Question about Bionaire BAP1500-U Air Purifier
Red Light indicator on
I have two Bonaire's with HEPA filters, both about 3 to 4 months old and about a week ago the red light indicator by the squiggly lines on the filter came on. I turned them off, cleaned the filters but they are still red. Of course, I can't find my book that came with either one, so any info you can provide would be greatly appreciated. Thanks, Anita
  • 1 more comment
  • Anonymous Apr 07, 2008
    i have the pufifiier for about a couple of months and i have cleaned the filter and the red light continues to stay on. whats wrong with the purifier
  • Anonymous Apr 08, 2008
    Same problem with red light staying on after cleaning and installing new filters. I do not have a reset button, but I noticed a small black dot under the indicator lights. I stuck a sharp pencil into the hole, holding for 10 seconds and sure enough the green light came on.
  • floydirith Jul 29, 2008
    I am wondering the best way to clean my permatech filter.Any ideas? Thanks floyd
I have a Bionaire tower air filter model BAP1700 that I bought from Costco. The filter check LED came on recently after 5 months of use. After cleaning the Permatech filters, I tried every remedy on this website including following the instructions that say push power button for 2 secs. Nothing worked. Then I noticed a tiny hole on the control panel in front of clean filter LED; I pushed a paper clip pin into that hole, felt a click, held it down and 2 secs later, LED went out. Success!
Posted on Mar 28, 2008
Its easy to fix, just turn it on, and hold the power button down for like 7 seconds or untill it goes away!
Posted on Apr 25, 2009
  • Gman Rhoads
    Gman Rhoads Nov 19, 2017
    Best Answer Here! Thank you!
I have a BAP1500 and held the power down while pressing each other button and that did nothing, but I continued holding the power button maybe 10 seconds then the red light flashed a few times then went out.
Posted on Jul 11, 2007
  • 944 Answers
Bionaire unfortunately do not provide a manual online for the bap1500u - you should be able to get one direct from; http://www.bionaire.com/contactUs.aspx The red light definitely is indicating that filters need cleaning, and on most models, this needs to be reset after cleaning. The 1500 definitely has a manual reset feature, sorry i cant find exact details on how to do it. some have a simple "reset" button, others may need only unplugging from the power for 15 minutes, while some may need a combination of buttons pressed - you should try all possible combinations, press and hold the power button for a few seconds may do the trick etc. Here you can get the manual for the BAP1175/1300 under "product details"; http://www.amazon.com/Bionaire-BAP1175-Quietech-HEPA-Cleaner/dp/B00005JHQE For these models you simultaneously press the "sleep" and "power" buttons to reset - these models are dissimilar, but just possibly the reset is the same. Hope this helps :)
Posted on Apr 20, 2007
    New Friend:
Thanks for the help I have this problem
Posted on Nov 03, 2016
For Bionaire BAP1500, press POWER for 2 seconds to reset the red indicator light
Posted on Apr 29, 2007
Constant red light
it may need a clean as there is a air flow sensor, if the flow is not right then it will have this on also a faulty sensor will read this aswell.
Mar 24, 2014 | Hoover AH60015 Air Purifier Replacement...
How do we change filters on a HAP8650 air purifier?
"After replacing the HEPA filters, RESET the Filter Life Monitor by inserting a small object (such as a pin or paper clip) into the hole below the red filter change light marked RESET and holding it down for 2-3 seconds." This came straight out of the Owner's Guide. Hope it helps!
Sep 13, 2012 | Holmes HAP8650 - HEPA Allergen Remover for...
I had a honeywell hepa air purifier 50250 given to me as a gift with no owners manual! Is there somewhere I can get one? also, there is buttons on the top, one saying check filter and the other saying pre...
http://www.honeywellpurifiers.com/ssi/pdf/honeywell/50100-200-300-manual.pdf
The Intelli-Check™ Filter Monitors will indicate replacement of the pre-filter and the
HEPA filter. Depending upon your individual usage (environment and hours used),
you may need to check and replace the filters more or less frequently.
