Question about Canon MX300 Office All-In-One Printer
Lexmark x 3650 change ink cartridge but it still gives a message(
The message is color cartridge replacement required a varible amount of ink will remain in the cartridge. can anyone help me glesam123@yahoo.com thanks Glen
  • glesam123 Dec 22, 2008
    but both of the cartridge are new i though that i got a bad cartridge so i took it back and got another one but it did the same thing can a person bypass that so it will print even if the cartridge is empty my 3400 lexmark will print even if its empty. i even refilled the old cartridge up that came out of the lexmark x 3650 and it even said the same thing.
  • Anonymous Jan 01, 2009
    where on EARTH is the ink cartridge in a Lexmark X3650 stored?
  • 66 Answers
Hi Glesam,
The X3650 uses the No. 37 tri-color cartridge, i.e. 3 colors in 1 cartridge. Unfortunately, when one color runs out, the cartridge has to be replaced. When you change printer, you might want to consider a printer that uses at least 4 separate ink cartridges (black, cyan, magenta, yellow). This way you need to replace only the cartridge that runs out.
Rgds
S88
Posted on Dec 22, 2008
  • sam88kid Dec 22, 2008
    Try to clean the contacts (that meet with cartridge) in the printer with some alcohol. Switch off the printer first!
When writing a Lexmark X5690, this text is displayed in the display (color cartidge replacement required. A variable amount of ink is in the catidge), what should I do now. Can it be refill ink?
There are some refill kits,a little messy. You could try resetting ink cartridges to see if it allows it to function properly ultimately it will need to be refilled or changed .
Jan 05, 2018 | Lexmark Office Equipment & Supplies
After refilling my cartridge it shows ink level low for one cartridge and gives two error messages for every printing but prints. But for another cartridge it does not print and give message to buy a new...
Original Printer manufacturers do not recommend refilling in cartridges.
Different inks used in different cartridges differ in density, color, acidity etc. Usually refilling ink is made as universal ink. i.e. They produce the ink for 'any printer'.
The differences in the original and refiling inks might lead to the printer not recognizing the ink level.
Either buy a new cartridge or just ignore the messages.
Sep 24, 2011 | Lexmark Z1320 InkJet Printer
I ran out of both black and color ink. I replaced the black ink b/c I do not print in color. But I cannot complete the alignment steps without the color ink.
Lexmark printers usually require both cartridges to have ink left in them to continue printing. But try to press the Cancel button for the Alignment process (this is not recommended). Then try to print a document again to verify that you are able to continue printing without an empty color ink.
If that doesn't help, I would suggest you replace your color cartridge with a new genuine Lexmark cartridge.
Sep 12, 2011 | Lexmark X2690 All-In-One InkJet Printer
Color ink cartridge
Well due to some problem in cartridge you would be facing this problem.however you can do try this.
Please clean your cartridge once again with some spirit.
Fix it well in the printer afterward.
Than use normal paper and print in color.
If than also it does not work that means the bar-code of the cartridge has problem in it so the printer is unable to read that code, so for that you need to change the whole cartridge.
Or if your printer had valid in warranty period and it still in that period just give it to a service center.
If you still had any confusion regarding the same problem or nay other please do reply.
Naiven.
May 31, 2010 | Lexmark X4270 All-In-One InkJet Printer
Change color ink message won't clear from machine
look for the all in one icon, then choose the change cartridges, say to pc that are news cartridges, that will raise de ink level.
Jul 24, 2009 | Lexmark X125 All-In-One InkJet Printer
Color cartridge missing
You may want to remove the power brick at the back of your printer, wait a few seconds and reinsert back. Then try the steps listed in the user guide to install new carts, page 42.
http://www.lexmark.com/publications/pdfs/x5150/eng/ug.pdf
Jun 01, 2009 | Lexmark X5150 All-In-One InkJet Printer
"color cartridge replacement required"
This is common problem with lexmark cartridges they detect refilled cartridge you need to clean the copper contacts of the cartridge and then insert it if it still shows " color cartridge replacement required" message then you need to buy original color cartridge.........
Jul 15, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5150 printer (serial #10450991811): Error message reads "color cartridge missing." It is not. With the last cartridge, printing was light and scattered; could not print anything...
Went to online chat with Lexmark. FREE.
They offered to replace cartridges as they felt the ink was dried out in one, and the ink jets in the other were damaged.
Apr 18, 2008 | Lexmark Office Equipment & Supplies
Cartridge error
How I solved this problem was, I took out the color cartridge (which seem to be the one giving the error message) and worked only with the black ink (and chose print black and white )
My color ink cartridge had been refilled at Walgreens. The Black ink cartridge is an original Lexmark
Oct 22, 2007 | Lexmark X3480 InkJet Printer
Ink Cartridge
Lexmark/Dell info
Before you buy a remanufactured Lexmark or Dell inkjet cartridge please carefully read and understand the following:
The more recent ranges of remanufactured colour Lexmark and Dell ink cartridges have been remarkably unreliable - the failure rate being massively higher than all other remanufactured goods we supply. Our remanufactured HP's, Canon, and older Lexmark/Dell ranges remain very reliable.
At seems almost certain the micro-electronics in these cartridges have been developed in the factory to ensure failure at a given point. THE MODELS MOST LIKELY TO CAUSE PROBLEMS ARE THE LEXMARK No1, No2, No3, No29, No33, No35 and No43, AND THE DELL MODELS TO FIT PRINTERS 922/924/942/944/962/964 and Dell printers sold in the last 12 months. For some reason the problems seem to be with colour cartridges - black units remain reliable.
On the reverse of a brand new Lexmark 29 colour cartridge box (in print so small it's almost impossible to read) it says: "THE PATENTED PRINT CARTRIDGE CONTAINED INSIDE IS LICENSED FOR A SINGLE USE ONLY AND IS DESIGNED TO STOP WORKING AFTER DELIVERING A CERTAIN AMOUNT OF INK. A VARIABLE AMOUNT OF INK WILL REMAIN IN THE CARTRIDGE WHEN REPLACEMENT IS REQUIRED." In plain English this means the cartridge will certainly fail - even when there is ink inside.
Although this is not printed on the boxes of certain other models, the high failure rate suggests similar technology is deployed. A perfectly good remanufactured cartridge can be installed, and used - albeit temporarily. Suddenly and without explanation, an error message "UNSUPPORTED CARTRIDGE" appears, and the cartridge refuses to work ever again. Most will almost certainly end up in landfill.
Jan 23, 2007 | Dell 924 All-in-One InkJet Printer
Canon MX300 Office All-In-One Printer Logo
523 people viewed this question
old marine
old marine
