Question about Cornea CT 1700 17" Flat Panel LCD Monitor
Cornea CT1700 monitor has no power.
I recently moved a PC from my wife's office to my son's bedroom. When reconnecting the monitor, I noticed the transformer light did not turn green. I changed power cords to make sure the outlet and power cord were working correctly. It appears the transformer is bad - does this sound correct and can I order another power supply for the monitor?
Thank you. Pat Bullinger
  • 51 Answers
I think that is not monitor problem, that is your computer (cpu) problem.plase chack your ram memory,open your cpu door and remove your ram and clean it with cloth and restore back.your problem will be solve thank you.
Posted on Dec 22, 2008
When I turn on my Cornea MP503 monitor on it has a message in a blue box saying Power Saving Mode and then goes blank and light flashes orange-green over and over.
Check the VGA/ DVI cable connection from your Monitor to PC, this also could be caused by VGA card on you PC that doesn't work properly, unfirmed connected to its slot etc, check also for unfirmed connected memory card/ RAM.
Dec 13, 2010 | Cornea MP 503 15 in. Flat Panel LCD...
Where can i find a power cord for a Cornea CT1700? I live in Greensboro, North Carolina
josdcabr, do you need only the cord or the "black-brick" switch-mode-power-supply" 12vdc @ 3.5 amps rating. You might try unitedsale. com in Valley Stream N. Y. 12fixlouie
Aug 10, 2010 | Cornea CT 1700 17" Flat Panel LCD Monitor
Cornea 1810 monitor power cord
Apparently the monitor's power consumption is near or slightly exceeds the specified value.
My suggestion would be to purchase an adapter with higher rated output current - if for example your original adapter was rated 12V 4.5A, go for a 12V 6A rated adapter. A 30% safety overhead will hopefully contribute to higher reliability.
Nov 18, 2009 | Cornea CT 1810 18.1" Flat Panel LCD...
Monitor Driver
Dear SANDY,
you can download the driver for your CT1700, from this URL:
http://www.avdeals.com/gvisionlcdmonitors/corneasystemslcd/ct1700.htm
be happy always
Regards
Jul 17, 2008 | Cornea CT 1700 17" Flat Panel LCD Monitor
My Cornea CT1702T flatscreen monitor does not turn on; and, I noticed there is no light on the power adapter. Is there a fuse in the power adapter? Do I need to buy a new power adapter; or, can it be...
it's a repairable. and there is no power adapter in monotor u just chek out monitor with bcabinet power cable if yr monitor light show on then just change yr power code it's cost just Rs. 40 to 50.... first do this way otherwise take yr monitor to repair or call yr system wander to chek powwer cable.
thanks for using fixya.
jo_chinmay
Apr 03, 2008 | Computers & Internet
Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Monitor not powering up
Try another monitor on that same pc, try your monitor on another pc. Next, check the data cable for any short.
May 08, 2007 | Cornea MP 704 17" Flat Panel LCD Monitor
Cornea Monitor Troubleshooting CT1700
it could be something as simple as your power settings in control panel> power options, then the first window called power schemes pops up and all monitor, harddisk and system standby should be set at never. Also check on you monitor menu for any power saving options and turn them off. If the monitors still turn off then there has to be a deeper fault with the monitors and not with the power options.
Apr 28, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
duplicate posting see below for solution http://www.fixya.com/support/t145139-cornea_monitor_troubleshooting_ct1700
Cornea CT 1700 17" Flat Panel LCD Monitor Logo
176 people viewed this question
Top Cornea Computers & Internet Experts
giarcnameloc
Level 1 Expert
Tom Chichester
Are you a Cornea Computer and Internet Expert? Answer questions, earn points and help others
