Xincom XC-DPG602 Router
Problem for Xincom XC-DPG602 Router (XCDPG602)
How do I allow inbound traffic (run servers) behind NAT?
By Mini Me - usenet poster
Same Problem
Dec 26, 2007
-   I bought a Acer laptop. My wireless connections work with mostly all wireless service that I encounter. Except at home where I have the Parker Vision. It will not work with it. I do have another desk top that is wireless and it works fine with my Parker vision. I try to use the disk that came with my router but there needs to be internet connection for it to work. And the site seems to be down. I am thinking that I just need to adjust my wireless soft ware on my laptop. But I just seem to fail at every attempt.
I can be emailed at kcooper21@elp.rr.com-   Kcooper
Dec 03, 2007
-   I am trying to run a ventrilo server, the server info is saying that it's public but no one but myself can connect. I have very little computer knowledge with this kind of stuff, so step my step instructions would be very helpful. Thanks in advance.-   Guest
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Putty
Rank: Apprentice
Rating: 0%, 0 votes
To allow unsolicited inbound traffic (run servers) behind NAT you need to use port mapping/forwarding, which instructs the NAT device to pass all traffic on a certain port to a certain private IP on the LAN side. For example, to allow inbound web traffic you have to map port 80 to the IP address of the internal webserver. The downside of all that is you can only have a single internal IP receiving the inbound requests on a particular port... If you were to run a second server behind NAT, you'd need to use a different external port (the internal port can usually remain the same, this limitation only applies to the external port. You could map external port 8080 to internal port 80 on a second webserver behind NAT).
Another option is to use DMZ and open one host behind the NAT entirely for bi-directional traffic on all ports, although that poses some additional security risks.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jan 27, 2008
Somewhat Helpful)
tpvijay
Rank: Wiz
Rating: 85%, 40 votes
Was this helpful?
Yes
No
Solution #3
posted on Dec 08, 2007
Somewhat Helpful)
GRINGOMAN
Rank: Apprentice
Rating: 75%, 2 votes
HI U ARE USING YOUR IP 192.168.1.1 FOR GETTING INTO VENTRILO AND THATS CORRECT FOR UR IP ON YOUR SIDE OF THE ROUTER......EVERYONE TRYING TO GET INTO YOUR SERVER,MUST USE THERE IP (16.263.387.20 ) EXAMPLE.....U HAVE A PORT OF 8767 TRY OPENING 8768 ALSO SOMETHIMES THIS WORKS ...IF IM RIGHT,PEOPLE MUST COME IN UNREG TO JOIN..... GOOD LUCK.....
Was this helpful?
Yes
No
Popular Solutions for Xincom XC-DPG602 Router
Questions and Unsolved Problems for Xincom XC-DPG602 Router
Do you recommend Xincom XC-DPG602 Router (XCDPG602)?
Answer
Answer
The router power on and off when I connect the internet cable
Answer
I change the upd port in emule, close emule. I then forward that port in the 2wire 2701-G, restart... (More)
Answer
Hi! I can't open ports TCP/UDP to use eMule on my router. I fixed everything with firewall but my... (More)
Answer
dgffdfgf!-- SPpider-Layouts.com - CSS Linker - Generator - MEDIA BOX -->
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xincom XC-DPG602 Router:
Top Router Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
