Question about Traxxas T Maxx 3.3 Monster Truck
I had bought a traxxasT maxx used today and was told it was a 3.3 and think its a 2.5 with a 3.3 engine how do i tell the differance or is the rest of the truck all the same.and seems to run very lean on idle and stalls or bogs when you go to take off it is a new engine 2 tanks burnt out of it
    Problem Solver:
  • 12 Answers
You have to break the engine in on 5 tanks or fuel the only way to be sure it a 3.3 is measure the piston diameter open the low speed needle just a little like an eighth of a turn the one on the barrel of the carb
Posted on Dec 22, 2008
Hey can a bad MAP sensor cause my 04 Malibu Maxx go into engine power reduce mode?
Yes..todays cars are so complex w ovr 1000codes. Each auto is different and unrelated sensors can make a mess. A datastream done w factory scanner not a miracle code reader from some store
Jul 09, 2015 | Cars & Trucks
I have had my lap top in 3 different shops and been told all 3 times that the proublems I have are with my server!!!!!! I have used yahoo for many many years and NEVER HAD A PROUBLEM UNTIL I got this lap...
Thinks to try:
Try a different browser on your laptop.
Try your laptop in a different location(different high speed connection like coffee shop or libarary)
Try your accont on a different computer
Mar 01, 2011 | Computers & Internet
I have a 10 hp tecumsen on a colman maxx 5000. The starter rope rips the unit up when I try to start it. I have been told that the govener in the engine is broke. I need to know how to get the armetor...
Your engine likely uses a tapered shaft. The alternator / generator portion is put onto the shaft, and as the screws are tightened, it is forced tightly onto the shaft. You will need a puller to get it off. Sometimes, if you disassemble the alternator to get to the end housing closest to the engine, there will be threaded bolt holes that are not used for anything. Putting a bolt (1/4x or 5/16x " bolts usually) will allow you to push the alternator off the shaft.
Unless you have been able to find governor parts already, it likely will end up being easier to replace the entire engine itself. Tecumseh is out of business (about 3 years now, I think. At least 2), and parts are quickly drying up. I have had pretty good luck with the Honda Clones from Harbor Freight. Just FYI.
Sep 22, 2010 | Coleman Powermate Powermate 5000W...
My t maxx 2.5 is driving and steering by itself. when the engine isnt running everything works fine, but as soon as i start it it drives and steers and i have no control. ive taken it to many places...
Sounds like an antenna problem. Make sure the antenna is isolated from any metal of the chassis or engine. Also make sure the antenna is not damaged anywhere. You could try purchasing crystals on a different frequency, but I think that it is more likely a mechanical issue.
Nov 01, 2009 | Traxxas 4910 T-Maxx RC Monster Truck
Just bought used yesterday dodge 3500 diesel dually. engine light ok yesterday. today engine light on and off, what to do? no warrant on vehicle
you can bet they turned it off right before you got it, so the light would not be on when you picked it up.. In order for the light to come on, the computer runs tests. if a test fails 2 times, it turns the light on. they knew it had a problem, period. If you have a contract I think you have 3 days to back out. I am probalbly wrong,but try it anyhow, bluff them. Tell them you want it fixed. Car dealer or private sale??? if its a private sale, you may be stuck. Call dealer be nice and tell them the light is on, play dumb and tell them you want it fixed, dont sign anything.
Sep 24, 2009 | 2006 Dodge Ram 3500 Truck
I just bought a 01 neon. The previous owner said he had to boost his car as he left his lites on. Now the stereo doesn't work. It has 3 lights flashing on I think the equalizer. I am told it is a antitheft...
I was under the impression that the dealer would give customers the code for their radio for free. Check with the last owner and see if he has it and knows how to enter it to get it working. When you get the code, save it. I haven't kept a factory radio for longer than it took to drive home from wherever I bought a vehicle, so, don't know how to enter the code. There is a code saver (small battery that keeps power in system) that you can buy/ use to prevent this in the future if you need to service battery.I'd also check with a different dealer...perhaps they won't be so greedy...
Good luck
Jul 26, 2009 | 2002 Dodge Neon
2006 Malibu Maxx ss hard shifting/Check engine light
There is no dip stick. Its most likely not the fluid. These malibu's use the first generation GM LAN system. Check the data cord comming from the transmission near the mechanical shifting linkage. Alot of these shifting issues and errors are from a break in the wiring causing bad data to be sent/rvcd to/from the computer control module- these cars are electronically controled shifted, not mechanical.
May 15, 2009 | 2006 Chevrolet Malibu Maxx
97 Toyota LC. Prado TZ . Auto- Transmission Oil change.
you are suppose to use T-IV ATF in toyotas or they will not shift correctly.
Feb 18, 2009 | 1997 Toyota Land Cruiser
42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Vertical Black line 3 inch width on Plasma Samsung 42C96HD after 2 months of use
I also have the same problem I phoned Samsung today to explain the tv was only 14 months old, they didn't wanna no because it was out of warrenty by 2 months. I am getting a black solid line down the left hand side of the screen. I ended up phoning Dixons were we bought it from, they have told me to get an independent engineers report done & send the report to them within 14 days. Dixon told me it was a known problem with Samsungs. They said they will fix it free of charge if they can if not they will send vouchers to the same value of the television. So beware stay clear of Samsungs.
Feb 03, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Traxxas T Maxx 3.3 Monster Truck Logo
149 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
