Question about Toshiba D-VR4 DVD Recorder/VCR
DVD player does not read discs anymore
I have a DVD/VCR combo player and the DVD side does not read anything anymore. I can't even get the DVD side to open anymore. On the TV screen it just says "Incorrect Disc" and the front of the player says "Err". What happened?
  • 5 more comments
  • tkulmer Nov 09, 2007
    All DVD's loaded into my Toshiba (D-VR4X) invoke the message incorrect disc, despite the fact I may have just recorded or viewed the disc hours or minutes before.
    The problem used to occur whenever I ejected a disc and loaded another, or simply loaded the same disc a second time. However after 3-4 tries ejecting and reloading it would eventually read and load.
    It has now regressed to the state that it will no longer load anything on the DVD side and anything inserted comes back with the message "Incorrect Disc"
    Toshiba Canada should be ashamed of their service department or help center as I was told there was no such model, eventhough I had the mmanual right in front of me during my call.
    My result from them was a simple take it to a local service depot as it is now beyond the one year warranty period.
    I paid good money for this unit to have it work 14 months only and am now planning on buying a Panasonic unit and using this junk as an anchor.
    I also could not get into the set up screen of the unit in later months.
    Help
  • Diane Simons
    Diane Simons Dec 01, 2007
    My Toshiba D-VR4SU has just started to give the Error Message "incorrect Disc - C104. The odd thing is that it reads other discs with out any problem.
    From what I read in solutions, it sounds like the laser is going. And as luck would have it my warranty has expired by 39 days. I too spent good money on this unit and cannot believe that I will have to replace it 14 months.
    I wonder how the Laser replacement will cost with parts and labor. Should a put more money into it when in only 14mths parts are wearing out. What will be next...
  • Anonymous Jan 05, 2008
    I have a TruTech DVD Recorder/player that is 2 years old but only used for 6 months. I can get all screens and set a timer recording, but when I insert the blank disc here is what happens. First it loads for about 5 min. Then it asks to format the disc, hit ok. Formats for another few min and then says disc error. I purchased all new discs and tried 12, all with the same result. The machine will play a CD with no problem.
  • kathryneb Feb 22, 2008
    When I put a DVD in to play, it spins for about 30 seconds and then the message "incorrect disc" comes up. I've tried unplugging and removing the reinserting the DVD, but the same message appears. I'd like to watch a movie! It used to happen every once in a while, but now happens every time.
  • megsemails Sep 22, 2008
    I have the same problem with the DVD player. Anytime I load it it reads incorrect disk. I had to hook up and other DVD player to my Toshiba TV combo to be able to play DVD disks. I was told the laser is gone and can't read disks anymore, that's a shame. I have this TV since 13 moths and the DVD player already broke. What's next? the VCR player?
  • Anonymous Dec 06, 2008
    DVD player. I can't even open it and ofcourse it does not read the DVD so the displayreads only broken lines ----------. Doesnot show any err indication. The TV screen looks normal just displays that it is in DVD mode. Thanks!!!
  • Anonymous Mar 22, 2014
    My DVD won't read the disc when put in it is just coming up as no disc found
Sorry no solution . i tried cleaning disc to no avail. Ithink it is the laser that has gone chips and will need replacing.
Posted on Sep 27, 2008
Hi, there,
I was having the same problem with the disc being ejected saying "Disc Error", but after reading comments from tkulmer posted Nov. 9, 2007(above),re. keep putting it back in. I cleaned my disc with a clean cloth, put it back in, and Voila! it stayed in and I was able to playback with absolutely no problem.
Thanks a lot!
Maxine
Posted on Aug 21, 2008
I too have the same problem. Unit just gone 12 months old and will no longer load dvds. My solution to the problem?? I will be returning my loyalty to Panasonic. Thanks for the heads up Toshiba, my first and last Toshiba purchase!
Posted on May 16, 2008
  • 81 Answers
The Laser is most likely defective. most likly it will need replacement. There is no correction that can made to correct the problem except to that of a replacement of the laser
Posted on Apr 07, 2007
With some models of DVD player I know you can download a firmware update on your PC, load it to the DVD player and it wil fix some issues.
Finding those sites for download may be difficult though.
Posted on May 17, 2008
SOURCE:
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Can a Go Video 3140 make a dvd disk copy from vcr tapes
Yes,read ur manual intructional book how to hook up the tv, VCR/DVD sides togother so it all link up.Play a VCR tape one side and record a DVD disc another side.
Nov 08, 2010 | GoVideo Go Video DVD/VCR Combo
Hi, I have a Samsung DVD-VR300E dvd/vcr combo. The DVD player won't read any DVDs anymore, whether bought or recorded. What I don't understand is that it does still read the DVD cleaner disk! It won't read...
The laser in the DVD drive may be shot (?), even though it seems to read the DVD cleaner disc. I attended a maintenance class on cleaning CD and DVD writer drives for PCs and was told not to use the disc cleaners with brushes as they can knock the laser out of alignment. It's best to use a can of pressurized air to clean a drive when it's open. Just make sure not to allow any of the propellant to get inside!
Aug 03, 2010 | Samsung DVD-VR300 DVD Recorder/VCR
I don't know if my first REQUEST for Assistance was received, at any case, I REQUESTED to find WHY my GO.VIDEO COMBO Player is NOT READING any of my blank DVD DISC( SONY, IMATION, MEMOREX, DVD+R ), IT KEEP...
If there is nothing on the disc, it will read, "no disc". It will only read and/or identify discs with media loaded or burned onto it. Your unit is a player, not a DVD+R (recorder). Can record VHS, but not discs.
Jun 30, 2010 | GoVideo Go Video DVD/VCR Combo
The DVD says "No Disc" when a disc in in the drive.
the laser len is not working anymore.and doesnt read the disc
Apr 29, 2010 | GoVideo Go Video DVD/VCR Combo
Toshiba TV Combo MW24FP1, DVD player doesn't work on some discs
This is a common problem for all combo units. The high voltage of the TV section attracts large amounts of particulate dust from the air and often it collects inside the DVD unit. The best way to deal with this is to clean the lens of the DVD unit u sing a cotton swab and alcohol. The store bought "cleaners" MAY work, but that is rare. These cleaners are nothing but small brushes embedded into a disc. They attempt to brush off hte dust. This rarely works. Open up the unit (if you feel comfortabel in doing so) to access the DVD section. Remove the top cover and carefully clean the lens. That should resolve the problem.
Dan
May 21, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Bad disc message
Did you try cleaning the eye i have had dvds that would not play because the eye was dirty
Mar 10, 2008 | GoVideo Go Video DVD/VCR Combo
Sylvania DVD/VCR combo
THERE ARE NO HEADS IN A DVD PLAYER! IT,S CALLED A
LASER. IF YOU TAKE THE UNIT APART DO NOT LOOK AT THE LASER IT WILL BLINED YOU BE CAREFULL WHEN YOU CLEAN IT. IFF WHEN YOU CLEAN IT IT STILL DON,T READ THE DVD,S IT MAY BE BAD. IF THATS THE CASE, IT,S TIME TO GET
ANOTHER DVD PLAYER. THE LASER COST TO MUCH TO REPLACE.
Jan 05, 2008 | GoVideo DVD-VCR Combo
Open Questions:
See all Toshiba D-VR4 DVD Recorder/VCR Questions
Toshiba D-VR4 DVD Recorder/VCR Logo
578 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