To check Expected Filter Life Usage
When the unit is turned on, quickly press the appropriate filter monitor button. The
pre-filter light will flash up to 3 times and the HEPA filter light will flash up to 4 times,
depending upon how much expected filter life has been used.
PREFILTER:
1 flash = from new, up to 1/3 expected life used up
2 flashes = between 1/3 and 2/3 expected life used up
3 flashes = between 2/3 and all of expected life used up
Remains on = time to check/replace pre-filter
HEPA FILTER:
1 flash = from new, up to 1/4 expected life used up
2 flashes = between 1/4 and 1/2 expected life used up
3 flashes = between 1/2 and 3/4 expected life used up
4 flashes = between 3/4 and all of expected life used up
Remains on = time to check/replace HEPA filter
To RESET Filter Monitor
When the filter monitor light remains on, it is time to check/replace the filter and reset
the filter monitor, if needed. With the unit powered on, press and hold the appropriate
filter monitor button down for approximately 5 seconds until the light turns off.
Page 6:
Mar 29, 2011 | Kaz Honeywell Hepa Air Cleaner (50250) Air...
Turn off reset button
IF RESET DOES NOT WORK DON'T WORRY
AS LONG AS YOU REMEMBER TO CHANGE
THE FILTER. CHARCOAL WHEN DIRTY AND
HEPA ONCE A YEAR OR SO.
Mar 19, 2009 | Whirlpool Whispure (45030) Air Purifier
Red light won't go off
To RESET the Electronic Filter Check:
When the filter check light remains on,it is time to check/clean the HEPA-Type
filters and reset the filter check,if needed. With the unit powered on,insert the tip of a ball-point pen or
paperclip into the hole next to the LED filter check light and hold for approximately 5 seconds until the
light turns off (Fig 5). Depending upon your individual usage (environment and hours used),you may need
to check and clean the filters more or less frequently. If the HEPA-Type filters are cleaned before the filter
check light turns on,the filter check should be reset at the same time.
These cleaning intervals are intended as guidelines only. Performance of any filter media is dependent
upon the concentration of contaminates going through the system. High concentrations of contaminates
such as dust,pet dander and smoking will reduce the useful performance of the filter.
NOTE:The HEPA-Type filters are not washable.
Fig.5
May 24, 2008 | Honeywell HHT-090 Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Red filter indicator light
    Hi Linda - there is a "reset" hole - you have to stick a pin or a paper clip in the hole when you change the HEPA filter - I just found this out myself! It does work. Mine didn't work right away, but it did end up resetting and went back to green after a few moments. I think this happened to me last time. The filters are really expensive, but you can get them at Walmart. If you need more information, email me at marixyz@aol.com and I'll tell you what model filter, etc.
    Nov 05, 2007 | GE HEPA 106653 Air Purifier
    Hepa filter
    The red light indicates a plugged filter. Replace the filters plug the machine in and get a paper clip. Streighten out the clip and put it through the tiny hole in the top. You'll feel it push a switch that will give a click you can feel. Keep holding the clip wire down for several seconds. When the red flashes remove the clip wire. The light will stay off if the filter is clean.
    Aug 22, 2007 | Holmes Products HAP422-UC Air Purifier
    Red Light on front of Filter Queen Defender
    When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
    Mar 06, 2007 | Filter Queen Defender Air Purifier
    Replace Filter Indicator Will Not Turn Off
    I owned the previous model of the same unit with the hole for the paperclip. But it wore out and I replaced it with the HAP422 and found the same issue; no hole to "reset" the light. I was just fooling with it and determined that "some" switch would reset it and finally held the power on button on for a few seconds, after which, the red light flashed and then went out. Problem solved. BUT THERE IS NOT ONE WORD IN THE MANUAL TO TELL YOU THIS! WHY NOT?
    Dec 18, 2006 | Holmes Products HAP422G-U Air Purifier
    Bionaire BAP1500-U Air Purifier Logo
    4,017 people viewed this question
    Top Bionaire Air Purifiers Experts
    Jay Finke
    Jay Finke
    Naveen Sistla
    Naveen Sistla
    Tom Chichester
    Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
