SimpleTech - Exteral Harddrive: It seems the hard drive fuse or trasformar is blown away. I am not sure. Could someone repair this?
  • Randall  Trahan
    Randall Trahan May 11, 2010
    External hard drives have neither fuses nor transformers. Could you clarify exactly what is going on with it, what are the symptoms and I can give research and try give you a good answer.
    Scholar:
  • 130 Answers
Yes.
Posted on Dec 22, 2008
Simpletech 250 GB External Harddrive won't backup 180GB . Says it is full.
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Jul 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
I think everything got deleted off of my simpletech harddrive.. how can i know for sure?? what can i do?? the red light turns on but all my movies and music are gone
double click on MY Computer, then double click on the drive letter for ur Ext H Drive and see what comes up. or right click once highlighted w/mouse pointer and select properties
May 03, 2010 | SimpleTech 1TB SimpleDrive USB 2.0/eSATA...
All my files on simpletech harddrive show as 0
you mean you HDD does not show the capacity it holds? try using it on another pc, or even try using it on your friends pc, see if it works?
Mar 28, 2010 | SimpleTech SimpleDrive 160 GB External USB...
SimpleTech SimpleDrive 640 GB external USB harddrive wont turn on
Loose connection inside the Drive case. Remove drive and check internal wiring.
Dec 23, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Mount problem for external simpletech 100GB harddrive
Typically points to a hard drive failure. These normally happen without much warning. Have you contacted the manufacturer tech support?
Feb 23, 2018 | SimpleTech 100GB SimpleDrive portable USB...
Simpletech 500GB hard drive service center in hyderabad
someone mention to me that its just a laptop drive inside the housing. You can go to fry's and ask. But they will sell you a kit for 20 bucks.The kit contains external power and usb strap cable and bought a seperate housing too. I accessed the ext drive, dragged and dropped all files. But i would check your warranty first, call tech support and double check. IF not what the hey go for it or spends lot of money to retrieve files. Try yahoo.com and under answers and type in simpletech. I dropped mine and recovered all.
Jan 18, 2009 | SimpleTech PC CARD W/ DRIVELINK- SERVICE...
Unresponsive harddrive
hi,
you have definitely got a dead HD (hard-drive) there, nothing you can do about it.
sounds like the force of the shock has damaged the HD beyond repair.
HD work by i high precision arm that reads data on a spinning platter, the chances are you have damaged the arm and the click is where the arm is trying to read the HD with no luck
sorry
Dec 28, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
External Harddrive Won't turn on
SimpleTech SimpleDrive Pininfarina 320GB External
I need to replace my ac adapter what is the voltage
6 volts or 12 volts
Dec 10, 2008 | SimpleTech SimpleDrive Pininfarina 320GB...
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
My simpldrive deluxe external harddrive 160gb doen't power on any more...
Is it a 3.5" or 2.5" drive?
If its a 3.5" the first thing I'd check is the fuse in the plug for the power supply (if you're in the UK)?
If changing the fuse doesn't work it could be a problem with the power pack within the external HDD. Is it under warranty? You my be able to get it repaired or a new one (Don't forget, if you open up the fasia of the hard drive you will void the warranty). I assume you're not worried about data on the drive as you are happy to format it. If you are worried about data and it isn't under warranty/garantee I can tell you how to get the data off if you need me to?
Hope this helps.
Nov 18, 2007 | SimpleTech 160GB USB 2.0 / FireWire...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
