Question about Yakima Fat Cat 4 Ski and Snowboard Rack
Yakima ski rack lock core...locked and now will not unlock. tricks/hint?
3 Suggested Answers
Coachphil
  • 347 Answers
SOURCE: I have two different SKS cores. One for my
You have to replace the SKS cores you don't want with mates to the ones you do want.
I would suggest replacing the snowboard cores with ones that are the same # as your towers since then you are only replacing 2 cores instead of 4 and it is cheaper.
The key should have a number on it that tells you what core it goes too. You can either contact yakima and get the exact cores you need or go into your local dealer and see if they have them in stock or can order for you.
Posted on Dec 30, 2010
rockmeister
  • 2047 Answers
SOURCE: I have a Barrecrafters Sierra
Hello there, getting replacement keys for your ski rack is possible. Usually to get replacement keys all you have to do is visit your local distributor. Apparently the keys can be re-ordered from the manufacturers although the name of the manufacturers have been changed to proline products. here is the web address http://www.prolineracks.com maybe an order can be placed from there. Or you could get more information from calling their customer service and locating the nearest distributor to your location.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Aug 07, 2011
Hi I am looking at buying a barrecrafters sierra summit sx910 universal ski rack. It says fits most cars. Can't find a manual online and need to know if it will fit a 2016 highlander. Thanks!
Says it fits ANY car, but the Highlander is NOT a 'Sub Compact to Medium car', as it is a Crossover SUV. Buy a roof rack from Toyota, then the ski clips.
Barrecrafters Ski Rack
Model- SR-910+
-Hold four pairs of skis
-Covered locks(keeps from getting froze)
-Fully Assembled
-Removable attachment hooks fit any car
-Fits sub compact to medium cars
https://www.cstatic-images.com/car-pictures/xl/usc60tos141d021001.png
Dec 17, 2017 | Cars & Trucks
What does 26V means in a Yakima Vertical Mighty Mounts?
It is the size of mount to fit your crossbars. Go to Yakima website for particulars:
http://www.yakima.com/shop/rack-systems/factory-crossbars
Mar 05, 2015 | Yakima Winter Sports
Barrecrafter ski rack lost key
Lock Smith can do a Tap and File (Insert a Blank and rotate it and File to get the lands and grooves to get it done (Time Consuming) and Cost Extra Money
Try a Different Locksmith
Jan 25, 2014 | Winter Sports
How do I open Yakima Skybox Pro Cargo Box without the key
How can I open a Yakima without keys. I lost my keys..
Mar 12, 2012 | Yakima Skybox Pro Cargo Box
The locks work fine when there's no gear loaded, but when i put my boards onto the rack the locks won't turn. any suggestions?
sounds like a pressure issue ( binding problem ) --- when you go to lock the locks ( with the skis and/or snowboard on rack ) try and push down hard on the rack while you turn the locks,, this might get the pressure off enough to allow the lock cams to pass. if this does not work then the next thing to do is to file down and modify the lock cams so they turn easier without binding. if you do not have the tools to do this modification then you can always go down to your local locksmith shop ( with the skis/snowboard on the rack ) and have them do the modifications -- the shop will only charge you around 10 to 15 dollars for this service.
I hope this helps,
c...
Jan 25, 2011 | Yakima Fat Cat 6 Ski and Snowboard Rack
Bought a barrecrafter car rack off craisglist...i bought it with no keys because the ownr lost them...i need a replacement
look and see if there are any letters and numbers scribed on the face of the lock cylinder, this is the key code-- with this code you should be able to go to your local locksmith and they will be able to cut you a ' key by code ' and it will work. if there is no code on the lock then you can also just take the rack to the lockshop and they will be able to pick and remove the cylinder from the lock and fit a key to it by hand. normal shop rates for making a key in this fasion is about $12-$15 dollars and if you want more than one key - duplicate keys cost about $1.75 to $ 2.50.
(( even if the lock does have numbers on it -- take the rack to the shop with you to make sure the key that they cut by code works before you leave the shop,,, saving you a second trip ))
c...
Jan 05, 2011 | Barrecrafters /sportrack, Sx-12...
I have two different SKS cores. One for my snowboard rack and one for the Q towers on my Yakima roof rack. How do I set it up so I only have to use one key?
Dec 30, 2010 | Yakima Sks Lock Cores
Cracked cargo box (yakima)
good old duct tape... i would get some silicone caulking and run beads along the cracks in the box to seal the water out. not sure what colour that is but the caulking comes in many colours as well as clear.
Robert
please take a moment to rate this solution.. thanks
Feb 05, 2009 | Yakima Fat Cat 4 Ski and Snowboard Rack
Bike rack for 940 wagon
The mount on the rain gutters...Thule, Yakima, etc. Get locking feet...worth the extra money.
I think you can also get some for hanging off the tailgate...check with the companies online or in a local dealer.
Oct 27, 2008 | 1993 Volvo 940
Yakima Fat Cat 4 Ski and Snowboard Rack Logo
722 people viewed this question
Top Yakima Winter Sports Experts
Arnie Burke
Arnie Burke
Marvin
Marvin
vtrktrmn
Are you a Yakima Winter Sport Expert? Answer questions, earn points and help others
