Question about Maytag MER6772 Gemini Electric Kitchen Range
Top panel shows sABath
When pushing controls on top panel nothing happens.
  • 61 Answers
Someone has put the control into the sabbeth mode the oven will not work until you clear this from the control. The info to clear is in your use and care guide if not contact the manufacturer and they can help you. good luck
Posted on Dec 22, 2008
While cleaning the inside drum and turned the drum by hand. She heard a "loud noise" and will not turn. The control panel will come on andselect the mode, but when start is pushed nothing happens.
When you rotated to drum you caused to belt to pop off the pulley .it has a safety switch so it won't run if belt breaks . With unit unplugged remove top than control panel than front panel to access bottom to put belt back on just enough room for hands to fix inside
Mar 26, 2016 | Samsung DV218AEW Electric Dryer
I have power but the lights and pumps do not work when I push the control panel buttons
When you unplug & reconnect the topside control what happens?
If nothing your control is bad, you'll need a new one.
They are typically attached with double sided tape so removal is easy.
Nov 12, 2012 | Pool & Spa
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Time showing on panel. No functions work.when I touch any button,
You can try to reseat the serial ribbon but it sounds like a board problem. to reseat the ribbon, unplug unit. remove the case for counter top models, otr models need to remove the grille, and the control panel screw, lift up and pull out at the top. the serial ribbon is a flat set of wires at the top of the board lift on the connector latch to loosen the ribbon pull it out, push it back in and relatch. close up the control panel before plugging back in. if it works great, if not it is time for a new microwave boards are very expensive.
Jun 19, 2009 | Microwave Ovens
MY RANGE jennair THE CONTROL PANEL BEEPS BUT NO LIGHTING
Control is bad and needs replacing. NO way to repair it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag MGR5751AD Gas Kitchen Range
Beeping and Frozen, 44 min
If it is a Calypso, abandon it immediately... it is amazing you still have it. One of the worst designs, ever. Whirlpool Washing Machine Drain Pump 285990 No Longer Available
Apr 23, 2017 | Whirlpool Calypso GVW9959K Top Load Washer
Front Panel Buttons not responding
The touch control panel is a piece of ****! Call MAYTAG, and get a new one, you should still be under warranty. Make them send you the part direct ( its the WHOLE front top panel ), then call a tech to put it in for $50 bucks. Takes about 10 minutes to do. The panel plugs into the electrical Board behind the panel.
FYI...the Top panel includes the Stainless Panel + the Touch controls! Its all one integrated part. The part that goes bad is the "cable contacts" that latch to electrical panel.
FYI....the Cable is made of "thin clear film " similar to Film you put in a Camera.
Jun 19, 2008 | Maytag MEW6530DDS Stainless Steel Electric...
My dishwasher control panel does not light-up
This is a common problem. I am about to replace my second control panel in two years. First time was under warranty and I hope this time will also e under warranty.
Jan 21, 2008 | Maytag MDB9750AWS Built-in Dishwasher
Kenmore range 655
it is what is called sabath mode. it locks out the controls and lights ect. check your manual and it will explain how to deactivate the sabath mode for that particular range. good luck.
Aug 17, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Maytag MER6772 Gemini Electric Kitchen Range Logo
98 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
