Question about Lexmark Z845 InkJet Printer
Label sheets won't feed, jam
Lexmark z845, about a year old, won't feed cd label sheets. Been doing fine until last few months. Have to "force feed" like the rollers are dirty and slippery and can't grab the label sheets. If they do grab, the label sheet will turn sideways and jam. If that's the problem, how do I clean the feed rollers (or roller)?
  • 1 more comment
  • skyking310b Dec 23, 2008
    Thank you for the suggestion. I won't have access to the printer until Sunday. I will try your suggestion then. Is there a pictorial or schematic of the Z845 printer I can refer to? If I have to partially disassemble to clean the paper path, a diagram would help. I have partially disassembled, cleaned and reassembled an HP Color Laser printer, so this small inkjet is no problem. Would like to know any obstacles I may face.
    Thanks. I guess that brings up a final question of what's the best cleaner for the rollers, one that will preserve and not deteriorate the roller surfaces further? I'm used to using alcohol and swabs from cassette servicing. I'm sure there's a better cleaner for printer rollers. Any suggestions?
  • skyking310b Dec 29, 2008
    Ajkill, thank you! This morning at church I was able to clean the rollers visible through the front panel that allows access to the cartridges. I used Q-Tips and alcohol and cleaned what I could get to. After powering it up, I put a few sheets of the CD labels in and hit the manual feed button several times and they all fed through perfectly. Problem solved. Thanks again. I just wanted to make sure there weren't any problems others had with cleaning the rollers before I attempted it. Always better to err on the side of caution.
    Regards,
    skyking310b
    Colorado
    Genius:
  • 2,035 Answers
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
good luck..
Posted on Dec 22, 2008
  • Anand Kumar
    Anand Kumar Dec 23, 2008
    In the Lexmark printer the parts you can open is only the paper tray and then top cover which provide access to all the rollers , and clean the rollers which are visible to you ....Sorry no diagrams ...
    Good luck...
  • Anand Kumar
    Anand Kumar Dec 25, 2008
    I guess any cleaning which is able to remove dirt from the rollers is good , alcohol and swabs are good enough...
    Good luck...
How can I make a printing test without connect my printer to the pc?
How to Perform the Hardware Test on a Lexmark Z840 and Z845 Color Jetprinter Document ID:HO3002 Properties Lexmark Z845How to perform the hardware test; Hardware test; Lexmark Z840 Color Jetprinter; Microsoft Windows 98; Microsoft Windows Me; Microsoft Windows 2000; Microsoft Windows Server 2003; Microsoft Windows XP Professional x64 Edition; Microsoft Windows XP
Solution Performing the Hardware Test
    1. Turn off the printer.
    2. Press and hold the Paper Feed button.
    3. While continuing to hold down the Paper Feed button, press the Power button ONCE.
    4. When the Power button begins to flash rapidly, release the Paper Feed button. A test page will print.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Lexmark Z845 InkJet Printer
My Lexmark C510 keeps popping up with a Paper Jam 241 error in Tray 1. There is no paper jam. I open the printer door take the tray out, put it back in and shut the door. How can I fix this problem? I...
I have a Lexmark C510 colour printer: Manufacture date June 2005.
I had been getting the "Paper Jam 241 error in Tray 1" message for some time. Sometimes it would print just fine but in the past several months, it's been bad. I'd pull the tray out (notice roller marks on the top sheet that was only partially fed), reinserted the sheet properly into the tray and try again and again. The techy at Lexmark mentioned that I could purchase a new rubber roller that feeds the sheet but that I might first wipe down the roller myself as they get worn and old. I first wiped it down with a damp cloth to clean it then thought to try reconditioning it with leather conditioner we'd purchased for our couch (I'm sure Amourall would work just as well). Voila, the old, dry roller was picking up paper again. Just open the rear door and that grey roller (it's black again when you recondition it) is at the bottom. Hope that helps.
May 11, 2010 | Lexmark C510 Laser Printer
Lexmark S405 Paper Jam
Hello there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
http://www.printertechs.com/tech/mkinst/mk-1300-5fuser1.php
Feb 10, 2010 | Lexmark All-in-One Printer with PictBridge
Lexmark T640 won't print on label sheet a SECOND time...
try changing feed rollers. For a quick fix, remove the rubber rollers and flip them inside out. It should work
Jan 28, 2009 | Lexmark T640 Laser Printer
We have a Lexmark X5250 All in one. In the last two or three weeks we cannot get it to accept any type of paper. We can put in one or more sheets and when we try to print, we get a notice to load paper....
I have to select -print first then when I get the "load paper" message, turn the printer off . wate a few seconds then turn it back on. I will then feed the paper and print. I may end up replacint the printer.
Apr 29, 2008 | Lexmark Office Equipment & Supplies
Printer z845
Go to Lexmark.com
They have a link to drivers. Also probably a link for troubleshooting.
Mar 23, 2008 | Lexmark Z845 InkJet Printer
Printing on CD labels seem to ruin fuser in Phaser 7300
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.44 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
Lexmark Z845 printer pulls paper sidw ways
I had the same problem with lexmark z845. It is easy to solve this problem.Just do like the picture I post and you never get the paper pull to one side again. The problem is the rolling motor is too strong, so it pull the paper out out the tray in oneside. I use the mini cassette box, stick it with the super glue. And the printer works very well
Feb 20, 2008 | Lexmark Z845 InkJet Printer
Paper wont feed propaly
Something probably fell into that tiny pinch of an area where the paper goes. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over, poke it if you have to, and shake it around til the little bugger falls out.
Sep 22, 2007 | Lexmark X1270 All-In-One InkJet Printer
Lexmark Z845 InkJet Printer Logo
215 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
