My car s front wheel is out of ajustment had a accident top of wheel is setting to the inside at top of tire. what do i ajust
SOURCE: front end noise cavalier
hi, this sounds like track rod ends have gone this is for the steering and causes the tyre to where in one point these are cheap to buy and easy to fit but you will need to get the tracking set after replacing this part as it needs to be set to stop your tire wearing uneven the noise your getting will be from the tire on the road as it will be forcing the tire to run uneven so getting this checked would be my first choice.
Hope this is some help toy you let me know how you get on or if you have any questions ok
SOURCE: rear wheel alignment
first of all firestone are rip off artist. you got suckered. next there are struts on the back and yes you should align them however it has more to do with how the tire wears than a steering issue. with only 12,000 miles I seriously doubt there would have been a problem. my solution would have been if one of the front tires was bad i would have replaced it then took the 2 back tires and put them on front and the new tire and other front tire on the back and no alignment would have been needed unless your girlfriend would have complained about it tracking one way or the other. feel free to click on my user tab anytime you need help.... please rate this.........thanks
SOURCE: I have front end vibration
just checked this out a while ago:
Wheel Hub Assemblies: Systems and Diagnosis of Worn Hub Assemblies & Bearings
Front wheel hub assemblies and bearings control the position of, and reduce the resistance of, vehicle wheels in contact with the pavement. When they fail, front wheels may not be kept in position and vibration and noise usually develop. Symptoms that normally develop as a result of these worn parts include:
SOURCE: Growling/Roaring Noise Front End
sounds like a wheel bearing. typically when you take weight off bad bearing noise goes away. to replace bearing you will need a press to get it off and on
SOURCE: S430 Mercedes - Front end shaking at 55+
It sounds like you have either a broken steel belt in your tire or a worn out idler arm in your steering assembly. Other causes may be a bent wheel, a flat spot on the tire or worst case your brake rotor / wheel hub may be loose. If the rotor / wheel hub is loose you may have severly damaged wheel bearings. Good luck...
