Question about ASUS P4S533-VM (P4S533-VM/L) Motherboard
CPu fan turns for 1 second and then stops.
I have an ASUS P4S533-VM Board. I originally had a Celeron Socket 478 1.7GHZ Cpu on the board. i wanted to change and i put in a pentium 4 3.0GHZ Socket 478. When i started up pc, all that went was the cpu fan for a second and stops. The green led on the mobo stays on all time when power is in. I tried putting the old celeron back into no avail. Removed all peripherals except ram, still no good. Tried different PSU. Cleared CMOS, changed Ram configuration, kept ram out, done all, but still no booting sequence at all. Can anyone help me please?
  • 1 more comment
  • Niall Mulrine Apr 07, 2007
    No the PSU IS compatable with P4 as it works on another machine that was p4 chip with MSI board.
    I know when i first turned the pc on, i didnt have the cpu fan connected to power. I connected it up and then turned it on and that was the only thing that has moved, apart from the green light on the board.
    Can you fry a board by putting in a bigger P4 3 ghz, where it had a 1.7 ghz celeron
  • Niall Mulrine Apr 08, 2007
    Yeah have tried old CPU in again and the board is doing the same.. How would the cpu of fried.
    Thanks for all help that has been left and thanks to anyone in advance that will leave a soultion
  • Anonymous Nov 07, 2007
    i have celeron 1.7 on my p4s533 board and i want to upgrade to pentium 3.0 what will i do? the first time that i tried seems like the processor is not compatible.. pls help me
    President:
  • 2,961 Answers
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Posted on Apr 07, 2007
  • andrew pester
    andrew pester Apr 08, 2007
    You have probably fried the cpu, have you tried your old cpu in it again.
CPU Support
Go to your motherboard website and check it's CPU specificaions
May 25, 2010 | EliteGroup 661GX-M Motherboard
Can i use 2.8ghz cpu for my p4s533-e?
this is what asus says:
arrow-org.gif Latest P4 CPU Support
The latest P4S533-E motherboard supports Socket 478 Intel® P4 processors, which utilize the most advanced 0.13um process technology to provide frequencies up to 2.53GHz
Mar 23, 2010 | ASUS P4S533-E Motherboard
Asus motherboard a8v-vm jumper setting motherbord on but cpu fan not ON
You do not use a jumper to run the CPU fan. There will be a small 3 or 4 pin plug near the CPU mount and you can plug the wire from the fan into that plug only. If the one on the motherboard has 3 pins and your plug has 4, you can use it anyway; just be sure the slot on the back of the plug matches the side of the one on the board.
Oct 28, 2009 | ASUS A8V-VM Motherboard
I have p4 3.06 ghz processor on mother board it is written P5P800-vm/s i require VGA and sound drivers(realtek ac97 sound driver} i have i P5P800 VM motherboard and i was wondering if i can upgrade it's...
NO. you cannot install DUO to *********** board. the DUO is pinless and the P4 3.06 is pin type if you want to upgrade your PC you have to replace the mother board too.
May 18, 2009 | ASUS P5P800-VM Motherboard
Asus P5Q-VM CANT BOOT
CPU Should work with board.Try removing cpu and replace in socket check for bent pins if all is well..reinstall.make sure to use pad or silver paste and reinstall fan.rebootRichardm69
May 05, 2009 | ASUS Computers & Internet
ASUS P4S533 Motherboard 1.77GHz CPU does not boot with 1GB DDR400 RAM
Make sure you are using the supported memory type. Check the user guide. Also check if you have installed the latest BIOS firmware from ASUS.
Oct 30, 2008 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Cpu compatibility
Hi Buddy,
Thanks For The request.
Heres Your Information:-
http://safemanuals.com/user-guide-instructions-owner-manual/ASUS/P5RD1-VM-_E#
This Is English Version Of your Motherboard. Just Click The pdf file and download. Open with adobe acrobat Reader.
Compatable With Socket 775 CPU. Pentium D. Pentium 4.Or Intel Celeron Processors. Your CPU should be fine on this Motherboard, Providing It has the correct Pins. ( Socket 775 )
Hope this Answers your Question.
Mike @ compurepair.
Mar 15, 2008 | ASUS P5RD1-VM Motherboard
P5rd1 vm
The P5rd1 motherboard supports celeron's using a LGA775 socket. You can use a 2.0 celeron but you need to get the correct one such as:
Intel 440 Celeron 2.0ghz box cpu , 65nm conroe-L , Lga775 , 800mhz fsb - 64k L1+ 512k L2 cache
good luck!
Brad Nelson
Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Oct 03, 2007 | ASUS P5S800-VM Motherboard
ASUS P4S533-VM (P4S533-VM/L) Motherboard Logo
223 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
