Question about Exercise & Fitness
Electric start on snowblower not working
13hp yardman snowblower, there is power in receptacle, but no sound of starter when I push the button.
Key is in, oil level is up.
Earlier this week, the starter worked fine.
SOURCE: Mastercraft snowblower will not start
if old gas was left in the tank and not flushed it makes the carb stick and won't allow the proper gas flow to the motor...I would first test the plug by verifying it has spark..if it does what i do at times is quickly spray some quick start in the plug chamber and reinsert the plug and try to restart...this at times will get the spark going and allow the motor to start.....you can also try to spary some in the carb before starting...just a squirt or two....the best thing to do is actually clean out the carb as it is likely the issue.....hope this helps
Posted on Dec 31, 2008
  • 87 Answers
SOURCE: 1997 honda shadow ace vt1100c2 ..starter switch, electrical
bad connection on starter or batt check bof of em
Posted on Aug 04, 2009
SOURCE: yardman snowblower wont start
More often than not, old gas in the carburator breaks down. It turns green and smells like turpentine. This usually fowls the carb inlet. I dodnot know the technical name but You can usually solve the problem by removing the bolt that holds the bottom of the carb. to the carb. It looks like a very small tin can under the carb. This contains the carb float and lets gas into the carb. The bolt is usually hollow and has two extremely small holes that allow gas to be taken up to the carb venturi. They are usually clogged and therefore no fresh gas gets through into the chamber. Use a very thin wire or needle to clear debri. Clean out old gas and residue before reassambley. It could also be the Carb float stuck closed and again no gas is getting through. You can service these issues usually without taking the carb off the motor.
Posted on Dec 19, 2009
Testimonial: "ill try that sound right"
SOURCE: Problem with snowblower electric chute
This was poorly designed , you will have more problems unless you fix it right as the bolt heads underneath the shute ring is rubbing the right stop and on top of the motor housing the main problem is the left ring stop is hanging up on the front motor mount.
to fix it,remove the motor,grind about 3/16" off the rear shims and file about the same off the bottom of the front motor mount,remove the motor mount bracket,file about 1/4" off of the right stop,remove the shute and the shute ring, mark the left stop before removing,bend the left stop up about 3/16" be careful not to bend the ring,replace motor bracket first than shute ring and shute than replace motor.if your shute has hung up often you may need to replace the motor,you can go to an auto parts store buy a 1999 chevy lumnia passenger side window motor around $50.00 vs yardman $360.00 you will need to tap out the mount holes with a 5/16 standard thread tap and tap from the bottom of the motor,don't forget to file the bottom of front motor mount.
Posted on Feb 23, 2010
ftw1952
  • 10319 Answers
SOURCE: Dryer will not start when On button is pushed to start.
Check out the door switch. Push it in as far as you can by hand and hold then hhave someone try and start it. If that works you need a new door switch
Posted on Jun 10, 2010
How to fix a electric start on a Craftsman snowblower
it needs a new starter. also probably needs the carb cleaned out
Mar 14, 2018 | Craftsman Garden
My snowblower isn't starting
If it's the starter that makes a humming noise then you need to check the starter out. the gears could be stripped or even a tooth missing so it won't grab the fly wheel. Try pulling the start rope and see if that makes a difference. My Craftsman 8 horse has a recoil starter as well and I quite often use it as well. I don't always use the electric start.
Jan 10, 2016 | Craftsman Snow Blower / Snowblower Bottom...
My electric toro power curve 18" snowblower won't start.
I had the same problem. Stopped while using it. I discovered the black plastic cover over the motor was not properly seated all the way around which allowed snow to infiltrate the area. With all the moisture present it didn't take long for the carbon from the brushes to totally cake the copper contacts. Note all the ice present. After cleaning with a piece of emery cloth it's worked like new. Hope this helps those that are still having trouble. Take extra care to ensure the black cover is properly positioned before tightening the 3 screws.
20171230_115326-jxqihalonfbfbg4v1uc0cw0h-2-2.jpg Cheers, Ed
Mar 05, 2015 | Toro 1500 Power Curve Electric Snowblower...
How do i trouble shoot the electric starter system,it does not work
Mine the electric cord had pulled out of the receptacle.on the blower so it was not working. I pulled it right out and reinstalled it It's ok now.
Do you have power coming to the blower or have you blown a GFI and it needs to be reset. Does the starter click or try to work? These are things that I have to know before we tear things apart.
If it buzzes it could need a gear replacement. on the starter itself.
Mar 03, 2015 | Toro Powerclear 221qe Electric Start...
Troybuilt snowblow electric starter won't start or turn over. Nothing happens. What could be wrong
if it does nothing, check to be sure you have 120v power out of cord
push starter button do you hear a click/ if not micro swtch is bad
if you do than starter motor is bad
Jan 28, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Tecumseh 13hp overhead valve snowblower engine starts fine than sputters and dies, replaced the carb with new and exact same symptoms, Lots of fuel at the carb.
Make sure the fuel is good. Ethanol laced fuel starts to varnish after 20 days and is no good by 30 days, it also attracts water. Be sure you have good fresh fuel, then try a new spark plug.
Oct 19, 2012 | Tecumseh Lawn Boy Push Mowers Insight...
Bad switch on Electric Started
hello,if it is the one i think it is to where the push button is a closed unit with no screws as far as i know there is no repair for the push button switch,how ever there is a good how to on u tube repairing snowblower electric starters,from what i have seen the push button doesn't go bad,now if the push button comea apart you can repair it which useally the black box or circut thing that cost around $40.00 found on most s 200 blowers,hope this helps,,
Jan 23, 2012 | Garden
Yardman snowblower will not shift properly
you must been the arm back. look under your unit and check the drive rubber wheel. your are going to probably need to adjust the shift arm assay. make sure you lube all slide shafts. let me know
Oct 18, 2009 | Garden
Yamaha snowmobile starting issue
sounds like the starter is sticking!
Dec 09, 2008 | 2008 Yamaha XT 660 Z Tenere
Exercise & Fitness Logo
311 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
