Question about Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool leaking water thru soap dispenser when off.
How to repair or find the problem where do i check.
  • Anonymous Dec 23, 2008
    where is the tube located i only see dispenser area
  • ddc1440 Dec 24, 2008
    Fabric softener dispenses prematurely. A&E was dispatched twice, the 2nd time they replaced the entire dispensing unit and instructed us to 'close' the door very slowly. Come on now.....tried it and same result as above. Is it in the overall engineering and what can be done about it?
    Genius:
  • 1,028 Answers
Remove dispenser and clean next ck tube from dispenser to tub be sure it is clear
Posted on Dec 22, 2008
Water is leaking out the soap dispenser.
Remove the soap dispenser and clean it throughly, next check the tube from dispenser to the tub to be sure it is clear of blockage. Run the washer with hot water to clear any residual buildup that may be left in it.
Jan 06, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Water is pouring out of the soap dispenser onto the floor. how to resolve this problem?
sounds like the dipencer hose came loose.
Unplug & remove screws along top of washer in back.Lift up & remove. You should be able to access issue from there
Mar 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking/pouring water out of soap dispenser
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet leaks soap from dispenser and side of machine at start of wash cycle
Oct 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Jan 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Can i adjust the water level on my Duet?
Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water overflowing from dispenser, no error codes
check the holes of the dispenser, could be clogged with soap and liquid detergent. check the hose where the dispenser flows to the drum, it could be clogged also. open the door, trace the dispenser hose that is attached to the drum or to the big rubber gasket at the front. check and see if there is dirt accumulation or soap clogging the hole.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from soap dispenser front loading washing machine
water leaking from soap dispenser. so water pours out under the soap dispenser
Apr 19, 2008 | Whirlpool Washing Machines
Leaking...
Normally you shut off the wall valve when you are thru with your washing. If there is a leak in the front area (important: first take the plug off the wall) open up the top of the machine and check whether the three rubber tubes are in place at the soap dispenser - one of them may have come off. Refit or replace if rubber tube is damaged; would be good to check all the tubes. Another thing would be to check that your soap dispenser is not clogged. :)
Sep 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
646 people viewed this question
Dan Webster
Dan Webster
Sal De
