Question about SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card Reader
Write-protect is on my sd 2gb card for my camera.
I want to copy pictures from my computer and cd's to this card, but it says that it is write-protect
  • 298 Answers
There is a very tiny slideswitch on the top or side of the card
Move it to the other end ;-)
Posted on Jan 17, 2009
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
Tip
Lost CD Driver
This is for you, if you lost your CD driver that came with your camera, and you don't know how to download your pictures to your computer. You don't need the disk to transfer your pictures from your camera to your computer. Follow these steps:
1. Take your sd card out of your camera.
2. Plug your sd card into your computer.
3. A folder with your pictures should appear on your computer.
4. Copy your pictures to a different folder on your computer.
5. Take your sd card out of your computer.
6. Your pictures will be on your computer for you to enjoy.
If that doesn't work, plug the cable in that came with your camera.
I hope this helps.
on Jan 07, 2009 | Polaroid I533P Digital Camera
Tip
Lost CD Driver
I hope this helps.
on Jan 07, 2009 | Polaroid T730 Digital Camera
My computer does not recognize my SD 2GB SD Flash Card which I insert into my camera and take pictures. I have a slot on my computer for SD cards. Can I just put the card in the slot and access the...
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Jun 24, 2009 | SanDisk 2GB microSD Memory Card
Tip
Lost CD Driver
I hope this helps.
on Jan 07, 2009 | Polaroid i733LP Digital Camera
Missing pictures
Lets check the SD card first.
Take out the SD card and put it in external card reader connected to computer.
Copy/transfer all the photos from the SD card to computer.
goto My Computer and right-click the 'Removable Disk' (the SD card drive) and click Properties.
click Tools and click Error checking - Check now button
select the option 'automatically fix file-system errors' and click Start button.
if any errors was found and fixed, you can also Format the SD card. And your SD card should not drop photos again.
Now put SD card back in the camera.
Now take 20 test photos and check if something is missing.
if not take 20 more test photos and check if something is missing.
if all is ok then you can delete all test photos and start taking normal photos.
May 31, 2009 | HP Photosmart R817 Digital Camera
Took pictures with Panasonic DMX-FZ50 using a Lexar SD 2GB memory card. I put card into card reader in my computer to upload. It shows a JPEG thumbnail with a file # and if you place the cursor over it, it...
Firstly, whenever you put the media card into a card reader, ALWAYS turn write-protect on, to protect the images already on the card.
Secondly, AFAIK, the only way that your computer could have 'wiped' the card is if you told it to Move the images, rather than just Copy them. Again, setting write-protect would have solved this.
May 04, 2017 | Cameras
Vvicam 3625 does not working with windows XP
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 27, 2008 | Vivitar ViviCam 3632 Digital Camera
KODAK EASYSHARE Z710 DIGITAL CAMERA
Hi Tanya
It sounds like something was corrupted when you transferred your pictures to the computer.
If you have all the pictures safely on your computer, it will be ok to reformat the memory card and then just copy and paste the pictures back to the card.
Insert the card in your card reader, go to My Computer, you should be able to see the card as a removable drive. You can click and open it just like a folder and see what is on the card.
I would also back up the pictures to an external drive or dvd so they are extra safe!
Feb 16, 2008 | Kodak EasyShare Z710 Digital Camera
SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card Reader Logo
100 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
