Question about Samsung Digimax S500 Digital Camera
Camera turns off when shutter button is pressed.
My MIL has a Samsung S500 about 2 years old. Recently she has been unable to take pictures at times. I looked at her camera and could not find anything obviously wrong with it. It appears to have issues in low light settings the most. When the shutter button is pressed the camera simply shuts off instead of taking the picture. It can be turned back on right away.
    Guru:
  • Samsung Master
  • 695 Answers
[source]Question about Samsung Digimax S500 Digital Camera[/source]
Try replacing batteries (high Ah photographic type).
The lens motor & electronics may be draining power if Ah capacity has dropped too low. At night, it could be that your flash is trying to fire (another drain), or shutter timer / mirror staying open longer.
Posted on Sep 20, 2017
jackboy
  • 2985 Answers
SOURCE: My camera will not take photos
'I have opened the camera up and looks OK' How can you tell? what you have done is negated any chance of as repair or replacement. But a new camera?
Posted on Aug 01, 2007
SOURCE: My camera seems to short out and there are horizontal lines in the pictures.
I have one that is doing the same thing.
Posted on Dec 22, 2007
Gwenivie
  • 39 Answers
SOURCE: Autofocus not working
When the camera is OUT OF FOCUS, these are the steps that you could try:
1 Power Reset
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
2 Distance
- When the distance between the camera and the subject is too close,
the strength of the light can cause the picture to overexposed and
be blurred. On the contrary, if the distance is too far,
the beam is too weak to shed enough light on the subject.
Allow yourself enough space between you and your subject.
3 Shutter
- If you press the shutter before the flash is fully charged,
the flash will not be able to emit enough light and therefore
the image can be blurred.
4 Surrounding Light
- Use the fill-in flash mode to create a balanced shot when
the surrounding light is very bright.
5 Backlight
- Use the backlight control feature when the background
is brighter than the subject.
6 Cleaning
- Clean the lenses with a smooth piece of cloth.
7 ASR (Advanced Shake Reduction)
- Put in ASR mode to prevent any blur
8 Master Reset
- Press on MENU button
- Press on the right button until you see SETUP
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds for changes to be saved
* If it still does not work, you need to send the camera for repair.
Just contact the Manufacturer so they could tell you how to send camera safely.
Posted on Jan 19, 2008
SOURCE: samsung s 500
same as above.
Posted on May 07, 2008
Tyranny
  • 21 Answers
SOURCE: Lens stuck after dropping camera
Probably it can be fixed, but if the lens gears are too damaged the repair could be much expensive and you would prefer to buy a new one.
Take your camera to a qualified technician to check the price of a repair.
Posted on May 24, 2009
The shutter of the camera is not closing
Do you mean when you press the shutter release button, oohing happens?
Are you sure you are giving the camera enough time to focus, before you press the button complete?
Normaly, you have to press the button half way, and wait till the camera is focused. The camera will give an audio or a visual signal. Then press the button complete.
Be patient. Point an shoot camera's sometimes need more than a second to focus.
It is not like in the old days, every time you pressed the shutter release button the camera fired.
May 12, 2014 | Samsung TL205 PL100 Digital Camera
Shutter clicks ever time I press a button & it won't take pictures
I had this problem this afternoon, and it resolved itself when I took the memory card out. It's been fine so far, all working as normal again! :)
Apr 16, 2012 | Pentax Kr Digital Camera
My camera hasn't been used for over a year or two now and the reason being is that when you press the shutter release button ...it makes the sound for half press but no matter how hard you press the button...
So the camera is at least two years old- that means it will cost more to repair than it would to buy a better new camera. Prices have been falling and specs rising dramatically, so don't throw money at this old camera. Sell it (as faulty) on eBay, and someone will buy it for parts to fix their old camera (some people just like a challenge).
Jan 27, 2011 | Fuji FinePix F20 Digital Camera
Hi Experts, I bought an Olympus C170 camera 6 years before. It was good... recently due to some problem Technicians changed Lens in my camera.. Now the problem is I feel some delay time while I am...
When taking a picture, you must press the shutter button half-way and allow the camera to lock in the focus (it will beep) and then press the rest of the way when the moment is right for an instant picture. Is that what you do?
Oct 12, 2010 | Olympus Camedia D-425 / C-170 Digital...
Describe how to use the self timer on the samsung S830 digital camera
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Jan 11, 2010 | Samsung S830 Digital Camera
Delay/unable to snap pictures
Are you pressing the shutter button half-way and giving the camera time to lock in the focus before pressing the rest of the way?
Sep 17, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Displays icons but won't register pictures
First make sure that you accidentally didn't turn off the screen by repeatedly pressing the DISP button to cycle it on and off. If that didn't fix it, and if your camera is less than 1 year old, call 1-800-OK-CANON to arrange free warranty repair.
If your camera is more than a year old, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 03, 2009 | Canon PowerShot SD1100 IS Digital Camera
Does camera have timer
Putting Yourself in the Picture The Self Timer creates a 10-second delay between the time you press the Shutter button and the time the picture is taken. 1 Place the camera on a flat surface or use a tripod. 2 In any Still mode, press the Self Timer button. The Self Timer icon appears in the status area. 3 Compose the scene. Then press the Shutter button half-way and hold to set the exposure and focus, then press the rest of the way down. Move so that you are in the scene. The Self Timer light blinks slowly for 8 seconds (then quickly for 2 seconds) before the picture is taken. The camera "clicks" when the picture is captured. To turn off the shutter sound, see page 64. The Self Timer turns off after you take the picture or if you change modes. To cancel the Self Timer before the picture is taken, press the Self Timer button. (The Self Timer setting remains active.) To turn off the Self Timer, press the Self Timer button twice.
Jan 09, 2009 | Kodak EasyShare DX6340 Zoom Digital Camera
1 Power Reset
- Turn off camera
- Reload batteries
- Turn on camera
2 Distance
3 Shutter
4 Surrounding Light
5 Backlight
6 Cleaning
8 Master Reset
Dec 26, 2007 | Samsung Digimax S500 Digital Camera
Auto is stuck on and I can't zoom in or out or review pictures - shutter button stuck also
Being very careful, follow this pictorial disassembly (it's in Estonian, but just follow the pictures). Don't go any further than popping the top off the camera! Look for anything obviously broken off near the vicinity of the shutter button, or looking very different than what's in the pictorial. Keep in mind it's amazing what you can do with a little glue and scrap pieces of plastic:
http://qman.fotokala.ee/Kaamerad/PowerShotA95/index.html
Also, pay attention to the following post as there is some potential for electrical shock:
http://camerarepair.blogspot.com/2007/11/important-warning-camera-flash.html
Oct 19, 2007 | Canon PowerShot A95 Digital Camera
Samsung Digimax S500 Digital Camera Logo
53 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
