Question about GE GSL25JFPBS Side by Side Refrigerator
Water dispensing very slowly - gss25wgta
Ice machine works, but the water dispenses water very slowly. I saw some posts for a different model, and am not sure if it applies to my model. Also, I read the recommendations for using a hair dryer, but need to know where to apply the heat.
Thanks to all.
  • 700 Answers
You apply the heat at the water resevour at the back of the refrigerator. remove the drawers and you will see it . It has two plastic tubes that run to it.
Posted on Dec 22, 2008
Ice maker not dispensing
This is possibly only a defective micro-switch on the Dispenser Module. Can you post the model number so I can examine the correct parts?
I am here should you need me, Thanks John Tripp Appliance 911
Contact Me Here
Mar 16, 2014 | Refrigerators
I have an Amanda double Door refrigerator with an ice & water dispenser. The ice machine unit's dose not dispense ice cubes,
If the unit is making ice and the water will work from the door but the does not dispense, you will need to replace the "auger motor". Here is the part to order.
Nov 28, 2012 | Amana 22 cu.ft. Side-By-Side Cabinet Depth...
Decreased water flow from dispenser GE GSS25WGTA refrigerator
This is usually caused by the water inlet valve not opening all the way or it got clogged up. The valve assembly will need to be replaced, don;t try cleaning it out it will likely cause a clog further up the tube. They are usually pretty inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/referwaterinlet.html
Jun 23, 2010 | GE Refrigerators
Water dispenser does not work, ice maker does work. This is a used Whirlpool side by side. I hooked up the water yesterday and the water dispenser worked. Overnight, something went awry and I do not get...
Icemaker is in line with the water and runs from the icemaker threw the door and up to the water valve. So that is why the ice maker is working and the water is not working, most likely the water has frozen inside, And this can be caused by many different reasons, if it has been humid or the door was left open then shut it would cause the moisture in the air to be drawn to the warm water and flash frosted the pipe, try to see if you can defrost the line with a hair dryer. If that does not work post here and I will tell you the next step to try.
Aug 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHY DOES THE WATER WILL NOT DISPENSE WHEN LEVER PUSH IN
I think your water dispenser switch is broken behind the area where you press your cup to get water. Go tom site below and enter the model HSS25GFPAWW into model search feature and it takes you to a photo of the switch #72 in photo The part number is different WR23X10224 I could also be mwrong but if you need to contact me my email is appliancepartsse@yahoo.com http://servicepartstec.blogspot.com/ <site
Jun 10, 2009 | Hotpoint HSS25GFP Side by Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Water/Ice Dispenser is not working
at the very least replace that water filter.clogged water filter will reduce water pressure to the line.
Feb 24, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE GSL25JFPBS Side by Side Refrigerator Logo
179 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
