Question about KitchenAid KGRT607 Gas Kitchen Range
Oven section not working
I purchased the Gas Kitchen KGRT 607HS8 back in Autumn 2001. After some issues with the oven not working, the store(SEARS) changed it and gave us a new one ( we were not told what went wrong) in Summner 2002. For the past 4 and a half years,it was working perfectly until last Christmas when I noticed that sometimes when I turn on the oven, it does not heat up. So instead of cleaning it every month, I clean it every 2/3 weeks depending on whether I have been roasting meat or not and after I have experienced that the oven does not come on after I turned it on. Last night I experineced the same occurence, turn on the oven, wait for it to reach the temp but it remained cold and I could smell gas. I cancelled the whole thing and restarted the oven and I managed to get a hot oven. This morning I started the cleaning cycle ( 3.5hours) . After 45 mins, I heard a beep and i saw that the cycle has stopped and there was F5:E5 on the display. I restarted the cycle again and i could smell the gas. The cleaning cycle stopped again after 45/50 mins. I went through the whole procedure of restarting the cleaning cycle twice but I gave up when I heard the beep and saw the F5:E5 display ( and nothing was cleaning inside ). Would appreciate if someone can explain to me why this is happening before I call the serviceman from Sears. Thank you in anticipation
  • narrima chummun Apr 11, 2007
    Spot on Catriver. The bake ignitor was drawing only 2.4 Amps. So it was changed and now it is working. We replaced also the broil one at the same time.
    Thank you very much.
    President:
  • 878 Answers
Beaver, the F5-E5 is the code for self clean temp not achieved after 30 minutes. This makes sense since you are having trouble pre-heating your oven on regular bake. I believe your ignitor is not drawing enough amps to open the gas valve all the way. Sometimes these can be erratic, work sometimes, sometimes won't. Your part number for the oven ignitor is 9782065. Catriver..post back.
Posted on Apr 07, 2007
Just delivered from store. Two burners on left side and oven are dead.
Alex,
If this is a brand new oven then you need to call the store back & have them come check it. It will be under warranty & they can check to see if it is a stove problem or a power problem from your house power. If it is a used appliance, I would still call the store you purchased it from to see what they can do for you.
Apr 09, 2015 | Thermador PRG366GH Pro 36" Gas...
Kitchenaid Model KGRt 607HWH6 won't heat.
I assume you mean the oven. The oven igniter is probably bad if it is a gas model.
Sep 26, 2014 | Kitchen Ranges
KitchenAid Gas Range Model KGRT: Oven temp won't go past 260 degrees. When a higher temp is typed into keypad, it gives me an "err" mesage.
replace the oven safety sensor located in the upper left corner of the oven cavity,its merely a thermocouple and cycles the temp in the oven and is easily replaceable,its a whirlpool part # AP3083985 available from most appliance parts stores that handle whirlpool parts,as this unit is produced by whirlpool corp. for kitchenaid corp.
Mar 27, 2011 | KitchenAid KGRT607 Gas Kitchen Range
How to adjust oven temperature?
Typically, if there is no LCD display, the oven gas knob has the adjustments on the back of it. Just back off the screw and adjust it 10 degrees at a time, using an oven thermometer to verify accuracy.
May 22, 2010 | Sears 61301 Gas Kitchen Range
Oven racks for Maytag CWE 9000 ACB
HI, simply click on the link provided below to be directed to the purchase page. You can order your new replacement rack on-line, if you wish.
CLICK HERE-OVEN RACK PURCHASE PAGE
Nov 07, 2009 | Sears 61301 Gas Kitchen Range
GE 30" Gas Freestanding Stove Model #JGB290MENBS. The control panel on top has gone out and cannot use oven. Can still use cook top. Is there a reset button. We have had this stove 6 months.
There is no reset button. First, unplug the range, and plug it back in after 5 minutes. That MAY reset the control, if not, the control will need to be replaced. If the range is less than a year old, it should be covered by the factory warranty (unless it was purchased a Sears store).
Sep 17, 2009 | Kitchen Ranges
Gas over not lighting
It is likely that the ignitor needs to be replaced. If the range does not sense the proper amount of resistance in the ignitor, it will not turn on the gas valve for the lower burner. If the broiler is still working, it would further this thinking, as it has a separate ignitor.
Sep 14, 2009 | KitchenAid KGRT607 Gas Kitchen Range
How can I purchase an extra oven rack for my 790 gas range
Go to one of the following web sites:
Searspartsdirect.com
Appliancepartspros.com
Pcappliancerepair.com
Repairclinic.com
All these sites offer great service with competitive pricing. Use the model number from your range (located around the oven door, or lower drawer opening) for your search criteria.
I ordered addtional oven racks for my gas range using one of these sites. Since prices can vary, shop each one for the best deal.
I hope this helps you.
Jul 21, 2009 | Sears 61301 Gas Kitchen Range
Oven thermostat - schoenberger gas system 1975
Will need to find the correct model # somewhere on the range then go to www.appliancepartspros.com or www.www3.sears.com and you will find it there. I found thermostats on those sites for a model # close to yours and most likely the same one. Sears was about $72 and appliancepartspros was about $78. Hopes this helps.
Oct 08, 2007 | Tappan TGF320 Gas Kitchen Range
KitchenAid KGRT607 Gas Kitchen Range Logo
299 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Jacques Valiquette
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
