Question about Sony KP-57HW40 57" Rear Projection Television
Green flashes Our tv will work fine fo 20 to30 min, and then has green flashes on the screen and shuts off.
    President:
  • 1,284 Answers
It is a defective green CRT and most likely the red and blue will need to be replaced as well. This was a known issues with this year of Sony projection TV's.
Posted on Apr 07, 2007
Flashing green light
I have a mits. 82738 tv which would shut off after 20 minutes when first turned on .
Loose sound and picture.
Looked up error code in service manual and it said the lap was the problem.
Replaced lamp and now it works fine and the picture quality is great.
Jan 20, 2014 | Mitsubishi WD-82738 DLP TV
Green Screen/Shut off
Turn off tv for few hours and then turn on..
Aug 28, 2008 | Insignia IS 20" TV040919 TV
Turn tv on watch it for 20 mins. screen shuts off but green power light is still on. turn it off manualy wait a few mins. turn back on watch for anouther 20 mins or so then screen shuts off again
The reasion your set is shutting off is because the power supply is dieding, and you need to replace the electrolytic caps on the power supply, or purchase a new one, go to www.partstore.com sand check to see if they have your power supply.
Aug 17, 2011 | LG 50PX5D 50 in. Plasma HDTV
Red, Blue, Green white flashing screen
https://www.bleepingcomputer.com/download/windows-repair-all-in-one/
Dec 04, 2017 | Acer AL2016W 20" LCD Monitor
The tv was working fine the other day. I turned it out today and the screen just stays black. If I press the channel button up or down the channels change and sound comes out. The audio works fine, but the...
Turn it off/on a few times within a few mins each times.U get a flashes of picture about 10 to 20 sec?Than ur LCD inverter board is dead.Tries Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It usally a long PC board in shape.
Apr 16, 2010 | Polaroid FLM-3232 Television
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Green picture
a green screen on power up with retrace lines. At shut down a point appears in the middle of the screen. Sounds like either a shorted G2 grid, or bad flyback. If a phospher flake has shorted the grid in the tube, you can sometimes have luck by using a megger set at 1000VDC, to burn away the short. This is usually caused by the line HV going too high causing the anti-UV protection to kick in so fit a dummy load 40W lamp instead to the line output to allow measurements to be made.
Oct 19, 2008 | RCA 20F512T 20" TV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KP-57HW40 57" Rear Projection Television Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
