Question about Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera 50" has no color
Just installed a new cable line, moved my TV to another room, and now I have no color. Sound and picture look ok but its in black and white. I'm a fios user. Any thoughts?
Thanks,
Kevin
SOURCE: Panasonic viera
1.You may have the magnet of a speaker too close to the TV.
2.Turn off other electrical devices in the house one at a time.
3.Faulty cable.
Puzzler.
Posted on Oct 31, 2007
  • 583 Answers
SOURCE: Panasonic 50" Viera plasma on/off problems
its the problem in main board.any of the capacitors or ic are getting overheated that needs to be checked and replaced. thanks.
Posted on Jul 13, 2009
rockitman187
  • 2559 Answers
SOURCE: Panasonic Viera Closed Captions HELP
Just use he remote and push the cc button or the display button until cc off appears on the screen
Posted on Jul 29, 2009
  • 5 Answers
SOURCE: screen comes on all red 50 inch panasonic viera
the rest of your color spectrum in you r tv has burt out
Posted on Aug 21, 2009
Testimonial: "I had suspected that but just had to be sure. Thank you very much. I most appreciate this information."
SOURCE: Viera Link not work between two brand new Panasonic devices
You need to select setup from the TV menu then switch the Viera link on. I think retuning must have switched it off.
This worked for me
Posted on Oct 03, 2009
My Panasonic plasma Tv does not have sound. How do I fixed that
Sound no picture on 50 inch samsung plasma ps51d450a2m - HDTV ...
www.tomsguide.com/.../58009-4-sound-picture-inch-samsung-plasma-ps...
Jul 1, 2015 - 4 posts - ‎3 authors
There is sound and no picture on plasma tv, remote works at times but ... My pioneer elilte has this mode, and it is pretty easy to completely turn ... When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
Problems with blu ray player and plasma tv - HDTV ...
Nov 16, 2014
I do not have audio out on my tv how do i connect so ...
Dec 18, 2013
All channels on my tv have sound except channel 3 ...
Jun 29, 2010
More results from www.tomsguide.com
No picture or sound in my Panasonic TH-P42UT30A plasma ...
Dec 07, 2015 | Panasonic Viera Th-50px60u 50" Plasma...
No picture on my Panasonic TV
Please unplug all HDMI cables from the TV and test a different electrical outlet. If the problem persists, please use the below link to locate an authorized service center in your area.
Where to Service Panasonic Products
Mar 13, 2014 | Panasonic TC-P50S30 VIERA 50 Class 49.9...
Panasonic viera picture
no picture and no sound
Jul 07, 2013 | Televison & Video
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
5 year old panasonic viera LCD works great until tonight, screen turned into vertical and horizontal rainbows, can see vague picture behind all the lines like looking through thin black horizontal venetian...
make sure your speaker to your sheron sound isnt to close to it .also if dvd player is the source then move away from tv will demagnatize the tv theres a magnet in them
Jul 05, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Hi - we have problem with Viera tv. no sound or pic. switch on green light briefly. then straight to red light flashes 4 times then 3 sec interval then repeat. tv is just over 13 months old. any ideas.?...
Instructions Things You'll Need:
  • Damp Cloth
  • Fuse
  • TV Remote Control
  1. Ensure the power cable is securely fitted to a wall output if you can't get your Panasonic LCD TV to power up. Try testing the wall outlet with another appliance to make sure there is not electrical fault with the outlet itself. If there is still no power, a blown fuse may need replacing.
  2. Switch off the color correction option if you are using HDMI cables and the displayed image has unnatural colors. For instance, if a picture area that should be red is blue or green, then the color correction option may be the issue. Press OK on your remote control. Now access the Other Adjust option and scroll down to the Color Correction option. You can now turn the setting off, which should restore normal image quality.
  3. Press the Mute button if you can't get your Panasonic LCD television to produce sound. This may have been pressed in error, cutting off the sound. Check the volume settings on any other devices, such as a games console or DVD player, that are connected to your LCD TV. If the volume is set to low on such a device, it can limit the sound output on your TV.
  4. Check that the air vents at the lower rear of your Panasonic LCD TV are free of dirt and debris. Dirt can accumulate in these areas, causing the cooling function to under-perform. Panasonic LCD sets come with built-in safety features that shut off the power if your set becomes too hot. Clean the air vents with a damp, rather than wet cloth. Dust and vacuum the room regularly to prevent the problem from recurring.
Jan 24, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
CONNECTING THE SET TO MY SURROUND SOUND SYSTEM.
What surround sound system can I buy to go with my panasonic viera th-50px80u plasma tv. One where I can here sound from cable and bluray
Jul 03, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Just bought a 50 panasonic viera, when we hook up ps3 on hdmi cable, we have sound but no picture.
Plasma TV normally do not have the resolution required for PS3 unless the plasma TV is fullHD( 1920x1080p) pixels.
HD Ready Plasma = 1024 x 768p
PS3 Outputs = (fullHD)1920x1080 or (HDReady) 1280 x 720p.
LCD TV accepts the resolution matches the resolution the PS3 is outputting.
Feb 28, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic Viera TH-50PZ80U Plasma TV Logo
229 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
