Question about Gigabyte GA-8I865GME-775 Motherboard
Fan sound is very high
Cpu temp is 58-63c and fan speed and sound fan is high in normal form. fan and cpu have not problem
    Scholar:
  • 121 Answers
Check the speed of the fan in the BIOS and set it lower, although 58-63c is alright for a CPU (P4 is rated to go up to 70c) you might want to make sure that you have good air flow in your case to make sure the CPU doesn't overheat. Usually you can find the fan control in the Advanced section of the BIOS. You'll also want to check the specs of the fan that you have installed as that will tell you how loud it's supposed to be. You might have to get another fan with lower decibels if you want it to be quieter.
Posted on Apr 07, 2007
Gateway pa6 fan problems
old post.
odd symptoms.
the OP never once told the full story
what works good and not.
XP runs? surely it can, 0.4% 2016 run XP world wide and way less now 2018, due to virus magnet status.
do not run XP , and the fan is not XP job.
BIOS runs the fans.
if the PC runs at 56C or so and the fans slow that is normal
The bios only speeds up facts at start,
the slows them and monitors CPU heat and GPU heat
if they rise too high the fans spin up.
this is how all PC run
my fancy desktop has 600rpm fans right now, due to cool running CPU. 4 pin fans can do that magic.
The reason for the fast spin up is easy to learn turned on fresh.
the PC ASSUMES the chip are hot.
say PC parked in a trunk at 120F
the you go indoors and turn it on
so to be safe, it runs them fast (like at BIOS machine code instruction 1 or first. it spins them up then watches CPU temps live. this can take a few seconds to do a scan, see a TREND
if the trend show low, temps, it then uses a PWM fan table in the BIOS, and set the fan speed off that hard coded table)
get that?
now say PC was hot turned on then it slows only if fast fans speeds can lower the CPU temp
then rule 2 and 3 on BIOS CPU temps
if bios does not like say 80C it can turn itself off.
if failing to do that, say fan is dead, learn that ALL CPUs from P4 up
can turn them selves off they HALT.
ALL AMD and intel CPU do that.
ok?
and did you really clean it
is the RAD clean.?
http://www.pcdied.com/overheated.html
Jan 13, 2018 | Gateway Computers & Internet
Computer beeps every 30 seconds
It is car brakes. Turn that game off.
OH, I'M JUST KIDDING!
BIOS speaker is broken, and you hear high pitched beeps?
Hmmmmm,..........
CPU temperature in normal............
What is the CPU, and what is the temp? Hey, I gotta know so we are on the same page here, lol!
Me?
Those repeated high pitch BIOS Beep Codes indicate a CPU problem.
I would remove the Heatsink/Fan combo, and replace the Thermal Paste.
(Following Anti-Static Precautions, and cleaning the CPU, and Heatsink, of course)
Also make sure the Heatsink is sitting flat.
Yes, I know what you stated about Speecy, and Core Temp, but I would try it anyway.
Still no?
CPU is sounding Taps, and telling you goodbye.
Regards,
joecoolvette
Jul 29, 2012 | ASUS Computers & Internet
Processor thermal treat error while booting
Make sure that cpu fans are running normally. Go to BIOS (generally with F2 on intel motherboards), and there will be information about cpu temperature, also fan speed (in RPM). If fan speed is 0 or very low problem is in cpu fan. (connection problem might be). If cpu fan speed is normal (high value) and cpu temperature is high, I will suggest you to open your PC case (or notebook) and see whether cpu fan is dirty or not. This is very common problem. If so, clean it.
May 09, 2012 | Intel Computers & Internet
My pc's Front fan is giving bad sound and its speed increases while playing game and give sound but at normal using like chating playing songs it works oK now what to do any one plzz
When you are playing a game, your CPU has to work a lot and a lot of heat is released. To cool it down, the fans run at a high speed making that bad sound. Playing a song does not require a lot of CPU work. To reduce this get a additional fan which can control heat without making noise. Make sure your CPU and the Heat sinkers present are free of dust.
Dec 28, 2010 | Dell OptiPlex GX620 PC Desktop
Lincon LS 2006 5600 kl coolent fan runs in winter when the temp gage is normal the radeator is not hot.The fan is very noisy, the engin has ben bled of air. The car has ben looked at by Lincon dealer said...
the fan has a low and high speed or some have 2 fans. It comes on low speed when the temp starts to climb or when you turn the a/c, defrost, or mix mode (it turns on when the a/c compressor kicks on. If the temp of coolant gets to about 230 F, then the high speed kicks in.
What is your doing? Very nosiy sounds like high speed. Could be a defective ECT - engine coolant temp sensor.
Dec 07, 2010 | 2006 Lincoln LS
Beep problem
Hello niceguy_jes2,
click on this link for the ambulance like sound beep description:
http://www.bioscentral.com/beepcodes/awardbeep.htm
"High frequency beeps while running". "Check the CPU fan for proper operation. Check the case for proper air flow".
First item to check would be CPU's fan speed. To do this, enter your bios menu. Listed there is "H/W Monitor". Open it. Check the fan speed, CPU temperature & mother board temp. Chances are the CPU fan is turning too slow & it may need to be replaced. (No less than 2300RPM's). Average CPU fan's spin at 3000 plus).
Next item if CPU fan is ok. The thermal grease between the heat-sink & CPU may have dried up over time & cause the CPU to get too hot. You may need to remove the CPU & heat-sink assembly. Clean off all old thermal grease from the bottom of the heat-sink & from the CPU. If you do this, do not scratch either surface. Use house hold alcohol on a clean rag & wipe away all old thermal grease. Apply a tiny amount of new thermal grease. Re-assemble & check through bios H/W monitor, CPU temp. One or the other will stop the system beeps.
Link to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=237
Good luck niceguy_jes2!
Post if there are troubles.
Thank you for using fixya.
Mike
Jan 07, 2009 | MSI K8MM3-V Motherboard
CPU FAN SPEED IN HP Compaq d530 Small Form Factor Desktop PC
The fan/heat sink on these models get plugged with dust very easily, use an air compressor or can of air to blow the dust out of the heat sink and fan. In extreme cases the thermal paste gets dried out and needs to be re-applied to properly cool the processor.
Dec 01, 2008 | HP Compaq d530 SFF PC Desktop
Cpu fan noisy/chip fan fail error messages
pils,
Yes. This sounds like a fan issue. The noise often comes from bearings failing within the fan. Also, a failing bearing can make things harder on the motor as it brings the fan up to speed. This is likely the reason that you see increased warnings during the fan speed check while booting because it comes to speed more slowly as bearing wear increases.
I give this a 90% chance that your CPU fan is causing the issue. Since a decent CPU fan will cost you ~$20 online, it's not much out of your pocket if you happen to uncover another culprit.
I'll keep an eye on this post. Let me know how things go.
Apr 03, 2008 | ASUS A8N-E Motherboard
Main cpu fan high speed
the speed of the cpu fan will go up and down depending on the work load that your pc is going thru,lets say you start a game and the speed increases then drops down thats all normal
Oct 06, 2007 | ASUS 865G (MBAS-P4P800VM) Motherboard
Computers & Internet Logo
237 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
steyr1
pankaj rautela
pankaj rautela
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
