Question about Protron PLTV-32 Television
No Sync Detected
Hello Sir, On the screen, all that appears is NO SYNC DETECTED. Please tell me what I need to do. Thanks,
    President:
  • 1,284 Answers
Is this while trying to use a HD cable box, sat. rcvr, or DVD payer? Make sure the output is set a format the TV can do ie: 480i,480p,720p or 1080i. Some HD TV's cannot do 720p and possibly will say no sync.
Posted on Apr 07, 2007
SOURCE:
When I turn on my LCD TL3220 the screen shows a 3" x 6" silver box that says "no sync detected". I have checked the cable box and that seems to be working. Any suggestions
The word ''no sync detected' means that there is no video connection between the cable box and the TV set. Isolate the source of trouble by connecting to the TV a prevoius video source that worked properly e.g DVD player. You should also try to get a new set of video cables as the ones you have may be internally broken.
Please follow the installation instructions carefully especially the colour codes of the video and audio cables i.e yellow cable to yellow connectors of TV and cable box , Red cable to red connectors of TV and cable box etc.
good luck!
Oct 09, 2010 | Hisense TL-3220 Television
Flash mp3 (MC4004) F"n thing making me mad!
When the player shows up as a detected device in Windows Media Player 10 or 11, the MC4004 will try to synchronize the playlists that are on the player with those on the computer.
It is possible that playlists on the computer:
1. have been removed or
2. are no longer in the library for synchronizing
Synchronizing can be set automatic or manually in WMP.
When you right click the player in the list in WMP, selected Library or Sync view, you will be able to setup the sync mode of
the player.
For more help look in the help function "Help with Sync" under the Sync tab in Windows Media Player.
Need more assistance ? Just post another comment.
Jan 04, 2010 | Audio Players & Recorders
Barracuda 7200.7
Hello Sir,
While windows is booting first go to BIOS settings by pressing "Del" or "Esc" then change the boot priority that is save the first boot priority as cd-rom and second boot priority as hard drive... so that you can boot you system with bootable cd...
And then while formating the system just delete the partion that is only "c:/" and install the windows in to that and don't even do anything to your "d:/" drive then you can get all your data back... Abd the cd should be bootable format...
Aug 22, 2009 | Seagate Barracuda 7200.7 Hard Drive
HP 1940 turns off after a second or two desktop appears with a message no signal detecked
no signal detected is displayed when there is no sync pulse detected by monitor. look in the monitor cable connector and see if you have a pin bent down. same at video connector at pc. if no bent or missing pin it probably bad in monitor itself. do u have another monitor you can hook up to pc? that could tell you which end is defective.(pc or monitor)
Aug 20, 2009 | Computers & Internet
Tv comes on but only displays 'no sync detected'
What are you using for signal and where do you have it plugged into?
Jun 08, 2009 | Soyo DYLT032D 32 in. LCD Television
Computer wont detect Nextar ma715a to sync items.
lol You don't need to uninstall anything just go into My Computer in the Start tap in the Bottom left corner of you screen and click on your mp3 player's picture and if there isn't a picture it will say your mp3 player's IP name or company name.
Apr 26, 2009 | Audio Players & Recorders
Xbox360 wireless controller not being detected
1. Turn XBOX360 on
2. Press the sync on the XBOX360, green lights swirl
3. Hold the center xbox logo button on the controller, lights swirl
4. Release the xbox logo button on the controller then press the sync on the controller
Good luck
Dec 04, 2008 | Microsoft Xbox 360 Console
No display in monitor
This may be the problem with the WYSE driver. Ensure that correct driver is intalled and colour profile is compitable. Syncmaster is auto detected by window based OS.the message "Sync out of range" comes due to improper out put video signal.
Jul 24, 2007 | WYSE Winterm 3235LE Network Terminal
USB connectivity for Jornada 520
This may be a simple case of removing all the entire active sync directory. If you used to connect via serial+com it wont be detected on usb. Remove active sync from your pc via the add remove program feture, then reboot and re install. Then run the make a connection again from active sync. Hope this helps
Sep 12, 2005 | HP Jornada 520
Protron PLTV-32 Television Logo
1,382 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
