Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Very slow interface but no such problen when paying a game
After turning on my psp, the interface is very slow. it takes minutes just to transfer from one function to another and to load a game. but when the game is loaded, the game does not show the same slowness.
  • 40 Answers
This happens when you have a dirty psp game loaded, perhaps it needs cleaning? It can also happen if somehow the system files have become corrupted, if this is the case you must reinstall the PSP software or try updating it by connecting to the internet with your psp and going to the update function.
Posted on Dec 22, 2008
Download speed extremely slow
The memory stick capacity left too little, format once again in the original exam will do something! I just, finished more than a lot of capacity!
pspcovers
Jun 07, 2012 | Sony PSP 1000 Black Console
How can i downgrade my ver 6.10 software psp????
Hello there
Download MPH Downgrader and Firmware version you want(e.g 1.50) to the Windows-based computer. Connect the PSP Slim to the computer's USB port using the USB connector. Transfer the two programs to the main folder of the PSP Slim. Disconnect the PSP Slim from the computer's USB hub when the transfer is complete.
Turn on the PSP Slim. Go to the Settings/USB Connection in the Home menu and select the EBOOT.PBP file in the PSP\GAME\UPDATE update folder. Extract the MPH Downgrader zip file to the root folder of the PSP. Click OK using the X button if you are prompted that this will replace some files.
Go to Photo/Memory Stick in the Home menu. Wait as the screen goes black and numbers appear. Wait two minutes and then press and hold the power switch until the PSP Slim turns off. Release the power switch.
Wait as the PSP Slim turns on and reboots. Go to Game/Memory Stick in the Home menu and select PSPS Update version 1.50. Press the X button to start the update.
Wait as the update finishes and presents an error message. Press the O button to restart the PSP.
Oct 04, 2010 | Sony PlayStation Portable (PSP) Slim...
My psp works really good but when i try to play games or movies it starts to slow down and flicker
1. Set “UMD Mode” to M33 driver NO UMD
The PSP firmware version was 3.71 M33 but is also tested with higher versions like 3.8 M33. These firmware versions should have the UMD mode to M33 NO UMD.
To set the following you need to go to the Configuration Page. To go there you need to:
i. Turn off your PSP
ii. Press and hold the R button. While doing that slide and hold the power button up. This would turn on your PSP. You should hold until the black screen appears saying “M33 Recovery Menu Configuration”
iii. If the PSP just turns on to the normal menu, just repeat the two steps above.
2. Set “Use VshMenu” to Disabled.
It is also in the configuration page. Use the steps above and you should be able to find it.
Now after these two steps, if you continue no further, your PS would run faster – but only for the menu screen. The menu would be fast and really responsive. However, try playing a game. You would notice that loading is still slow and the gameplay is still played in slow motion
3. Set the CPU speed to Default.
Now this is really important. The CPU may not really be used when playing music or in the menu screen but its very important when you play games.
There are two settings you need to adjust. Speed in XMB and Speed in UMD/ISO. For us normal users we just need to set these two to “Default”.
After this, your PSP should be running ok. However, I recommend that you do another step which would also help the performance of your PSP.
4. Free up memory from your Memory Stick.
You can do this using two methods. One, you could connect your PSP to your PC using a USB cable. Two, you could remove your memory stick and use a card reader. I prefer the second method but you may use any of the two.
Method Two: Remove your memory stick and use a card reader.
Freeing up memory is easy, if you know what files to remove. As my friend is not really using her PSP for music and videos, majority of her files are game files. What she does is that she just puts games that she really plays. I recommend doing the same for your PSP.
Game files are located at the folder named “ISO”. The game files have a .CSO file name extension. You don’t need to delete them. Just transfer them to your hard disk. That way, when you want to play them again, you just have to transfer them back to your memory stick.
But if you have music and video files that take up much space, I recommend that you look into those first. Normally you would like to have at least 500MB of free disk space. You’d need the space for your game saves.
My friends have done the steps above with ease and have solved their slow PSP problems. Most of them, if not all, had to do all four mentioned above. The first three usually solves the problem.
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
Psp slow using cfw
if you mean the game is slow turn off the psp. then hold the right trigger then turn back on. it should boot to the cfw menu scroll to cpu speed and press x. then change the speed to 333. (scroll through till you get there) this should sort it. most games are ok but grand theft auto sometimes slows
MY PSP SLOWS DOWN ,IT ATKES TIME TO DOWNLOAD GAME.MAINLY ITS SLOW
its natural that it takes long time to downlod a psp game....u need to wait 4 it...
Mar 18, 2009 | Sony PlayStation Portable (PSP) Console
Psp gone really slow
try getting a memory stick for it.. so then lots of the memory is free'd up
Dec 28, 2008 | Sony PlayStation Portable (PSP) Console
Psp laging
Turn on the PSP holding the R trigger.
You should get to a different menu. change the CPU speed to a higher speed. This will consume more battery tough
Dec 16, 2008 | Sony PlayStation Portable (PSP) Slim...
Psp rower problems
My recommendation for this is first try a different battery...if this doesn't fix it, then probably, your PSP has been bricked and it needs to be unbricked through PANDORA KIT....
Sep 03, 2008 | Sony PlayStation Portable (PSP) Console
PSP Slowed Down
Do a Restore Default Settings and try.... also check the M33 Vsh menu values..(press SELECT button to pop up the VSH Menu) it should be like this. if any changes to change it to the default values which is shown in the picture.
if the problem still exists format the mem. stick and try
Jul 27, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
213 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
