Question about Nikon N75 35mm SLR Camera
HP Pavilion a1000 won't power up
We had a brown out with our electricty. Since then my HP Pavilion a1000 desktop won't turn on. Is this probably becasue the brown out fried the power supply?
    Problem Solver:
  • 17 Answers
Usually the brown outs fries the mother board when the power supply fries on these computers
Posted on Mar 07, 2009
HP Pavilion a 1250n won't turn on. Green light is on under the plug in the back but noghting else.
If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Sep 22, 2012 | HP Pavilion a1250n (EG194AA) PC Desktop
Please try the following:
1.remove the power cable an plug it again
2.check is the power it's on at the back of the source.
3.if you hear some noises write them down and search for the error codes on the net.
Hp pavilion a705w - blue power light flashing, won't turn on
On the back of the power supply there is a 120/220 V AC selector switch.
It's possible that switch got knock on the wrong voltage position.
Pull the power cable. Move the switch back and forth between the two position.
Make sure you leave the switch in the correct selection. 120v = USA
If you have time,open the case and inspect the RAM module(s) and card(s). They can be un-sitted.
plug in power cord and power on the pc.
Jul 29, 2011 | HP Pavilion a705w PC Desktop
Hp pavilion a1217n tower won't power up...the green light in the back is blinking rapidly....help!
it could be 3 things eigther the hard drive failed or power supply went out or mother board went bad you can take it to a reputable computer repair store and they will check these for free
Jul 08, 2011 | HP Pavilion a1217n Desktop PC
Suddenly my hp pavilion a1217n tower won't turn on...the green light is blinking rapidly...
are you referring to the light on the back? if so the power supply has most likely failed, mother board can also cause this issue.
Hp pavilion a820n comp won,t turn on . rear power light blinking , turned all power off several times waited long intervals before repowering unplug all plugs and tried still no power up found when mother...
make sure nothing is plugged in to your front card readers slots:
If so PC will not boot. Other then that can you put a different power supply in it? Just to see if it is the Power supply..
Jul 26, 2010 | HP Pavilion A820n (PP165AA) PC Desktop
Jumper settings
If you try to enter in safe mode or at last known config and the laptop reboots or freezes then you need to reinstall the operating system if you want to use that hard drive on hp pavilion a1000n. The laptops have different chipset and XP requires to be the same or similar chipset to boot properly.
Oct 06, 2009 | Maxtor Hard Drive
My HP media center edition m7330n desktop will not power up (won`t stay on), The power button light flashes every 2 seconds from blue to orange & no power at usb ports. Any advise on what went bad or...
Before doing anything try to get the following tested,Processor,Power supply,Memory,also remove any cards installed including modem.Look for physical damage(ie) Brown substance coming from capacitors on board all capacitors should be flat on top if they show rounding or a hump over the top the MotherBoard needs rplacing!
Aug 08, 2009 | HP Pavilion Media Center TV m7330n...
Nikon N75 35mm SLR Camera Logo
494 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
