Operating Systems
Problem for Operating Systems
Generic problem for all Operating Systems
Error message when I openmy computer:
By scdec23 on Dec 22, 2008
when i open my computer, this error message appear: "Reboot and select proper boot device or insert boot media in selected boot device and press a key."
and my computer will automatically shuts down...
What can I do to fix this problem?
Thanks....
Same Problem
Jan 01, 2009
-   Hi, I have the same problem, the only difference being that my laptop is not shutting down right after, it stays as it is displaying that message. How can we fix this problem? What you explained seems to be so tecnique, and so difficult, can you please tell us step by step what is to be done?
Thanks
-   ruxi79
Solution #1
posted on Dec 22, 2008
Somewhat Helpful)
xsoulreaver
Rank: Guide
Rating: 75%, 4 votes
-Take a look in your BIOS console to see if your primary boot device is connected and shown in the list.
-if yes then, bootsector on primary boot device is missing, and you might have to connect this HDD to a different computer and back your data up, and then connect it back to your computer and run the windows recovery. make sure you scan for bad sectors after your system is up and running.
-if no, then shut your computer off and groud yourself and take all the precautions for static and open the cabinet and make sure that your primary boot disk is securely connected to the motherboard and power connector is firmly connected to it (you can try switching the cables to see if its an issue with the cables, motherboard ports or power supply)
hope this helps you to pin point the issue..
Was this helpful?
Yes
No
Solution #2
Not Rated)
scanner077
Rank: Wiz
Rating: 79%, 52 votes
Please make sure that you have set your computer to boot from your HDD initially. You can do this by pressing F5 or F8 button upon restarting the computer thereby going to the CMOS settings, then check the boot sequence. Your HDD must come first. You may press PgUp or PgDwn to change the boot sequence.
If your boot sequence is OK and you have Windows installed in your computer, it sounds more like the Master Boot record of your HDD is screwed up. Boot up with the Windows cd into Recovery Console and see if you can access the C:\Windows directory (or any other directory you know on that HDD). There are also utilities on the internet that can scan your HDD for any problems, physical or software faults, and may try to correct them (be careful using this - it may delete stuff).
Easiest way is to download a Live OS CD like Knoppix or Ubuntu Live that has support for NTFS filesystem and using that to access the HDD directly. That will tell you if you have a problem with your HDD or not.
If you have tried all the above steps and you still have the same error, you may reinstall OS if you still have your original Windows CD.
Was this helpful?
Yes
No
Popular Solutions for Operating Systems
Questions and Unsolved Problems for Operating Systems
Answer
How can I upgrade my royal 660 cashregisterlink to cashregisterlink pro
Answer
i want to factory restore my lx2000 phillips pc but dont have a disk to do it. is there anything... (More)
Answer
I need a valid key code for windows vista that i can activate windows
Answer
I have forget to start a new file in visual c++6.0 to write a program! piease help me . after... (More)
Answer
won't let me download pic. sent to me via text.
Describe your Operating Systems problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Operating System Experts
Top Computer & Laptop Repairmen
in Newport, KY
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
