Question about Microsoft Windows XP Home Edition
20-60 windows pop up?
When I start the computer and then click on any program/application that will come up on my computer about 15-60 times. With one click I will probably get about 20 windows and when I double click.. well it's more. When I go to the start menu my mouse will click automatically on anything the cursor is over. The strange thing is I have figured out how stop this from happening. Before I click on anything when I first start up the computer I hit any key on my keyboard and then the mouse starts working perfectly, everything is back to normal. I have scanned with mcafee (nothing comes up), avg, privacy guard, adaware. I found a few tracking cookies on avg but I think they are harmless. Thanks for any help! (:
  • 3 more comments
  • hennes9_1 Dec 22, 2008
    I just switched mouse, did not work.
    USB, its in the back of the computer.
    just to clarify when I switched the mouse it did the same thing as before. The mouse works but still does funny stuff as before. Not literally the mouse did not work. Sorry bad communication. I am trying that link you gave me.
    did the scan nothing came up
    Problem Solver:
  • 5 Answers
Try switching the mouse.
the left click switch might be surging.
Posted on Dec 22, 2008
Nothing happens when rebooted
If you a downloading for free check a youtube tutorial if that doesn't work buy it.
Jul 10, 2013 | Empire Interactive Taito Legends
Tip
How to Make Windows XP Startup Faster Steps 1.Click on Start, then Run, and type...
Steps
1.Click on Start, then Run, and type "msconfig". Wait for a new window to pop up.
2.Look under the "BOOT.INI" tab. You will see a box labeled "Timeout:", and a numerical value. By default, it's 30, which means 30 seconds of wait time before boot. This can be changed, using 3 seconds. (Note: if you have more than one operating system, this means the wait time to startup to the highlighted OS. you might want a bit more than 3 seconds)
3.Delete the temporary files periodically from your computer to make the applications run faster. Type %Temp% in the run dialog box by clicking on Start -> Run, and click on "OK". You will see an open folder with many files. Click on the Edit menu and click on Select all and then click on the File menu and select Delete. Note: Always confirm that the folder which is opened has a temp on the top of menu bar and the folder indicates that it is a temporary folder.
4.Perform a scandisk to see that your computer hard drive is in healthy condition and it helps your computer run faster.
5.Always perform a disk defragmentation at least once in a month. start the disk defragmentation from the system tools available in the accessories from the start menu. it takes a longer time and it is advised not to run any applications in the computer including the screen savers, while running disk defragmentation.
Hibernation
After you have done all this, another method you can do is to allow the computer to hibernate. Hibernation closes and opens Windows faster than normally. However, Hibernation is a good long-term solution, as it does not waste electricity.
1.Go to Start->Control Panel->Power Options. Click on the Hibernate tab.
2.Click on the box that says "Enable hibernation" to check it.
3.Click on the Advanced tab and change the Power buttons options if you want to hibernate by pressing the sleep button or the power button. Otherwise, holding the Shift key while in the Turn Off Computer menu will give you the option to hibernate.
4.Restart your computer every week or so to clear your computer.
The power can then be completely turned off, even at the socket so that no power is wasted.
Prefetch
1.Simply browse to the windows folder (Ex: C:Windows) and under there you should see the prefetch folder. Go into the prefetch folder and delete all the files (Careful! It should look like this c:windowsprefetch). We need to edit a registry key to tweak it. Open regedit and browse to this key:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlSession ManagerMemory ManagementPrefetchParameters
Under this key you should see a value named: EnablePrefetcher
It has 4 possible values:
0- Disabled : The prefetch system is turned off.
1- Application : The prefetch only caches applications.
2- Boot : The prefetch only caches boot system files.
3- All : The prefetch caches boot, and application files.
We don't want to disable it entirely. This would actually make boot times *longer*. This is because this feature is also used to speed up the loading of boot files. That is why we are going to pick the number 2 option. It allows us to keep the advantage of caching system files, without continually clogging the system up with applications.
Set the value to 2 and reboot.
The 2nd time you boot it should boot much faster. Remember that the side effect is that launching individual applications once windows has loaded will now be slightly slower.
Tips
When installing new software choose not to add the program to the startup folder.
. Regularly check to see what programs are running from your startup folder as malicious programs such as spyware may have installed itself without your knowledge.
. If you accidentally uncheck a program, just retrace the steps above and recheck the program and restart your computer.
. Adding more RAM to a Windows XP computer helps it boot faster, and since RAM prices are very low these days, it's an easy way to boot faster.
. uncheck system startup unnecessary startup programs*
Warnings
. Save any open work before making changes.
. Shut down all applications before making changes.
. Don't uncheck anything from Symantec or any other anti-virus or anti-malware software. Doing so may disable or hinder the protection of your PC.
on Feb 25, 2011 | Computers & Internet
I want remove geniune from my desktob
Microsoft has created an application that checks your Windows operating system to see if the copy of Windows you are using is genuine. If it is not, the application launches a "Genuine Microsoft Software Notification" pop-up alerting you that "This copy of Windows is not genuine." This has a purpose. However, many users have reported being flooded with the pop-up notification even when the copy of Windows they are using is genuine. If this happens to you, you can remove the genuine Microsoft software notification. Note that the instructions below apply to the Windows 7 operating system.
