Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Coleman evcon furnace
If i have already cleaned the flame sensor and the unit still goes out when the blower motor kicks on,,,what else could be the issue?...heat exchanger?...bad flame sensor...gas plug?
any help would be great
  • Matt McElhenny
    Matt McElhenny May 11, 2010
    Could be a bad heat exchanger. a crack or hole can cause the blower to effect the air pressure in the heat exchanger. How old is the unit? Does the pressure switch trip? Does the flame blow around when the blower comes on? Any of these can indicate a bad HX. Does the limit switch trip? Is it clean?
  • Coleman Master
  • 3,411 Answers
Is the air filter clean afc could be dirty
Posted on Jan 22, 2010
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
I have a steady green indicator light on my Coleman Evcon Furnace what does this mean??
Check the flame sensor is clean . And check limit control is not shutting off too soon ,
Jan 24, 2018 | Tools & Hardware - Others
I have a Coleman Evcon Elec Furnace with the added AC Unit. The blower works great with the AC but only on & off with the heat, what could this be?
Replace the sequencer...which is just a series of snap disc relays that are staged. The first snap disc should kick on the first element & low speed of blower. Depending on how many elements you have, determines how many snap discs are on the sequencer. It could be a 2,3,4, or 5 stack. Generally the coil is 24 volts.
Dec 01, 2012 | Coleman Evcon Furnace Control Circuit...
Coleman mach furnace wont stay running. i turn the thermostat down until i hear it click, then i turn it back up to get the furnace to kick on.works sometimes and sometimes not. blower will always kick on...
Hi, I don't know if you are still having a problem, but it sound like the flame sensor on the unit is dirty and need to be cleaned. If it has a automatic pilot, it will have a flame sensor. Its made of porcelin with a metal rod coming out the end, laying next to the pilot flame. Just 1 screw holds it in place. Remove it and clean the tip with steel wool or a piece of sanding cloth. If you don't have this set up, I would need more info on the unit, model and serial number. You may also have a faulty thermostat, but I do believe it is a flame sensor.
Shastalaker7
Nov 21, 2011 | Coleman Mach III Air Conditioner
I have a coleman evcon model dgat070bdf furnace. As soon as the furnace fan kicks on the burner shuts off. Any ideas?
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Feb 05, 2010 | Coleman Propane Forced Air Heater...
Evcon Coleman mobile home furnace needs repair
if you know what the flame sensor is try gently cleaning it with sandpaper they get gummed up sometimes and don't sense the piolet flame, if they don;t see a piolet it will not allow it to kick the gas on
Oct 10, 2009 | Tools & Hardware - Others
Have a coleman evcon furnace that is reporting ignition failure but everything is working but the valve shuts off after 15 seconds or when the fan motor kicks in
Thanks for your question,
more than likely it would be your Flame sensor, it is more than likely dirty and needs cleaning, it is the rod that the flame impinges on when the unit lites off, if it is dirty then its a matter of removing it and cleaning it with emery cloth, or replacing it, cleaning is the cheaper alternative, just look at the front of the burners, and you will see a pencil thin rod, thats your flame sensor, should be just one 1/4 hex head screw holding it in place, a quarter inch nut driver works great for this, then remove, clean, and reinstall, make sure you have the power off while preforming this task, hope that fixes your problem. please leave a rating for this, thanks again,
mr.grzz
Jan 23, 2009 | Heating & Cooling
Heating & Cooling Logo
379 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Paul
Paul
Craig Butler
Craig Butler
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
