Question about Kenmore Elite 45986 Front Load Washer
Kncking and f error
My front loader makes a horrible knocking noise during the spin cycle and now it won't spin at all. It gave me an f error. I have no manual can you help me PLEASE?
    President:
  • 1,294 Answers
If you hv no manual at least write your model number. You could also look for "solved problems" in this site where Kenmore is featured. Most likely u will find your solution
Posted on Apr 12, 2007
My front load washer is making a scraping noise and loud noise during the spin cycle
Could be bearing failure. It's quite common in front loaders.
Feb 23, 2018 | Washing Machines
The drum inside our front loader washing machine is loose and makes a horrible knocking noise while in the spin cycles. How can this be fixed?
it could be fixed,,, but it sounds like drum bearings worn out thats not going to be cheep,,,or it could be the steady spring/s if one has fell off or just snaped the other is trying to hold all the weight of the drum and it cant do all the work so the drum swings around on the spin cycle battering the inside of the washer,,,this will pull off the water pipes and wiring to other parts like the motor,,,you could wip the top or back off and look inside you will see if the spring has come off,,it will be laying in the bottom
Jul 03, 2010 | Washing Machines
Kenmore front load washing machines knocks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
Washer Problems Washer noise when spinning
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
May 25, 2010 | Kenmore HE2 Plus Front Load Washer
Samsung front loan washer makes knocking noise during rinse cycle.
I have had a repair guy out for a separate issue and been told my knocking noise most prominent during rinse and spin is the bearings going. I have a samsung WDJ1225c front loader
May 14, 2010 | Samsung WF337AA Front Load Washer
Loud knocking and vibration during spin
heatman101
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Makes horrible noise during spin cycle only
The bearings have most likely gone bad. This is a very common problem with the front load washer when powder soap is used.
Jan 28, 2009 | GE WBVH6240F Front Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
129 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
