Question about Philips Magnavox Learning Universal Remote
TV will not stay on. It does not seem to be the sleep control.
What can I do to make the TV stay ON?
    Champion:
  • 226 Answers
Dont hit the power button.
Posted on Dec 22, 2008
Stay logged in facebook
It seem s that you have two problems, I will address the windows 7 issue. you still need to retrieve your password from Facebook...
it seems that you networks is going into a sleep / hibernation mode. you need to go to the control panel...
power options... advance....
go to sleep.. never.. save and exit.
Tony Mitri
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 14, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Won't stay on
3-blinks by the SONY TV error code indicates that there is an audio circuit problem, ether is a shorted audio amp IC on the main board, or the power supply that supply the power to the audio amp section is defective.
May 22, 2017 | Sony KDL-52EX701 52 in. LED TV
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
We have a Sony Trinitron Color TV that seem to be in a sleep mode and we can't turn it on. Would you know what the problem is?
Hello
Press the "Sleep" button on your Sony's remote control hanset until the TV displays the time in minutes [ 15,30,45,60 or 90] that you want the the TV to remain "on" before shutting "Off" automatically. Cancel by pressing until "Sleep Off" appears. The logo also will go out from the screen.
You just do this after unpluging the TV from AC wall socker for about 10 minutes or so, and then plug it.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How do I use the sleep timer button?
Well you may please follow the steps below -
Step 1: Press and hold the "SLEEP" key, then release. The indicator light will stay lit.
Step 2: Enter time in minutes using the numerical keypad (from 1 minute to 99 minutes). For 1 to 9 minutes press 0 before the actual number. The indicator light will go off. Leave the remote aimed at the TV set.
The Sleep timer program can be cancelled (reset to zero) by pressing and holding the "SLEEP" button until the INDICATOR LIGHT blinks or by pressing the ON/OFF button.
Good Luck!!
Thanks for using FixYa!!
Oct 13, 2010 | RCA RCU410W Remote Control
TX-47F430S seems to be the common problem of going back into standby. Powers up shows the logs and then goes back to low power. The light never goes blue. The fiber optical laser turns on and stays on but...
This is known as SLEEP MODE / STANDY MODE problem.
Simple solutions:
1. Get a power surge protector / strip.
2. Plug your TV power cord to the power surge.
3.Then turn-on your TV using the remote control2_bing.gif. Just in case it won't go all the way to normal state.
4. Turn-off the switch of your power surge like 5 times with an interval of 3-5 seconds.
5. Then repeat step 3 and 4.
6. These steps are done to over-ride the sleep mode.
Roan
Jan 29, 2010 | Westinghouse TX-47F430S 47 in. LCD TV
Sleep Function???
In most cases you can set the sleep timer by accessing the menu. Or if it is a learning remote find a button you dont use and teach it the sleep button from your OEM remote.
Apr 15, 2008 | RCA RCR460 Remote Control
Phillips tv
Are you connected using R,G,B (component) cables? Check them to make sure they are in firmly - if so, then try a new set - that may very well fix the rolling issue. (Unless the rolling is caused by poor antenna reception).
Press "Sleep" on the original remote control for this TV if you still have it until the TV says "Sleep OFF".
If no strong TV signal is detected, this unit goes into sleep mode, which may explain Tuner B shutting off after 5 minutes.
Feb 23, 2008 | Philips TV Tuner Video Capture PCI Card -...
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Philips Magnavox Learning Universal Remote Logo
21 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
