Question about Brother IntelliFax-2820 Laser Fax
Can't receive fax
It just ring, ring, ring, but no fax come thru. Please email me solution. AndreGotMail@aol.com
  • Andre Bravin Apr 07, 2007
    NO, if a press the start button, it just stop ringing, but still no fax.
  • 186 Answers
Pick up the receiver and see if you hear a fax tone noise. If so then push the start button and hang up. Is this machine on a dedicated line or shared with the main phone number? Sometimes some people will pick up the receiver on their fax machine dial the fax number and wait for a tone before sending. If this is the case the machine can not recognize that is a ax. Make sure your machine is set for auto receive if it is on a dedicated line.
Posted on Jun 30, 2007
SOURCE:
I can't receive AOL email on my EVO phone. It was working fine and I wiped the system in error. I reinstalled gmail and my aol account, but nothing shows up in the inbox. I can see sent mail, but no...
i cannot receive emails thru my aol account on my HTC Evo phone. It was woking fine and all of the sudden it stopped receiving new emails. please help!
Jun 16, 2010 | Google Android
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
WHEN A FAX IS TRYING TO COME THRU, IT RINGS, THEN BEEPS AND SAYS "RECEIVE ERROR"
There may be some static on the phone line, try a line filter. If possible, you could plug the fax into another working telephone line, and have someone send a fax to that number (whatever number is attached to the new phone jack) to isolate whether or not it is the machine, or the wall jack.
May 20, 2009 | Samsung Office Equipment & Supplies
My fax machine will send faxes but not receive them. I have made sure it is plugged in and connected but no faxes will come through. Please Help!
If you have an answering machine, have it answer at three rings. Have the fax answer at five rings. Let the answer machine go thru it's cycle, and see if the fax picks up.
Apr 27, 2009 | HP 1220 Plain Paper Inkjet Fax
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
BROTHER MFC 240C DEFAULT TO FAX PRINTING
We moved from 561 to 772 area code. Now we can not receive faxes. What do I need to do?
Did not have an issue receiving faxes at the old area code: 561
please email with resolution:
purplegem0713@gmail.com
Thank You....
Aug 10, 2008 | Brother Multi-Function Center MFC-240C...
FAXING
right click on the for the printer, Left click on 4200 ALL IN ON CENTER (top). Look at the top right hand corner and you will see FAX UTILITY, go thru those steps. Email me if you are still having problems. burpo01@aol.com
May 07, 2008 | Lexmark X4270 All-In-One InkJet Printer
Fax receive problem
hi
i had same prblom, now it fixed
1-press(set up)3 times you will see on the screen(basic fax set up)
2- press enter
3- Click the right arrow utill you find (ringe to ansure)
4- press enter
5-than chose how many rings
6- press enter
7- good luck
Apr 25, 2008 | HP PSC 2210 All-In-One InkJet Printer
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
MANUAL
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
FAX ONLY
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
FAX/TEL
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
TAD:ANSWER MACH.
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
only
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
do
not
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Brother IntelliFax-2820 Laser Fax Logo
315 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
