Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
How do I find the drain hose/plug on a 1996 kenmore refrig.
Keep getting water on the bottom of the refrigerator under the crisper bins. Model # 106.9759725
  • 3 more comments
  • chubbyalex Dec 29, 2008
    i have a 2000 kenmore top freezer #1066096290, water drips from inside top of refrig by air diffusser and collects at the bottom, is there a easy solution.
  • msways Dec 30, 2008
    I have the same problem- water seems to come from the top of the frig. and drips down- steady dripping when defrost cycle.
  • phuket75 Apr 16, 2009
    water drips from the fridge roof, collecting on shelves, on top of food, inside krisper drawers, etc.
  • jenkava May 01, 2009
    So the refrigerator is leaking down the back, pooling water on the shelves and under the crisper bins. I squirted hot water around the area that was frozen over, but the rest of the mechanism is under a large piece that is screwed into place (my fridge is from 1999.) Should I unscrew the entire unit? I have not found the tray that is mentioned that collects water and I am guessing it is under that plastic cover.....
  • msways Oct 10, 2009
    Whirlpool upright freezer-model EEV151N is running but not keeping things frozen inside. Making a whirring noise louder than usual. It's at least 24 years old.
  • 93 Answers
If you open the fridge door in the top you will see a small funnel typy that goes tru your back wakk this is where it normally cloged pull it out if no screws that hold it then clean it out or blw tru hose in the back of fridge if you can get access to it thanks from gille
Posted on Mar 15, 2009
Refrigerator leaking
this means that when the refrig goes into defrost depending on the age either the hole for the water to drain out after defrosting cycle is plugged and needs to be thawed out and blown out with compressed air of if the water drains out under the crisper droor or behind the crispers the drain is plugged there. it could also be a drain heater problem. dont know age of refrig.
May 26, 2012 | Hotpoint Refrigerators
Our refrigerator is getting a pool of water underneath the crisper bins. We do not have the ice maker hooked up. Water drips down and freezes into ice on the bottom of the refrigerator inside. I am not...
water is coming from the defrost cycle and is not making it to the drain pan on the bottom. try cleaning the coils and if you can locate the drain that goes to the pan and blow in it this will clear it out. thank you.
Apr 25, 2011 | Kenmore 64802 Top Freezer Refrigerator
Water comes off somewhere in the bottom of my fridge. what could have caused it?
When your refrig goes into defrost , the water runs down the back of the refrig ( inside ) and out to the drip pan thru a drain hole under the crispers . If water is under the crispers , remove the crispers and you should see a " cap " covering the drain hole . Sometimes crud will cover the slots where the water is supposed to drain , causing water to pool under the crispers . Just remove this cap , clean , and reinstall .
Mar 20, 2011 | Magic Chef Refrigerators
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Kenmore Cold spot refrigerator model 106 70182001 leaking inside in the back of the refrigerator. Having to keep bowls in the back of the top shelf. How can I fix this?
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Dec 12, 2009 | Cars & Trucks
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Periodically leaks water
check to see if your drain line is plugged look under crisper bin
May 02, 2009 | Kenmore 64802 Top Freezer Refrigerator
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refrigerator with freezer on top leaks water into refrigerator area. My appliance repair man said it is due to the discharge line freezing and is a common problem with that model. I need to...
The drain line that comes through the casing may be plugged or the trap at the bottom of the hose where it drains into the drain pan under the refrigerator may be plugged. If water is freezing it is because it is being held back by a restriction.
May 08, 2008 | Refrigerators
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
360 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
