Question about Sony KP-53HS10 TV
Sony kp53hs10 we have a Sony 53" model KP53HS10. It turns on but there is no sound and no picture...Can't be that bad right? Please help!!
    Problem Solver:
  • 6 Answers
Try (with your remote) hit Display + Channel 5 + Volume - + Power hit each key within 1 sec of each other and the tv should go into error check mode on the screen and display some data, record that and google.
Mike
Posted on Mar 01, 2009
Sony kp53hs10 stand flashes
If your using composite video with the red green and blue, make sure the green and blue wires are connected to your TV right and not reversed.
Jan 11, 2014 | LG Televison & Video
It just keeps blinking in stand by and it wont stop kp53hs10 sony 53 inch tv
I have the same problem- please help- no power- just continuous blinking- tv 10 tears old
May 24, 2011 | Sony KP-53HS10 TV
Flashing "Standby" light??????
KP53HS10, NO PICTURE OR SOUND , ONLY A CONTINOUS BLINKING RED LIGHT ON CONSOLE. CAN YOU HELP ?
Nov 12, 2009 | Televison & Video
No picture
first of all sony uses blinks as a means of an error code, on older models like yours could be weak CRTs, try turning up the screen controls a little, if the picture comes on the CRts are weak and AKB is holding them dark. the controls are in the front behind the cover.
possibly you have no high voltage, D board or splitter is bad, bad convergence ICs will cause NP, check the 3.15amp fuses if any are blown replace ICs both stk392-110 and fuse to fix.
Jul 31, 2009 | Sony KP-53HS10 TV
Sony projector kp53hs10
I recently had this same issue. If you remove the speaker pannel in front of the set, you will see a block with 6 knobs on it, just to the right of the center panel. This is called a focus block. 3 knobs on top which control the voltage going to each tube, and 3 on the bottom are for fine tuning focus for each tube.
If your problem is the same as mine, it is a convergence problem. and due to the fact that the picture is turning off, says that one of the tubes is not getting enough power.
NOTE: BE CAREFUL NOT TO TOUCH ANYTHING ELSE BUT THE FOCUS BLOCK, THERE IS EXTREMELY HIGH VOLTAGE WITHIN THE TELEVISION, AND CAN CAUSE SERIOUS INJURY.
1. Make sure the screen is blank, ex video 2 with nothing on. It's easier to tell.
2. very slowly, one at a time turn up the knob on the left top, should control red, untill you start to see lines come on the screen, then turn back just till they dissappear, and you see a black screen again.
3. continue with the second knob on top, just the same as the first.
4. And continue with the 3rd knob on top right just the same.
5. when you're finished, turn off the set, then back on, let is set for a min or 2, then hit the FLASH FOCUS.
If the problem persists, it most likely is a IC chip.
Best of Luck
Ken
Nov 20, 2008 | Sony KP-53HS10 TV
KP53HS10 power supply board
you can check here or leave a post that you are looking for one
http://www.tv.quuq.org/forum/index.php
electech
Oct 23, 2008 | Sony KP-53HS10 TV
I have sony 53 Projection TV Model No KP53HS10
First check the batteries in your remote. if that doesn't work check the setup menu. see if you have any kind of auto on\off, alarm, snooze or enabled. some of Sony's tv's had these features
Oct 08, 2007 | Sony KV-32CS70 32" TV
Blurry picture
I Just had the same problem with my Sony KP43HT20, was a blury picture with the red & green going bad.......My set had defective convergence IC's, they are known to go in Sony's..IC's run about $30 a piece. Good Luck.
Nov 26, 2006 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
186 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
