas. Cannot be more than 30 days old.
Oct 10, 2012 | Craftsman Gas Mini - Tiller/Edger
Need gas mix
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
Jun 03, 2012 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Need gas mix solution
Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil).Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage.
We have lost the information to make the gas mix for the trimmer. We used the gas mix we had last year and it put out a white exhaust. What is the gas/oil mix?
Hello. First, never use old gas ion a small engine. Use 1gallon of new gas and add one small bottle of mixinng oil, 2 ounces,available at any Walmart or auto parts store.
May 26, 2011 | Garden
On a gas chain saw, do you mix the gas
there is usually a fuel/oil ratio (i think yours is 50:1) you must buy the 2 cycle oil and mix it with gas at the ratio reccommended by the manufacture. the bottle may say 6 oz per 1 gallon = 50:1 So 1 bottle of 2 cycle oil for every gallon of gas. mix them in a proper fuel can. then let the cutting begin.
Mar 17, 2011 | Homelite ZR10926 16 Chain Saw
What kind of gasoline?
  1. Check your manual for the proper gas-and-oil mixture. For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  2. Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
  3. Pour the proper amounts of gas and oil into a fuel can. Shake the can well to mix it.
  4. Label your gas can with the mixture ratio. You can use the same mixture for other two-stroke engines.
  5. Shake your fuel can thoroughly every time you refuel. After a while, the oil will settle out of the gas, and shaking it up ensures that the oil and gas are properly mixed again before you put the fuel into your chainsaw.
Mar 06, 2011 | Garden
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
What reatio of gas to oil? And what kind of oil?
32:1 / 40:1 will be fine.... your choice of pre-mix oil...pick your fav brand . use a ratio-right cup and make it simple
  1. Pump one gallon of gasoline into a gas can. Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+3322788282+9016233241+8962074949+8941458308+0371618899+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
  2. 2Measure out the proper amount of two cycle oil in the Ratio Rite.
  3. 3Pour the required amount of oil into the gas can with the gasoline.
  4. 4Shake the container lightly until all of the oil is thoroughly mixed in with the gasoline.
  5. 5Pour the mixture into the machine`s gas tank.
Jan 23, 2010 | 2004 kawasaki KX 125
Too much smoke
Use TWO STROKE ENGINE OIL in the pump. If not using an automatic oil pump, then mix the gas and oil 32 to 1. That equals 4 ounces of TWO STROKE ENGINE OIL to one gallon of gas. NEVER use motor oil in the gas. Only two stroke engine oil. There may be an oil build up in the crankcase. Do a 64 to one gas/oil mix for awhile. Watch closely. when the smoke reaches proper levels go back to the 32/1 mix.
A “very helpful” rating for this answer? Thanks!
Jun 17, 2009 | 2000 Yamaha DT 125 R
Homelite 'Yard Broom' Leaf Blower Logo
138 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
