Zenith D32D51 32" TV Logo
Charley Norton Posted on Apr 07, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Color tint went out
Hi, I have a Zenith D32D51 and the color tint on it went bad the other day. The only way to see any picture is to place the contrast and brightness to maximum. I was wondering if anyone knew what was going on with it and about how much it should cost to fix. Thanks for the help.
Henry Thomas
Level 3:
Genius:
  • Master 1,074 Answers
  • Posted on Apr 07, 2007
Henry  Thomas
Master
Level 3:
Genius:
Answers
1074
Questions
Helped
336397
Points
2402
Replace the color ic have tech do that. checks should be made around the same ic for transistor leakage
VERTICAL LINES ON OLDER ZENITH FLOOR MODEL TV
this was adjusted by the fine tune on the selector It is the picture not being held in place by being out of tune Same as if the picture goes sideways On the real old units there were 2 knobs to make these adjustments.
Green tint on picture. Cant adjust with tint or color from menu
My rear projection was doing the same thing. I have a mitsubishi and went into the video/audio set up. When I clicked on video it brought up brightness, tint, color, etc... Not sure if yours is set up the same.
3helpful
2answers
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Can someone take a picture of the original video settings on their Zenith B25A24Z 25'' TV because my screen is all messed up and doesnt get much better when i play with settings.
If this TV is a 25"...then this is an older set. Is the picture dim and the colors dim, will the tint not correct the color scheme? Zenith picture tubes, as a rule, for this model go bad...sorry but this is true!
TV Turns green and shuts off and less than 5 seconds.
In that TV its usually a bad picture tube. The green element of the tube is shorting.
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Zenith TV- greenish color
If you take off the back of the TV there are additional tuning buttons. One is for the focus. I have a model SY2551S and have the green tint problem. Have you resolved that?
Problem with the color on my Zenith
picture tube need a picture tube reguvinator $1300
4answers
Color mostly green
Sounds like tyo me that the picture tube is getting soft on ya!!. Its a common factor that occours with all tvs but mostly with zenith. A service tech might be able for a small fee rejuvinate the picture tube but theres never a warrantee with this type repair. Its not something a user should attemp to do as theres hi voltage inside this set even on the tube socket after its ubplugged for awhile. Seek the advise of a repair pro to see how bad the tube is. Good Luck
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