Press "Ctrl"+"Alt"+"Delete." Click on "Start Task Manager." The Windows Task Manager opens. Click on the "Processes" tab. Click on "wgatray.exe" and then click "End Process." Restart your computer. Press F8 continually while your computer is booting. The Advanced Boot Options menu will appear. Click on "Safe Mode" in the Advanced Boot Options menu. Click on the "Start" menu and then click on the "Search Programs and Files" box. Search for and delete the following files: (To delete a file, right-click on the file and select "Delete.") "C:\Windows\System32\WgaTray.exe"
"C:\Windows\System32\dllcache\WgaTray.exe" Click on the "Start" menu and type "regedit" into the "Search Programs and Files" box and press "Enter." The Windows Registry Editor opens. Locate the following registry entry in the Windows Registry Editor and delete it. To delete a registry entry, right-click on it and select "Delete." "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify\WgaLogon"
b>
Mar 03, 2013 | Microsoft Office Professional 2007 Full...
Stop incredimail
Uninstall IncrediMail 1
  • Click on the "Start" icon and select "Control Panel"
  • 2 Click on the "Add/Remove Programs" or "Programs and Features" icon.
  • 3 Allow the program list to fully load; this may take several minutes if you have a lot of programs installed on the computer.
  • 4 Click on the icon for "IncrediMail" and click on the button "Uninstall."
  • 5 Confirm in the pop-up window that you wish to remove IncrediMail and all of its components from your computer.
  • 6 Wait for the uninstall process to complete, a success message will appear on the screen.
  • 7 Restart the computer.
  • Removing IncrediMail Components
  • 1 Click on the "Start" icon and choose "All Programs."
  • 2 Scroll down the list until you see a folder for "IncrediMail."
  • 3 Right click on the "IncrediMail" folder and select "Delete."
  • 4 Confirm you wish to delete IncrediMail, a window will pop-up showing the transfer of files to your trash bin.
  • Performing Disk Cleanup
  • 2 Click on "Accessories," "System Tools," and click on the "Disk Cleanup" icon.
  • 3 Select "Scan Local Drive (C:)" and allow the process to find all removable files.
  • 4 Place a check mark next to "Downloaded Program Files," "Temporary Internet Files" and "Temporary Files."
  • 5 Click on "OK" to confirm the deletion of the folders, files and any leftover traces of IncrediMail. The process will complete and a window screen will show a successful cleanup message. Restart the computer.
  • Cleaning Registry Files
  • 1 Click on the "Start" icon.
  • 2 Click on "Run" or click on the start search field at the bottom of the screen. Type in "regedit" and double click on the icon that pops up.
  • 3 Double click on "HKEY_CLASSES_ROOT" and then double-click on the "Applications" folder.
  • 4 Right click on on "Incredimail" and choose "Delete." Right-click on "Impcontent.exe" and select "Delete."
  • 5 Close out the registry window. Restart the computer.
  • Dec 07, 2010 | Google Gmail
    Yahoo messenger standalone won't install
    Is this the first time installing it on your computer?
    If not, Have you tried deleting cookies, temporary files, and everything in temp folder? Remove any folders or files of Yahoo Messenger and try again.
    If this is the first time, or if that didn't work, maybe try shutting off your firewall before you install it.
    hope this helps!
    Oct 24, 2010 | Yahoo Messenger
    Dazzle Instant DVD Recorder keeps telling me "this application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem." I've tried...
    Welcome to fix yah,
    Your IDVDR icon is corrupted I would suggest to you to delete that one. Go ahead and click on start button on your windows click all program click on Pinnacle instant dvd recorder. Let me know if that is working.
    If working go back to your all program right click on instant DVD recorder click on send to desktop.
    Jan 06, 2010 | Pinnacle Dazzle DVD Recorder
    0xc0000005 application failed to initialized proplerly) (click on OK to terminate the application) how to uninstall google chrome. google chrome does not uninstall whenever i try to uninstall it.
    this is a common windows error. if a certain application stops working like your google chrome. try to edit start up items, click on start, click run, on the run box type : msconfig. click ok. on the start up tab, click on disable all on the bottom right, hit apply or ok. it will give you a prompt to exit with restart. this is for xp, if its vista more likely the same but after restarting the computer, no prompt for system configuration utility will pop up. to unisntall the google chrom, if its xp go to add remove programs and click remvoe, if you have vista, go to program and features and uninstall it from there, if no go. use the microsoft installer clean up utility. http://support.microsoft.com/kb/290301 just download and install it then look for it under programs and it will gie you all the programs installed on your computer, you can look for google chrome and uninstall it. that should work.
    Sep 11, 2009 | Dell Inspiron 530 -Intel® Pentium®...
    Problem about "services.exe - Application Error" pop-up menu
    Apparently, you computer has some unexpected software running during the startup. In order to get ride of these software, you could check your register table manualy by regedit or download this software, which will help you to find if there are any suspect software running at the startup.
    files.filefront.com/sreng2zip/;8049311;/fileinfo.html
    May 07, 2009 | Computers & Internet
    Microsoft Windows XP Home Edition Logo
    61 people viewed this question
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
