Question about KitchenAid Kitchen Ranges
Kitchenaid wall-oven model XJ4401013
How to replace Kitchenaid wall oven temperature sensor?
    President:
  • KitchenAid Master
  • 2,651 Answers
Easy enough, 2 screws hold it in, its in the upper left corner of interior of unit, pulll easy and the wires should come out far enougth to access the plug, if not youll need to get behind the unit and removethe back panel.
Posted on Dec 22, 2008
KEMS308SSS KitchenAid Wall oven - Error F3E0 - Sensor seems OK
The RTD could be in spec at room temperature but failing under load
May 21, 2013 | KitchenAid Architect® KEMS308SSS Stainless...
KitchenAid Electric Range KERS807 Oven won't do anything, flashes S3E3 code
Do you mean an F3-E3 code? I've never seen a KitchenAid S3 code.
The F3 code means that the oven temperature sensor is bad. The E3 indicates that the sensor indicated an excessively high temp during the clean cycle.
Please determine the full model number of your range to ensure that you get the correct sensor. The sensor costs between $75-80, depending on the vendor. I used the KERS807SSS02 for a guide. www.searspartsdirect.com and http://www.appliancepartspros.com both have the sensor in stock.
If the range is still under warranty, contact KitchenAid for the repair.
I hope this helps.
Apr 30, 2012 | Kitchen Ranges
KitchenAid Superba Gas Range error code F3 E0 when trying to strat the range
The F3 E0 means
Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse Good luck
Nov 27, 2010 | KitchenAid Kitchen Ranges
F-2
F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Nov 21, 2010 | KitchenAid Ovens
Kitchenaid DF Range F04 error code
I have a dual fuel kitchenaid convection range and I put it in self cleaning mode last night. Afterwards it said F 04 on the display. The doors open again, but neither of the ovens work
Nov 17, 2009 | KitchenAid KDRP487MSS Dual Fuel (Electric...
Kitchenaid oven says Error code F3E0, oven sensor-upper what'sup
It means the sensor that lets the thermostat know what the temperature of the oven is has failed. You need a new sensor.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes.
From KitchenAid themselves
F3 E0
Get one from the people in the first video. Very easy fix.
https://www.youtube.com/watch?v=VZKHpduF9RI
kitchenaid oven temperature sensor replacement Google Search
Sep 17, 2009 | KitchenAid Ovens
How do I replace the oven temperature sensor/thermal fuse in my Kitchaid oven?
Unplug the range.
Open the oven and look on the top left back wall of the oven to see the sensor protruding out. Unscrew the 2 screws holding the sensor and CAREFULLY pull it out.
Unplug the wire connector. Plug in the new sensor and CAREFULLY push the wires back inside.
Replace the screws.
Turn on the oven and bake me some cookies.
Apr 01, 2009 | KitchenAid KESC307 Electric Kitchen Range
OVEN will not heat
KitchenAid KEBC107KSS does not heat hot enough and does not heat evenly. When the temperature is dialed higher, it burns the cookies. When the convection fan is on, it has a 'cooling effect' so the temperature never reaches the proper level. Is this problem repairable? Or is this a thermostat issue? Thank you for your help!
Feb 24, 2008 | KitchenAid KEBC107 Electric Single Oven
Kitchen Ranges Logo
109 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
