Question about E-Machines eMachines Desktop PC
Mitsubishi tv volume on tv not working
Turned on tv today the picture is beautiful there is no volume. The tv has a popping noise when I turn it on. What could be the problem? It is over 12yrs old
  • mpm45 Dec 29, 2008
    We call the cable company that installed the cable connected to the tv he suggested to unplug the electrical socket wait ten seconds plug it back to the electrical plug that fixed the problem with not having volume .
    Thanks for your help
    mpm45
  • 585 Answers
If the TV has stereo sound, there may be a speaker switch for internal/external speakers on the rear of the TV that may have gotten bumped by something. (kids, pets, something fell behind?) If no switch, the sound driver chip or speaker may be failed. If the speaker is the culprit, headphones would still work if there is a jack for headphones. Might be a good time to consider a new HDTV
Posted on Dec 24, 2008
What might be the problem with tv making popping noise when turned on
you must have a wire ( sound plug ) not connect properly ,
sometime those plug loose with time ,
when powered the make connection and those sound happen !
Apr 05, 2015 | RCA L32HD31 32 in. LCD HDTV
No sound on TV
Don't know the exact model you have, but generally when the capacitors are replaced, many CABLES ARE UNPLUGGED and RE-PLUGGED in the process, including the speakers. Have someone check the speaker connections. Also be sure the tv is not in "mute" mode or the volume is not set to zero.
May 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
TV problem - Mitsubishi wd-62327 62
If the lamp is bad, you will hear a buzz noise as it tries to fire up the lamp. If you let it try enough it will spit out the error message. You can pop the speaker grille off and gain access to the lamp door. Use a philips screwdriver to get in. The lamp will be shattered or damaged looking if bad. If you have a good lamp, you may have 2 bad capacitors on the power board (3300uf). They will be bulged on the top and not flat. It is difficult to disassemble this tv.
Dec 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sound no picture
Try resoldering the vertical output IC this is acommon problem with this model
Mar 20, 2008 | Mitsubishi VS-5043 50" Rear Projection...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Nothing happings
jen, Please verify Model # and mo / yr off the label on the back of your new set.................................T.
Nov 23, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Snap crackle pop
Check the Flyback, had same problem, replaced it and the unit worked good.
Oct 15, 2006 | RCA P46921 46" Rear Projection Television
E-Machines eMachines Desktop PC Logo
179 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
