Question about HP Photosmart R707 Digital Camera
MY DIGITAL CAMERA KEEPS SAYING CHARGING FLASH EVEN WHEN BATTERIES ARE FULLY CHARGED AND PLACED IN THE CAMERA
  • 1 more comment
  • stephan886 Jan 04, 2009
    Have the same problem. No solutions on the HP site either. Upgraded today to the latest version firmware but still have the same problem
  • Anonymous Jan 07, 2009
    Exactly the same problem.
  • startop99 May 19, 2009
    I have the same problem. Tried the reset, replaced the battery, use the camera with out the SD card and the R707 would not charge the flash.
    Please help.....
  • 43 Answers
Remove the battery and push the reset switch for about 5 seconds. Reinsert the battery.
Posted on Jan 29, 2010
Red light display with SB
The flashing red light indicates that the camera's flash is charging.
Your electronic flash does not work on the low voltage supplied by the camera's battery. Instead, the battery is used to charge a capacitor(s) that are connected in a manner that raises the voltage to a level that will fire the flash. If the batteries are not adequately charged or the capacitor(s) are leaking, which will occur as they age, enough voltage will not be stored to allow the flash to fire.
Make sure your batteries are fully charged. Remember, rechargeable batteries do go bad after time and must periodically be replaced.
If the battery is fully charged and the red light continues to flash, the camera will need to be sent in for repair (probably replacement of the capacitor(s)). Call the Nikon Service Center at 1-800-645-6687 9AM-8PM EST, Monday to Friday, and they can arrange for you to have your camera evaluated and provide you with an estimate without cost. Your camera is rather old and it is possible that it might make more sense to replace it with a new model.
Feb 10, 2015 | Nikon Coolpix 5700 Digital Camera
I just bought a canon powershot sx120 is today. I can't get the flash to work. I lift the flash and once in about 20 tried it goes off but other then that it won't even take photos if the flash is up.
If the flash is on AUTO it will only fire if it needs to, such as in dim lighting.
Try putting the flash to ON mode and see what it does.
More likely this is a power problem.
It needs fully charged batteries to fire off the flash very well. If it "won't even take photo's" as you said that usually means there is not enough battery power to charge up the flash, so the whole camera is stuck until it gets done charging the flash.
This issue could be from using Alkaline batteries, they are not very strong and can't keep up with the power needs of a camera.
So if you haven't yet -- try some fully charged NiMH rechargeable AA batteries and it will probably run fine.
Aug 12, 2010 | Canon Cameras
HP Digital Camera R717 Charging Flash Error
Try to run self-diagnostics test - press flash button while switching the camera on. One of them tests the flash functionality.
Nov 29, 2009 | HP Photosmart R717 Digital Camera
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
Battery is fully charged but when I push button to take a
Camera takes pictures with flash off. With flash on message comes up and says flash charging and camera freezes unable to turn off I have to take the battery out
Jul 12, 2009 | HP Photosmart R707 Digital Camera
Takes a long time to focus / take a picture
According to your description, I would like to assume that your camera takes 9 seconds to get the flash ready, not to focus. If it is the focus problem, you need to send the camera for realignment or to replace the lens.
Here is my suggestion:
Try to disable the flash. Does it still take 9 seconds to take picture? If the answer is ‘no’, then try to use fully charged batteries or new batteries to reduce the flash charging time.
If you have a ‘batteries drain quickly’ issue as well, this tip may help: Why my camera keeps saying ‘change battery’ even with new batteries?
Jul 01, 2009 | Canon PowerShot S5 IS Digital Camera
When putting in new batteries the "change battery" sign comes on
try new Alkaline batteries or fully charged NiMH batteries, you may need to clean and adjust the springs in the battery compartment
this tips may give you more details
http://www.myfixtips.com/blog/digital-camera/why-my-camera-keeps-saying-%e2%80%98change-battery%e2%80%99-even-with-new-batteries-176.htm
May 14, 2009 | Canon PowerShot A520 Digital Camera
When ever i take a picture, the orange light turns on acting like its going to take a picutre but it doesnt. When i take it off flash, it takes the picture.
The orange light blinking means the flash is charging, once the light goes off you can go ahead take picture with flash. Your light keeps blinking because the flash is not ready.
Try with fully charged batteries. If it won’t work, you may have an open fuse or something wrong with the flash circuit.
Apr 05, 2009 | Canon PowerShot A550 Digital Camera
Hp r927
Sounds like blown flash bulb.
Needs to be replaced.
Mar 19, 2009 | HP Photosmart 735 Digital Camera
*istD pop-up flash problem
Not sure if you try fresh Alkaline battery. Try it if you havn't already. Fully charged batteries, how do you know it fully charged? The "charger said so"? Your batteries or charger might give you a fault peak reading. Try fresh battery or AC adepter and go from there.
Sep 08, 2005 | Pentax *ist D Digital Camera
HP Photosmart R707 Digital Camera Logo
324 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
