Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub zero 550 refrigerator light not working
My Sub Zero refrigerator light is not working. I checked the owners manual and it says the possible problem is the door was not shut properly, which may have been the problem, however I followed their instruction, waited the 1/2 hour & still no light. I also replaced 2 of the 4 bulbs...still no light
  • 1 more comment
  • pat9399 Dec 29, 2008
    I have the same problem--and when I replaced the bulbs, the light worked intermittently for a while. I think it is the door switch--how to repair/replace? There is no Sub-Zero repair person in my state, apparently.
  • Anonymous Jan 19, 2009
    i had the same problem , remove the top cover where the compressor is housed . you will see two door switches the one on the left is the light switch , unplug the two wires going into the switch and place the 2 wire ends together if your light goes on its the switch . It cost me 12 $ canadian for one and its a easy repair anyone can do
  • my3mjms Mar 25, 2009
    i have the same problem, all lights on top are not working. Does anyone know what is causing this problem?
  • 71 Answers
First try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Posted on Dec 24, 2008
Side by side Sub Zero light switch works intermittently.
I had the same problem with my sub-zero and finally resolved it (much to my wife's delight) by just replacing it. R&R was a lot simpler than having to work on it every time my wife had a problem.
Dec 14, 2011 | Sub-Zero 690 Side by Side Refrigerator
I HAVE A SUB ZERO 550 . THE LIGHT SWITCH ABOVE THE DOOR ISN'T WORKING. TO TURN ON THE LIGHT I NEED TO JIGGLE THE PLUNGER SWITCH. DO I NEED A NEW SWITCH?
Probally do need a new switch, you and try spraying like wd 40 arould the plunger and working in in and out. Hope this helps. Wally
Oct 09, 2011 | Sub-Zero Bottom Freezer Refrigerator
I have a Sub-Zero Model 550 whose freezer does not get very cold even though the set to 10
set freezer for 0 deg and clean the coils on top . and make sure the fan up top is working . very important .. mm 550 are r12 and may be low or refergent . this is somthing you may need a service tec to ck but do the cleaning first and see how it works. mm
Sep 03, 2010 | Sub-Zero Bottom Freezer Refrigerator
We replaced all of the light bulbs in our 550 and the lights still do not work, any ideas?
Most likely light switch is bad. Could be light limit t-stat (prevents from overheating) and wiring problem too.
Sub-zero refrigerator repair in orange county, ca
Feb 06, 2010 | Sub-Zero Refrigerators
Sub-zero 550. freezer icing
You probably have some food on the way. Unload the freezer and see if the door would close better. Looks like you have a warm air leak.
appliance repair orange county, ca
Feb 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
Freezer not working on Sub-Zero 550 Refrigerator/Freezer
You probably need to defrost freezer - frozen moisture possibly stockedevap. fan motor in the freezer. Turn it OFF for 24 hours and start itover. Make sure no moisture condensation on the freezer compartmentsurfaces as walls and shelfs. If so wipe it out. Pull out and remove upper basket from the freezer, push fan switch which is located almost under ice maker.You have to hear evaporator fan motor start working. Still not work? Call to professionaltechie! Good luck! :)
______________________________
http://www.SubZeroLosAngeles.com
Nov 11, 2008 | Sub-Zero 650 / O Bottom Freezer...
How do i install the grille on my sub-zero 550?
Check grille springs. It should be a springs clips on the grille...
HTML clipboard_______________________________
http://www.subzerolosangeles.com
Los Angeles Sub-Zero refrigeration experts
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 550
You probably have a freon leak in the evaporator coil.
Nov 01, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
3,685 people viewed this question
Top Sub-Zero Refrigerators Experts
Sal De
John Tripp
John Tripp
Steve Allison
Steve Allison
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
