Question about Refrigerators
I HAVE A ROPER RS22CFXTQ00 SIDE BY SIDE REFRIGERATOR. HOW DO I CHANGE THE WATER/ICE FILTER? THANK YOU.
catriver
  • 878 Answers
SOURCE: water always inside refrigerator sometimes ice forms
LadyBlues, This is a top mount freezer. What's happening is that the drain in the freezer area is frozen over. When the unit goes into defrost, the water is running into the refrigerator area instead of going down the drain hole. You will have to remove the freezer bottom panel and then the freezer rear panel to unclog the drain hole. It will be under the evaporator in the drain tray. Use some nice hot water from the microwave and pour it into the tray until the water flows down the drain tube. This should clear up your problem. Catriver.
Posted on Jul 12, 2007
  • 100 Answers
Sounds like you might have a condensation problem. Is the fan in your freezer working? If not it's not circulating the cold air. If it is you might have frost on the lower rear wall of your freezer meaning its not defrosting like it should and restricting your air flow. Last but not least you have a damper door in the upper left corner of your fridge that allows the cold air from your freezer into the fridge to cool it, that might not be opening up. Any one of these things would cause your water problem and a warm fridge section
Posted on Dec 05, 2007
22yooper
  • 828 Answers
SOURCE: Maytag refrigerator Model MZ02766GEW does not dispense water
In the water supply line to the refrigerator is normally a saddle type valve where the water supply is connected to your house water line. Trace it back and shut the valve off fully then turn it back on. When some work is done to any part of your household water system sediment may have lodged in the saddle valve causing a restriction. Closing the saddle valve and reopening it may dislodge the restriction.
Posted on Dec 02, 2008
  • 111 Answers
SOURCE: Ice maker does not work
Turn the icemaker off for 15-20 seconds at the rocker switch on the side of the icemaker body (square white box)Turn switch back on and immediately press the feeler arm (white paddle) in and out three time. This should start a test cycle. If still no water after it runs through a test harvest cycle (will take about 4-5 minutes), remove the icemaker and look at the ring finger size plastic tube that allows water flow into the icemaker. It is probably full of ice (because of a plugged filter or some other water supply interruption -possibly while you were changing the filter). If the tube is iced up warm it up gently with a hair dryer being extra careful not to get drops of water in the hair dryer nozzle. Do NOT use too high of a heat setting as that tube will melt... complicating things unnecessarily
Posted on Dec 19, 2008
  • 37 Answers
SOURCE: no ice or water supply for samsung side by side refrigerator
When you replaced the filter, did someone turn off the water inside the fridge where the filter is?
Try taking out the filter and putting the plug in and see if it works then.
Posted on Jul 13, 2009
After changing water filter on side by side roper refrigerator the outside water won't come out. The ice works but not the water
Did u hold paddle down to let water flow long enough. It takes a few minutes to get air out if line and for filter to fill b
Sep 04, 2017 | Roper Refrigerators
I have a roper side by side with ice and water despenser. after getting a glass of water and ice i find white particles floating around the bottom. I've never changed the filter and am not sure where...
hi Adam,
The knob you speak of is the filter location. Take that off, remove the filter, and replace with a new one, that should solve the trouble, you can probably get a new one online or thru Lowes or Home Depot, or any place that has this style machine for sale, i.e. Sears.
Hope this is of help. Please rate and comment, Thank You
Joe
Sep 01, 2011 | Roper RS25AEXLQ Side by Side Refrigerator
I have a Roper RS22CFXTQ00 side by side. It leaks water in the floor. Water gathers under bottom drawer in freezer then leaks into the floor. I also have a problem with the hose that feeds water to the...
first check for a hole that water should drain tru. it must drain under the ref. into a pan and then it is evaporated by the heat.. u need to go on the back of ref.,. look where water goes into the freezer and that will need to put some putty or soke tape to stop the air leak that is causing your spout to freeze.. try those. ok
Feb 11, 2011 | Roper Refrigerators
I replaced the water filter in my Whirlpool/Roper side-by-side refrigerator. Now ice maker and purified water (on front of door) don't work. No water is getting to the ice maker. Is it a defective water...
1.CAN YOU TELL IF WATER IS GOING TO THE FILTER, FIRST OF ALL.
2.IF WATER IS NOT GOING THREW THEN THERE IS A BLOCKAGE BEFOR THE FILTER
3. IF WATER IS GOING TO THE FILTER { CHECK TO IF THE FILTER IS IN CORRECTLY}
4.IS THE WATER GOING THREW THE FILTER, IF SO THERE IS A PROBLEM WITH THE KINE FROM THE FILTER TO THE LEVER TOR THE WATER TO COME OUT.
5. ALSO CHECK FOR LEAKS GOOD LUCK
Jun 23, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
No ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Jan 11, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Icemaker stopped working. There is water to the refrigerator (is water to drink) but does not fill icemaker. Thanks, Gene
I changed the water inlet valve on the fridge. It still doesnt send water to the ice maker, but continues to send water to the door, so what do i do now?
Oct 15, 2010 | Roper RS22AQXKQ Side by Side Refrigerator
Bad tasting water
Do not use a steel or plastic braided supply line. They make the ice taste bad.
Dec 29, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker not working
Are you sure you have the RIGHT Filter cartridge? If so, does your system have a water dispenser and if so.. is that working? If not.. some but not all ice makers have a test button under the removable service cover.. If your has that..press it and it should fill your ice tray directly after that.. If it doesn't then.. are you sure you have water back on to the system? can you reinstall the old filiter as a quick test to see if that's the problem?.. Thru a few ideas at you and hope one of them will get you going with ice.. BTW.. some systems take a pretty long time to cycle thru ( fill the air cavities with water , before they show any sign of life..meaning ice cubes)
Hope that helps !
Aug 18, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerators Logo
154 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
