Question about Cuisinart Refrigerators
Privat reserve cooler...Thermo does not
Cuisinart Privat reserve wine cooler...Thermo does not work. Fan runs constantly and heat sink will not get down to 53 . Many, many complaints on line about the same thing. The unit does not have a refrig, it has two fans that run over a heat sink. Any suggestions. It runs all the time. Was advertised as quiet. LOL
  • rickyrey1 Dec 22, 2008
    Thanks. I have a wine cellar in the basement. This unit is sold as a solution for the kitchen. Not to stick in the basement. To hold a few bottles in proximity to the area where you entertain. So ambient below 70 is not in line with their own advertising..
    Hah! .So whats new in 2008 in America along with all the the other toxic **** we bring to market. Why should I be surprised.LOL.
    Master:
  • 416 Answers
It might be several reasons for that:
1. Ambient temperature is too high. It should be below 70 F, that is why it should be installed for instance in a basement. Kitchen might be too hot. If temperture is 75 F this unit will never go to 50F
2. Do you have a lot of moisture condensed inside (some moisture is allowed but not too much). If yes there is a leake from outside. For instance door seal. Once the system is not closed it keeps operate to set the temperature.
3. The unit might be obstructed. It should be some free space around, no heat generating applience (fridge, oven etc)
Good Luck
Posted on Dec 22, 2008
  • Cuisinart Master
  • 19,396 Answers
Check if there is dust on the coil behind the fridge and clean it.
If there is ice on the coil do a defrost, leave space between fridge and wall behind, the condenser is probably under stress because the evapourator system is inefficient.
  • Ginko
    Ginko Dec 22, 2008
    Check also this link on the same problem: It's noisy.
Can not get wine cooler to get cool. Red lights keep,blinking. Need structions on how to set it.
If the light is on and no fan or compressor is running then its your thermostat that is bad. That's the only thing that turns on those parts. As you said the unit is new you should contact your dealer either to replace it.
Keep us updated.
Aug 20, 2011 | Cuisinart Private Reserve CWC-900 Wine...
My Cuisinart cwc-600 does not cool. It registers 45 degrees but is not cold enough to make white wine palatable. No matter where it is set, it seems to be a room temperature. We live in a small house so...
I have been all through these, and they are not very repair friendly. If it's under 3 years old Call Cuisinart, they will exchange it.
They are solid state cooled using a peltier chip cooler. There are 2 fans in the back cavity, and 1 inside. Remove everything from inside, and set the temp to cooling. Do all 3 fans run? If the inside fan does not run, no cooling. The fans are common 2 wire 12 volt computer fans, and available at computer parts stores that sell PC cases and components. Next is to check the cooler itself. Remove the inside rear cover. There's heatsink under the inside fan. Does it get cold when the fridge is running? If not, the next step you will need to get the back off. The Torx screws are special, but a quick slotting of the screw heads with a dremel or a hacksaw, and a regular screwdriver will remove them. Once off, note the red/black fan wires. Also see if there is a load of dirt in the heat sink. If it's plugged, no cooling. Back to the red/black wires. The fan wires are thin. The peltier cooler is heavier. Set to cool, Check for 12 volts on all 3 pairs of wires. If there's power, the fans run (inside and out) and the inside heat sink does not cool, the peltier chip is bad. It's major surgery to replace the cip, but it can be done, and there are scads of sellers on E-bay selling 60-90 watt peltier coolers that will work. They are standard millimeter square sizes, just match the thickness, 12-15 volts, and wattage (around 60-90).
If you are not getting power on the peltier cooler chip lines, there is a tiny fuse on the lower left of the circuit board. Check it.
These are not servicable from cuisinart. Even the silly screws to change the light bulb are security torx type. Fans are available at computer parts stores. Fuses at electronic supplies. The peltier chip can be had from E-bay. That circuit board is impossible to get. Any other parts are impossible to get to by the way it's built.
Jan 28, 2011 | Cuisinart Private Reserve CWC-600 Wine...
The system will not cool and want to replace the refrigeration parts, all else seams to be working fine
I have a Cuisinart Model CWC900 wine cooler that stopped cooling -- the cooling module is bad.
The FIX.
1. First remove the filler plugs from the screw access holes. I did this by tapping the plug off center with a small screwdriver and a small hammer. The plugs popped right out.
2. Use a #10 Torx driver to remove the screws from the holes.
3. The chip on my cooler was a TEC1-12708 made by HB. The part # was on the chip. I found the chip information by doing a Google search on the part #.
4. I found a replacement chip from Custom Thermoelectric. The part # to replace the chip in my cooler was P/N 12711-5L31-09CQ. Cost is about $20. You should specify that the chips that you order should be 'Sealed'. The lady that I spoke with said that the chips last about two years. The people at Thermoelectric were very helpful and appeared to be very knowledgeable.
5. You should apply heat-sink grease to both sides of the chip before installing the chip.
I hope that this helps.
WGD
Jan 22, 2011 | Cuisinart Private Reserve CWC-900 Wine...
Wine cooler displays temperature setting but does not run or cool wine.
It's 1 of 3 things...
A. The fans are not turning. Remove the back, and see if the fans are getting 12 volts, and spinning freely. Remove them and clean off the dust from the heat sink.
B. The Peltier Chip is shot. If the fans run, check for 12 volts on the power connector that's on thelower left of the curcuit board. If there's power, but no cooling, the Peltier is shot. These are available from E-bay for ~$13, but it's a major dissassembly to get it out.
C. If you don't get 12 volts to the fans or the Peltier chip, replace the circuit board.
Dec 15, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Wont cool down fans in the back of the unit constantly run
Remove the back.
Remove the fans. See of the heat sink is not plugged up with dust. If so vacuum it out.
Get a dc voltmeter. Fire up the fridge. Set it to cool. With the fans running, check for 12 volts on the connector that's on the lower left of the circuit board. This connector powers the Peltier cooling chip. If you have 12 volts, and no cooling the Peltier cooling chip is bad, ir the second fuse is out. There is a small cylindrical fuse near the lower left corner of the circuit board. Carefully check for voltage across it. If the fuse is good, and the fans running, you will not sense voltage across this fuse. Bad, you will read ~12-16 volts.
If your Peltier Chip is bad, it's usually caused by over heating from a plugged up heat sink or fan stoppage. These chips are available off E-bay for ~$13, but require nearly a total tear down of the fridge to change it. 95% of these cooler chips are single layer, square, and vary in thickness. You should find one that is drop-in should you choose to 'Go for it'. Look for a 60-80 watt unit that is the same or slightly thicker, and the same size square.
Oct 22, 2010 | Cuisinart Private Reserve CWC-600 Wine...
Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Thermoelectric plate does not appear to transfer heat
you should see if theres a DC voltage going to the plate or not. it should noticeably heat up instantly with proper voltage applied. if power is there and it doesnt heat then the thermoelectric device needs to be replaced. also you should be able to measure a resistance of the plate. Should not be shorted or open. it should be a relatively low resistance. like a few ohms. and it may read different depending on which direction you connect the leads.
Aug 02, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Unit will not cool. Stays at room temp.
based on my personal experience it may be a bad fan. can you feel the fan running? or does it just feel hot near the vents?
Jul 31, 2009 | Cuisinart Private Reserve CWC-900 Wine...
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Refrigerators Logo
Top Cuisinart Refrigerators Experts
Brian Coughlan
Tom Chichester
gbob59
Are you a Cuisinart Refrigerator Expert? Answer questions, earn points and help others
