Question about Garden
Where is toro 31820 auger shear bolt?
I need to repair my toro 832 snow blower. right auger will not spin.
  • 70 Answers
Shearbolt is located at #54 in this diagram.
https://homeownersolutions.toro.com/portal/server.pt?space=CommunityPage&cached=true&parentname=CommunityPage&parentid=1&in_hi_userid=19462&control=SetCommunity&CommunityID=214&PageID=238#drawingDiagramPage
part#322-9
It may be hard to spot on the auger shaft as it may have sheared flush with the holes so look close. You may also need to remove the part of the bolt remaning inside the shaft.
Posted on Dec 22, 2008
I have a Toro Power max 1323, auger turns but does not throw snow
only a guess of course but if this a 2 stage then you missed a shearboth to the blower if auger runs and it doesn't throw it out
Feb 02, 2015 | Garden
How to remove the right hand auger from a nova performance snow blower model 629104x31
remove the whole auger from machine and then remove the shear bolts. Slide the auger off shaft
Aug 25, 2014 | Garden
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Ariens st350 snow blower wont blow snow, augers wont spin
there is a bolt that goes thru auger and spinning shaft (look for a hole where it once was) holds the augers to the spinning shafts, it is called a shear pin, it is a safety feature, and made of softer metal, so if you pick up something too hard with the auger, it wont lock up the engine, or break engine crank shaft.find an ariens repair shop to purchase the shear pin so you get the right softness of metal.
Mar 05, 2013 | Garden
Toro524 5hp snowblower auger diconnected or shear a key or gear box
remove plug wire and try to spin augar by hand .If it spins freely you sheared a bolt located on either end of shaft that runs thru augar drum.You will see a notch in augar drum to access this bolt .If it is this bolt insure you replace it with factory bolt they are meant to shear to prevent costly damage .if the augars don't turn then damage is deeper .Go to toro web site with model number and serial number to view brake down drawing.
Jan 22, 2012 | Toro Garden
I have a honda ccr2450 and with the heavy snow today it clogged and now the auger doesnt seem to turn to speed and is slipping, not throwing snow etc, is this an easy fix. thanks carl
You have a two stage snow blower. The first stage in your auger and they are equipped with a safety shear pin. Consult your owners manual for proper pin or shear bolt replacement.
Feb 26, 2011 | Toro Garden
Toro powerlite 98 cc 16" Mod no 38182 ser
Yes, you have a shear pin and that is probably the problem...
The shear pin often will not fall out and look like a normal piece but in fact be broken...
The shear pin usually is in the main shaft from the transmission to the auger drive...
Some are right on the auger its self...look around you will find it...
heatman101
Feb 26, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
I have a snow blower which will start up but it won't move forward in the snow nor will it push the snow. Not sure what is wrong. I can manually move the blade around that pushes the snow.
If you start the machine and the axles spin but the augers do not it is because the shear pins are broke. If you look closely you will see the the augers have shear bolts and nuts or shear pins. If you jam a piece of ice or a stick in the augers while they are spinning the bolts will shear so you do not damage the expensive augers or the worm drive gears. If the axle spins with the augers you may have torn up the front worm gear in the front of the auger intake. If you spin the small auger and the large auger moves but when you start and engage the auger nothing happens you will have to remove the under cover and inspect the drive belt pulleys for jammed or broken parts or more commonly broken drive belts.
Jan 28, 2011 | Mtd 22" Yard Machine Push Mower
Garden Logo
224 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
