Question about Pioneer VSX-818V-K Receiver
Ihave a pioneer vsx-818 v. All set up perfectly. learned the surround sound modes. I still can't figure how to adjust the bass and treble. The instructions are very confusing
  • cindy_spitle Dec 28, 2008
    Would you mind sharing how you hooked your receiver up? We can't get the speakers to work after hours and hours of trying! Thanks!
Go to the top of your bilding and ....
Posted on Dec 22, 2008
Is the base and treble audio adjustible on this 1996 Sony TV KV- 20S20
Adjusting various sound settings (e.g. bass/treble ... - Sony
docs.esupport.sony.com/imanual/NA/EN/hx850/c_snd_qv.html
You can adjust various sound settings, such as bass, treble, balance, etc. ... [Setting Memory]: Applies custom sound settings to the current input or to common ...
General information on how to adjust the bass and ... - SONY
https://us.en.kb.sony.com/.../general-information-on-how-to-adjust-the-b...
Aug 15, 2015 - Follow this procedure to adjust the bass and treble surround parameters on the A/V ... Adjustable sound field parameters vary by sound field.
Dec 25, 2015 | Sony KV-20S20 20" TV
How to adjust bass and treble and surround sound
On the Remote Control
Press
1 TONE
ToneControl•OFF-
2 Use selection button to select "ON".
ON : Allow tone adjustment (bass, treble).
OFF : Playback without tone adjustment.
NOTE
The tone cannot be adjusted in the direct
mode.
3 Press
to select an item to be set, and use
TONE
to select a setting value.
Bass : Adjust low frequency range (bass).
• -6dB - +6dB (0dB)
Treble : Adjust high frequency range (treble).
• -6dB - +6dB (0dB)
"Bass" or "Treble" can be set when "Tone Control" is set to
"ON
Oct 24, 2014 | Denon Avr 391 5.1 Channel 110 Watt...
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
I have a pioneer vsx 818 v amp, when I set it up we get noise / beeps etc from the surround sound speakers but then when playing a film in 5.1 we get no sound from the surround speaks ..driving me nuts !...
To get sound out of your surround speakers, first off go through the receiver setup and make sure that is correct. Also, usually the best soundfields to use for sourround sound is PLII Movie or dolby digital. Next , make sure the source you are viewing is capable of outputting 5.1 sourround sound. Lastly, it is a good thing to remember that sourround speakers are only intended to reproduce sound effects. You certainly can override it so that all speakers play full range audio, but that is not the intention.
Good Luck
Jan 07, 2011 | Pioneer VSX-818V-K Receiver
I have set up a BOSE Accustimass System with my STR de485 receiver. How do I adjust the treble/bass?
hi,
if u are using bose speaker system then remember one thing. go to speaker setup and select all the speakers as large not small. then only u will get a good tone. bose speakers will handle the output power of ur amplifier.
u can only adjust the bass and treble of ur frond Channel speakers. for that
select multi channel surround sound and the increase and decrease the bass and treble
ok
Dec 31, 2010 | Sony STR-DE485 Receiver
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Having Trouble Assessing Bass and Treble Controls
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Feb 18, 2009 | Clarion DXZ375MP CD Player
Weird issue with Pioneer VSX-D510 and "tone"-setup
clean the all push buttons by using isoprpylalchohol.(surgical spirit)and dry well .i think all the buttons are short by itself.the problem is still there please check the power supplu secondary side smoothing condencers related to system control power section.
nuwan
Oct 02, 2008 | Pioneer VSX-D510 Receiver
Pioneer VSX-818V-K Receiver Logo
734 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
