Question about Tappan MEF500 Electric Kitchen Range
Door Lock on Self clean
I set the self clean on the oven slightly pulled on the door to be sure the door had locked which it did but a second later it popped open and will not allow me to close or set anything because it is flashing locked but I don't know how to unlock it. The door is open but the lock latch is out.
catriver
  • 878 Answers
SOURCE: GE Profile XL44 Spectra gas oven
Carol, let me see if I can help you with this. First try killing the power to the oven for 30 seconds and see if the locking mech resets. If nothing changes try this: kill the power for at least ten seconds, power back up,simultaneously press the cooking time, delay start and the number 8 pad. Test should appear in the display. Press and hold the self clean key, this will test the lock motor and cam assy. The display should show 2 on the left (for locked) and change to 3 on the left for unlocked. Travel time of the cam will display a 0 between locked and unlocked. You must hold the self clean key for these changes. This latch mechanism is thermally controlled and sends a message to the main board to lock and unlock during self cleaning. We are just bypassing this with this test. Your temperature sensor may have gone bad during the self cleaning cycle. This is the probe located in the oven cavity. If you know anyone that is handy with a meter, it should ohm out at 1092 ohms at room temp. If this checks out, someone will have to open the top and check the lock motor and cam. Catriver..post back.
Posted on Nov 13, 2006
  • 76 Answers
SOURCE: self clean inoperative
Dear Superglide, An error code "F5 E1" means "door latch not operating". In such situation I would recomend to replace the oven lock assy (part # 9782611 ) which is located on the back panel.If you are going to do it yourself - DO NOT forget to unplug the power cord first. About service manual - try to call Kitchen Aid directly.
Posted on Dec 13, 2006
devocap
  • 201 Answers
SOURCE: Admiral electric range with self cleaning oven
Hey there gcato1, your problem is actually a protective feature designed to prevent you from getting burned. The self cleaning feature runs at extremely hot temps. Until the temperature reaches a safe level, the oven door will remain latched. Be patient and the problem will solve itself.
Posted on Jan 29, 2008
SOURCE: locked door on self cleaning oven
try unplugging the stove for some minutes and plug back in.
Posted on Dec 10, 2008
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
We put this unit on self clean and now it wont turn on nor open.
I had the same problem with a Superba wall oven. In my case, the bracket mount for the door lock warped due to the heat of the self clean cycle. We were able to open the door by inserting a coat hanger into the slight opening at the top of the door and sliding the lock lever to the left. It was a pretty easy self-repair - 1) turn off breaker 2) slide oven out 2-3" 3) remove oven front trim pieces 4) remove screws that mount control panel 5) this should give you access to the door lock mechanism.
good luck
Feb 01, 2010 | KitchenAid Ovens
My oven is locked and wont open. it is cold and wont unlock
Hi
Thanks for using FixYa. The locking of the oven is a safety measure while self clean function is activated. Once the oven has completed the cycle & has cooled down, then it will reset the door lock.
If a self clean oven door lock fails to open after the self clean cycle and sufficient cooling time has elapsed (approximately 1 hour), there are several things you can try.
  1. Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
  2. Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition or you were not using the self clean cycle, then, the lock must usually be accessed and moved manually to open the door—
In order to open the door you have to open the control panel and remove the door lock.
Remove the three screws from the bottom of the control panel. You'll heed a 1/4" open wrench. Pull the bottom of the control panel toward yourself and push it up to release from the upper tabs.
The door lock is secured by the three screws.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 25, 2009 | Maytag MER5775Q Electric Kitchen Range
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Door locked after shutting down cleaning cycle earlier than
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
May 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Self-cleaning oven door won't open
May 15, 2009 | Ovens
Dacor CPO230, can't get lock to engage for self cleaning. I follow step clean symbolcomes up door lock moves into locked position then beeping starts and the word door flashes and the lock opens up.
For some reason the oven thinks you have a door that is not shut all of the way. Check the locking slot to make sure that there are no obstructions. Make sure that you are only doing one oven at a time, and not trying to cook in the other. Make sure you have no racks in the oven. Try pushing lightly on the door when the lock engages. For some reason your lock isn't engaging fully and that's why door is flashing. Good Luck
Below is from the owners manual for your oven.
Oven does not self-clean Door not shut tight Check for obstructions. Close door tightly
Oven set for delay timed cleaning Oven will start to self-clean at preset time.
Press CANCEL/SECURE to return to
normal operation
Double ovens only: Other oven is on. Turn off other oven.
May 10, 2009 | Dacor ECD230 Epicure Electric Double Oven
Oven Lock stuck open before start of self-cleaning cycle
Sounds like you bent the door where the lock is. You might have to replace the door.
Mar 12, 2009 | General Electric Stove/Oven/Range Chrome...
Oven Door is locked and will not open
On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. Pull or push the rod to move the lock to the open position..
Jun 06, 2008 | GE JBP70SKSS Stainless Steel Electric...
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Jun 05, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Tappan electric stove designer series
the cleaning light and the lock door light doesn't go on when I set them to self cleaning and lock the door what should I do
Nov 17, 2007 | Tappan 30IN ELEC IGNa Oven
Tappan MEF500 Electric Kitchen Range Logo
55 people viewed this question
Top Tappan Kitchen Ranges Experts
Paul Carew
Sal De
Archie Ferrarini
Archie Ferrarini
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
