So in 1992 if your engine dosent work you will have to ask a electrishen
Sounds like something electrical, but you will have to narrow down the possibilities to proceed.
When it won't start, you need to find out if you are loosing spark to the plugs or fuel. Then go from there with your diagnosis.
I cheaked all the coil packs got got spark from all eight and i got gret fuel preasure
Ok, do you have voltage and ground pulse to the injectors ?
That is my next test but my egr valve is reading low flow could that b my prob i wouldnt think it would cause my engine to stall or not start
Not sure how you could get a reading from the EGR, but if it is sticking open, it can cause a major vac leak which would affect performance.
SOURCE: Jeep GCL Backfires Stalls
Aaron, I had the same problem. It is the most expensive part of course the computer. I replaced everything as well till I replaced it. They are remanufactured and have had problems with them as well. I am on my third one now at 200k miles. Oh and by the way it does not show up on the diagnostic check. Good luck
Frank
SOURCE: I have a 93 mercury topaz 4cyl 2.3L that stalls
It sounds to me like you replaced everything but the most likely cause of a stall while driving...The crank sensor.
SOURCE: Shakes while idling and sometimes stalls.
check for minor vacuum leak and map sensor,pcv,egr valve
