Question about KitchenAid 32 in. KECC502 Electric Cooktop
Kitchen Aid kecc508gbl3 Cooktop - Flashing Controls. My touch controla are flashing and can't seem to stop or reset. Is there a reset switch or something else? Do I need new conrol board etc. Thank you. Neil
    Problem Solver:
  • 12 Answers
Held all off/on button for 5 seconds cleared the problem,
Posted on Dec 25, 2008
Tip
Fault Codes Kitchen Aid cooktop
F03 One or more eyes permanently pressed. Recommend that the glas be cleaned and all objects removed.<br /> Unplug the unit for one minute the plug back in if the error still remains after returning power then you will need to replace the touch control module.<br /> <br /> F12 Electronic board and touch module communication error.Unplug the unit for a couple of minutes.Restore the power if the error return then you will need to replace the board connection cable between the touch control module and electronic control. if the error remains replac ethe electronic control board. If the error comes back again replace the the touch pad.<br /> <br /> F13 Internal CPU checksum error.Recommend you replace the touch control module.<br /> <br /> F22 Key sensitivity problem.Turn power off to unit for a few minutes,if the error returns after power is restored replace the touch control module<br /> <br /> F36 Temperature probe hardware error.Recommend that you replace the touch control module.
on Jan 02, 2011 | KitchenAid 36 in. KECC568 Electric Cooktop
Power went out. reset circuit breaker and all the lights keep flashing 8.8 and won't stop
Hello Heidi, thank you for your post!
From my understanding your Electrolux cooktop is displaying an error code of 8.8. The error code of 8.8 means there is a shift register issue on the middle touch board. This could a possible issue with the control board or the middle touch board. You may need to have a professional technician out to your home for proper diagnosis. We hope this information is helpful to your repair. -Matt
Jan 23, 2016 | Electrolux 36"" Induction Cooktop
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Kitchen aid cooktop got wet wont ignight?
Usually Spark Switches might get shorted out or spark module went bad, but first unplug your stove and let it sit for a while (1-2 days) then try it again, if still nothing, then You will need to open up stove to check. Here is the video I made. Screws would not come off, so i had to replace almost all components on it. Hope It Helps.
May 28, 2014 | KitchenAid KFGU766VSS Cooktop
Replacement Griddle for Kitchen aid KGCP463KSS
If Kitchen Aid is of no help, try an appliance parts supplier
Apr 21, 2013 | KitchenAid 36 in. Architect KGCP463KSS Gas...
Gas igniter does not stop spark
Most likely some water got under the top near the knob shafts while cleaning or something boiled over. Despite the cause, the switch or switches are shorting out and we're talking 120 volts so it could be dangerous. Unplug the power cord under the counter and let it all dry for a day or 2, you could speed that up with a hairdryer but the burners will still light with a match so why rush it?  Good luck and don't use so much water when cleaning.
Jan 08, 2010 | KitchenAid 38 in. KGCS166GSS Gas Cooktop
The cook top display control lock ? i need to unlock the controls
To Unlock Cooktop: Touch and hold CONTROL LOCK for
5 seconds.
Jan 11, 2009 | Jenn-Air JED8430 Electric Cooktop
KitchenAid 32 in. KECC502 Electric Cooktop Logo
693 people viewed this question
Top KitchenAid Cooktops Experts
vince
Dale Copeland
Dale Copeland
davenpdx
Are you a KitchenAid Cooktop Expert? Answer questions, earn points and help others
