Question about Kenmore 24 in. 15932 Built-in Dishwasher
I have a Sears Kenmore Elite Ultra dishwasher 665.1315 model. For the last 3 weeks, it keeps having the clean light blinking 6 times pause then 1 blink and pause and repeats cycle again. I have turned off the breaker...I have reset by pressing the heated dry and normal wash until all lights are flashing. It then completes some type of cycle and looks ok. When I opened the door, steam came out and all was hot inside. However, once I try any new wash cycle, it seems to wash but after 1-2 hours and I believe as it wants to rinse, the clean light blinks again same pattern. I always run hot water in kitchen sink before using the washer, so I don't think it is a water heat issue. I have called Sears tech but they have cancelled 3 times in the 3 weeks. So much for service. Any help would be appreciated.
  • bob_iacono Dec 23, 2008
    As I mentioned, I did call Sears and they ave cancelled 3 times on me due to truck and ice issues. I believe since dishwasher is not considered an emergency candidate appliance, I keep getting bumped off. I am looking for answers as to where problem could be and whether it can be reset somehow. I am worried that once Sears does pay us a visit, he will see the 61 code and tell me it is blahbalhblah and part is backordered and wait another month. I find it surprising that I wasn't even asked about the code.I did look around for certified technicians that could come within few days, but was told that if i use them, then my 5 years warranty is null. So much for service.
  • rf07828 Jan 19, 2009
    I have exactly the same problem and the machine is new.
    Sergeant:
    Champion:
  • 338 Answers
Call sears service and tell them you need service there is a service flash and will be no charge
Posted on Dec 23, 2008
  • Robert Artiaco Dec 24, 2008
    ok well usually it is not sensing a temperature change in the water or not getting hot enough. so you can reset the dishwasher and try running the hot water in the sink before starting the dishwasher. if it fails again there is a service flash replacement kit for the heater and the control board. The heater has been redesigned to go over the thermostat and the new control is to help power the higher wattage element. the service flash number is sf22-799 and the part number is probably going to be 22 - 665- 8264900
Blinking clean light, not completing cycles
some of the dishwasher have a device in them that you have to remove the container and clean it. mine is up side down cup that unscrews.
go to www.wikipedia.org
kenmore elite blink clean light
or go on to www.sears.com/service
talk to someone or look on line at
www.youtube.com/kenmore_elite_blinking_clean_light
see if anyone else had this issue
Mar 25, 2015 | Kenmore 24 in. Elite Built-In Dishwasher...
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Jan 18, 2015 | Kenmore Dishwashers
Kenmore Ultra wash mod.# 665-77963K703. normal wash light flashing. How do I reset.
How many times does it blink before pausing and repeating? 7 times? (That's a common problem - means "water not heating" error.) In some dishwashers, instead of pressing Heated Dry, Normal Wash, Heated Dry, Normal wash, you press the 3 left-most keys in the following order: 1, 2, 3, 1, 2, 3, 1, 2, 3. That will start the diagnostic cycle and clear the error, but if you don't find and fix the cause, the problem will come back the next time you run the DW. But before I try to explain how to fix the root cause, I would need to know how many times the light is blinking.
Jan 09, 2015 | Kenmore Dishwashers
What does it mean when my clean light blinks but I cannot cancel or reset it
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller.
Jul 21, 2014 | Kenmore Dishwasher With Ultra Wash And...
Dishwasher wont finish any cycles
That blinking light is trying to tell you that there is something wrong with the dishwasher. You need to fix the problem or else that blinking light will come back. And the number of times it blinks (before it pauses and repeats) will tell you (or a technician) what is wrong. How many times does it blink?
Jul 04, 2014 | Kenmore Dishwashers
The clean light on kenmore dishwasher elite keeps blinking and will not stop
That blinking light is trying to tell you that there is something wrong with your dishwasher. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff or thermostat, a bad controller, or a problem with the door latch and/or switches. Usually there is a tech-data sheet located on the other side of the toe-kick panel which will explain the meaning of the varius blink codes, but you might still need to call a technician to fix the problem. Don't forget to put that tech data sheet back so he can find it and use it to fix your dishwasher!
Dec 16, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Clean light keeps blinking and I can't start a new cycle
That is a comon problem with that model. It is not sensing a temperature change in the water.
Push i believe it is heated dry and sani rinse going back and fourth between the two to clear the code and see if you can get it to complete a cycle. If it doesnt call sears and schedule service there is a service flash repair that should not cost you anything to repair the unit.
Nov 13, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Puppa, clear the fault by pressing the keys in this order: high temp scrb--air dry--high temp scrub--air dry. Or, depending on your model..Sani rinse--air dry--sani rinse--air dry. The dishwasher will enter the service mode. Let it do it's thing or advance it through it by pressing the start key. The fault came from the board not sensing a rise in the water temp. Make sure to run the hot water before starting the dishwasher. The heating element runs through the nuetral side of the door switch so make sure the d/w is level and the door switches are all making. The element itself could be at fault. Catriver...post back
Apr 01, 2007 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
657 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
